- Past hour
I have questions. I don't want them answered. -
Thanks Nate for the advice. I consume 5-6 liters of fluid on daily basis. Min 3 liters of water, 2 cups of coffee, 4 cups of tea. But about salt, yea I love salt. I have to reduce the amount I consume, I suppose. Gonna work on it. Also, I - at least - doubled the consumption of dairies since I became vegetarian (13 months have passed since I became one) to make up the amount of protein I need. Maybe that contributed as well. I took appointments for urology and MRI for next Monday. Gonna get a clear picture I hope.
- Today
The Life of a Showgirl by Taylor Swift (2025) https://album.link/6czzqws7wv6p3 Example: The internet needs more old white guy opinions of music that has nothing to do with them. So why not one more? I think it is overall a nice album. Very few musicians involved, this is a pure Max Martin and Shellback joint. As Rick Beato would point out, there are 100s of tracks per song. Having this dense of a production I hope goes away pretty soon. There are some funny moments and some poignant moments. Not going into rotation, but not mad at it.
So far I've been using PCBway for all of my printing, since I already order PCBs from them regularly. JLC seems like it would also be good, probably equivalent in most ways, like their PCB production. The one minor downside to PCBway is that the lead times for printed parts can be less reliable and a few extra days for completion is not uncommon. I've been wanting to try some US-based services, especially for larger orders, but so far have only tried Xometry once, when there was a time-sensitive need. They were good, and more expensive. The biggest disadvantage to using printing services instead of having a machine is that I can't really dial things in like this, though if I talked to the engineer running the machine they could probably give useful advice. I've started to use hexagonal or octagonal holes where possible to avoid this. I've also had to drill out some 2mm holes to use a batch of parts. Another tolerance thing I've run into, at least with resin parts and without having control over the part orientation on the bed, is that flat surfaces can sometimes become convex, which is a problem if the part needs to sit flush. To avoid this I'll usually add some kind of concavity to the surface so that only the edges make contact. @JoaMat's construction is pretty much what I've been thinking about, since it makes pin removal much easier than Neutrik's rotate-to-release (which did not work for me when I tried with a loose contact) or using a tool. I've also been thinking about a version that could be laser-cut or more simply CNC'd, if the plug piece was sliced into two pieces. You wouldn't get the nice flush panel mounting though. Circular connector contacts would be interesting to try, like this Amphenol AT62-210-1231-1820, though the ebay collet-style are going to be cheaper than most of those. I was also thinking about a PCB-mount socket, using Mill-Max 0321 or Preci-Dip 16008-83-4010 sockets, which are equivalent. A PCB with no copper could act as insulator and improve mechanical strength. Here's a quick render, without the necessary flange with mounting holes or traces to attachment points. A flex-rigid PCB socket could be cool in production, with the flex material potentially allowing some amount of "floating" contact behavior and also eliminating a few solder joints between the amp's output and the socket.
Twisted Metal (Peacock) - An amnesiac is enlisted to drive across a post-apocalyptic USA wasteland to pickup & deliver a package on the promise of a better life. Apparently based on a series of Sony Playstation games of which I am not familiar. Think The Transporter meets Mad Max. Mackie brings the self-deprecating swagger, while Beatriz brings...herself, which is always great. Qwerky & (violently) fun. I am about halfway thru season 1, & think it's lots of fun.
One and done, with quesabirria tacos today. I'm With Her was enough and now we're happy to be back in Fairfax before the traffic jam.
Man it's been a good 10 years since I had a kidney stone. I'm glad to only have had one and you're quite lucky to not have felt the passage from kidney to bladder (unless it really was just a bladder stone). Just about all patients (Steve and I included) experience the worst pain as the stone makes its way from Kidney down, simply because that's the smallest pipe. But all that said, completely agree, passing a solid is not fun. Side note - look for areas in your life where you are letting yourself get overly dehydrated or taking in too many salts/minerals. My brother in law had stones 4 or 5 times until he realized that taking his kids leftover multi-vitamins on top of his own daily vitamin was overloading his kidneys. Talk about a painful lesson.
- Yesterday
No point in ever turning up the pedal tensioners until you've pulled out of them because you're cranking so hard. I doubt you ever get there, I never have even when pulling 1000W in a sprint. More than anything I'm glad you're enjoying the bike. As your fitness increases and your body adapts to the positioning more and more it'll become even more fun. And she's sexy, that much is for sure.
It’s a shame he killed himself by going full MAHA and thinking an all-fruit diet would cure his cancer. The Reality Distortion Field had its limits. Hoisted on his own petard, to be sure, but he is missed.
@luvdunhill in case you find this of use. It is a summary of brew profiles by brand / specific coffee that I found on reddit. If you click on one of the coffees it takes you to a Fellow site where you can use your camera over the scan code and it will populate the brew profile on your Fellow Aiden app directly. Up to you whether you want to save, alter or discard. Pretty nifty as I was able to find several of the coffees I purchase from Intelligensia and Onyx. https://brewshare.coffee Here is the reddit post in case you want more details HS
I’m coming up on 200 miles on the new bike and still very much in the honeymoon phase. I did a 35ish mile ride today and had a blast. This thing is a riot to get out and ride. I love how much distance I can cover, and it feels like a proper machine. The farm roads where I live are infinite, and with the radar I’m not caught off guard when motorists do want to overtake. I’m starting to get used to the clipless setup. No wipe-outs since the initial one. As I’ve developed a more deft touch on the brakes it is easier to dismount under control. I still have close calls every now and then so not ready to crank the pedal tensioners up yet, but I’m getting there. I’m ready for a bike fit and booked one with a local place that a co-worker recommended that uses the Retul stuff. I don’t know what I’m doing outside of going by feel, so hoping they can help me out. I’m not sure if my saddle is right or not, and I do get some shoulder soreness on longer rides. I can see fit being more and more important as I do longer rides. I’m also going to bring the bike back to the shop for a break-in adjustment and cleaning. She is getting filthy and I don’t have access to a hose to spray it off.
