This stream auto-updates
  1. Past hour
  2. Chicken tinga enchiladas
  3. If the output tube (like 300B) is self-biased, should I measure the voltage between the cathode (K) and the control grid (G1) to determine the actual grid bias (Vgk), and then adjust the trimmer resistor accordingly? I understand that in a fixed bias setup, you’d measure between GND and G1, but in a self-bias configuration, G1 might be at 0V and the cathode elevated — so the true bias would be relative to the cathode, right? Just want to make sure I'm adjusting based on the correct reference. Thanks in advance!
  4. The Megatron final stage is CCS-loaded single-ended output working in class-A. There is no problem selecting operating point that way. However the final stage is self-biased. The grid bias eats up part of the B-, in other words B- is not equal to Eb in the tube datasheet. 20 to 30mA is more than enough for an estat amp. Since 300B has a low mu (2.85), which is about 1/3 to 1/4 of a triode-strapped EL34, the undistorted output voltage will be less than with EL34. But the DHT fame and the aesthetics probably more than compensate for that.
  5. Thanks for the feedback! I wasn’t aware of the differences in operating point strategy between push-pull and single-ended, so I’ll definitely take the time to study the article you linked—much appreciated. Also, if it’s not too much trouble, could you share what grid voltage you typically use for the 23mA setting? And when you went up to around 30mA, did you notice any significant sonic differences? Thanks again for the quick and helpful reply!
  6. Today
  7. I'd say that's a very high operating point for this amplifier; the math of push-pull output stages is different from single ended and as long as the transition is smooth you can pick much lower operating points. See for example: https://www.valvewizard.co.uk/pp.html Megatron (XL) has about 22-23mA through the EL34 current sources. I've tried up to ca 30mA but not beyond that.
  8. This is a couple a months ago but a Woo Audio energizer blew the driver of a SR-X9000.
  9. Thanks for your help, MLA. Another thing I’d like to confirm: based on the 300B datasheet (see chart below), I’m planning to use a 400V B+ supply. According to the curve for Eb=400V, it looks like a plate current of 70mA corresponds to a grid bias around -85V. Would you consider this a good operating point?
  10. Yesterday
  11. I listened to that album before going to sleep every night for probably 5 months.
  12. Putting $6,000 of parts on a Walmart bike:
  13. Six worthless posts in the first 30 minutes on Head-case is a recipe for pain. If there is still a welcome message, I suggest that you read it and heed it.
  14. Rest in peace big guy.
  15. > "Ohhh you like electrostatics so you don't like bass!" The humble HD600 sighs in relief, as STAX takes the blame.
  16. Oh, and they're running on the SRM-Xh. I don't even know if they're re-capped but they seem to work well. Should I be concerned about my headphones blowing up if a cap dies?
  17. “Wendt showed up as Norm over the years on St. Elsewhere, Wings, The Simpsons, Family Guy, Frasier and The Tortellis and as himself on Seinfeld and The Larry Sanders Show. He also had recurring roles on The Naked Truth and Sabrina the Teenage Witch and guest-starred on other series like Alice, Soap, Hart to Hart, Becker, Hot in Cleveland, Columbo, Harry’s Law, Fresh Off the Boat and The Goldbergs.“ That’s pretty impressive. Also in Hairspray on Broadway.
  18. I think that's going to be the least of your concerns if you look on other forums
  19. Ohhhh so that explains their gamer planars
  20. I'm just afraid that they're going to kick the bucket sooner than later. I could send some pics but it's like 23:47 Also, the weird wool on the outer side seems to be more dense on the left side. Maybe that messes up my bass? Edit: I might be stupid, I just remembered that the power cut out, meaning I have to wait for them to charge up to get peak electrostat performance
  21. Hello. I have a pair of Lambda Nova Basic. Both drivers are slanted forward and left one has less bass. Volume is slightly unbalanced but mostly noticeable for stereo music. Should I risk it? Audio signature suddendly changed today and then it sounded normal again (that's when I noticed both drivers slanted forward. Left one was only slightly slanted now both of them fully are)
  22. RIP George Wendt. AKA Beer-Loving Norm from Cheers. Died at 77.
  23. Holy shitballs those look nice! Would love to hear them.... Saw an ad for these, would love to hear them, too! The Göbel Divin Noblesse....
  24. We post about anything like this we can find but you can't post anything like this on Head-fi and it's been that way for close to 20 years. Those who pay Jude money can get away with most things. Other forums are not much better.
  25. Yes; gives roughly +/-4V of adjustment range in my build. Can be upped if larger range is needed.
  26. Dungeon Soup
  1. Load more activity