Ye Macce Threade
Knuckledragger replied to Hopstretch's topic in GoRedwings19's Computer Help Hotline
"Never trust a computer you can't lift." Steve Jobs died 14 years ago today. At the time I tweeted (ya rly) "The Reality Distortion Field is now off." -
That is the weird stuff Steve. I've never felt any pain except while I was shooting the stone from my urinal canal. I literally felt it's pressure on the canal as it went through. The ER doctor and my father wouldn't believe how I endured the pain but, as I said I didn't felt any unusual thing till I peed with blood. Cannot compare as I haven't experienced kidney stone but as I read, bladder stones aren't as painful as kidney stones. There wasn't any bad reading about my vitals too, except my elevated heart beat. The stone was like small red lentil, like a 1.5-2mm size like oval shaped. I'm going to visit an urologist next week. Thank you Steve, for taking time and educating me on possible health complications. Gonna take a full Check-up after urologist too.
After the morning jaunt, the plan was to start with Dan Tyminski but I took a nap instead. Claire went and enjoyed it. I arrived at the blanket one minute before Cimafunk started, which was pretty ideal. They are from Cuba but live in New Orleans now apparently. Fun stuff. Made our way to the adjacent stage in time for Tweedy to come out and bore the snot out of everyone. The sun was in his face and his deathly pallor clearly indicated that was not routine. When he finally spoke, he said that he didn't know the sun would be here and "that's not cool, man." Wilco's California Stars was the only song that got the crowd going. At the end of the show he said that it was the first show touring for his new triple album, and thanked us for listening to a lot of new stuff. Definitely the weakest of many Tweedy shows I have seen with Wilco, solo, and with this band with his two sons that he used to call Tweedy. Oh well.
So I've been there myself. I had no idea what was happening to me, but it was the worst pain I've ever had. I finally called Al, who took me to the emergency room. The first thing that they did was to take my vitals. I remember the look on the Doctors face as he took my blood pressure. All of a sudden the initial reason for me being there (I think they already suspected a kidney stone), everything switched to reducing my BP. I was quite literally in the stroke zone. Once they gave me some BP medication, and got that down a bit, then they switched back to the kidney stone. However, the kidney stone that caused that incredible pain was the size of a grain of salt. I actually thought at one point my appendix might have ruptured. I thought it was possible that I might die. That's when I decided to call Al. The good thing that came out of that experience was that the ER Dr. made me an appointment to get more thoroughly checked out. That's when I discovered my hypertension. A week later my diabetes and elevated cholesterol. The meds that I take now are working fantastic at controlling those issues. I just can't imagine a lentil sized stone! I thought I was dying from a salt grain sized stone. The stone passing through my penis was painless (insert large penis joke here). It's whatever vein or artery it initially traveled through that was excruciating. I understand your pain and your panic! I did not have any blood in my urine during my event, however 10 years earlier I woke up and went to pee and my urine was red. My Father had this happen several times. He also had hypertension. So I understood the gravity of blood in urine. My panic completely left a few minutes later as I discovered the Red Velvet cake I had made the day before, and consumed some of had started bleeding the Red color through the cream cheese icing. Thankfully it was just the Red dye from the cake. That was the first and last time I ever made or ate Red velvet cake. Just take this as a warning to be thoroughly checked out. If something is made aware from this, it can be treated. Don't be a dumbass like me and wait until your almost 60 to finally go to a Dr. We're never bulletproof. Not at 60, not at 40 or even 20.
So yesterday night, I had blood in my urine, like my pee was strawberry flavoured. Fucking freaked out, was thinking like "worst experience of my life". Went to ER immediately. After waiting half an hour and drinking lots of fluid, even before seeing the doctor, I passed the effing bladderstone on my next urination. That was THE WORST experience of my life. Nothing in solid form should ever pass from there. It was out of blue. I haven't had any pain or anything and within an hour I peed blood and passed a small red lentils sized bladderstone. I don't have any pain or burning but going to take antibiotics for a week. It was a wake up call like "you're not a young guy any more, should start take care of yourself better" TL;DR: I peed blood, shot a small stone from my penis and felt old.
Grahame replied to Knuckledragger's topic in Off Topic
As written privately to @willsw, I'm in need for some 6 pins plugs, and I'm happy to lend a hand down what regards cad design, 3d printing (will order from jlcpcb though, so beware shipping times), and or pin variants. Unfortunately on the web the set of kt88/el84 pins with screw is to be found quite expensive, 10€ 10 pieces from audioaholics in France. Stax lambda NB already in, and don't have any socket for it 😞 Glad to help.
I caught parts of Earle - but I got caught up in Courtney Barnett and just rode that out. Tomorrow is about clearing my calendar to make sure that - I'm With Her - is my priority.
Thanks! I will have to check out Nick Lowe and Los Straitjackets tomorrow. (2:05 on Swan Stage at Right Coast time, presumably.)
Sorry, I was remote. I would have definitely reached out Al if in person. Hope you and Claire had a good time. Anyone catch Steve Earle? I don’t pretend to be objective there, but was messy fun, especially in the shadow of the Dukes breakup at HSB years ago. Will throw on The Mountain in a few minutes. Will miss tomorrow, unfortunately. Hope everyone enjoys.
I wish I knew you were there. We could have connected
- Last week
She and Leventhal are pretty great. Smiled the most so far with Albert Lee.
