- Today
Seems very much of the times.
- Yesterday
The drivers are genuine, there is just no way to reuse the stock rings so I had to have my own made. The 009 diaphragm rings make zero sense too as there is no way to solder to them so PCB's here make a lot more sense. Plus more insulation as the stock setup is not ideal. The stators and the case will be stock and I went for slightly thicker rings for the dust covers to add more compression to the drivers. I'm also going to replace all the o-rings with better units. One thing I want to do as well is plug that hole in the center of the stators. I don't understand the reasoning behind it and it might be one of the reason why the 009's sound so bad.
£220 ‘for a cut-up sock' - Apple's new iPhone Pocket ridiculed online https://www.bbc.com/news/articles/cn97ndgpnq7o
True, any modifications you make there won't allow you to predict results on genuine drivers. But I’ll still be interested in your work.
They will have new diaphragms so they will be tonally completely different.
Ah, ok, so mods for cables. I was wondering if you found a way to trim tonality of drivers a little.
For the cable entry as a prototype but probably milled once I'm happy with the piece. The drivers will be fitted with new diaphragms and dust covers (as they were shot on this set) so that means PCB's for that plus a new way to fix the earpads in place.
I would like to see your ideas about fixing SR-009 drivers. Are you going to use some 3D printed parts?
- Last week
Chris Rea - Dancing with Strangers
vinyl
Thanks. :) More hopefully on the way soon plus maybe some speakers
Thanks all. Hope all is well with everyone! Trying to start a program related to my headphone correction research back in the day actually.
Thanks!
I used a 3M (Adafruit) thermally conductive adhesive tape. Mouser 485-1468 (80x80mm sheet).
GrindingThud started following The Multi Amp aka Dynalo Mk2
What is the favored method for affixing the heatsinks to the output transistors? After years on the shelf, I’m finally getting around to assembling this. 🤓
Belated Happy Birthday to you both! Hope the days were great!
they looks cool
Happy birthday both!
Happy Birthday Mikey and Chris!
Happy birthday, twins! Up to you to decide who I'm insulting... 🤣 Neither is the only correct answer.
Happy Birthday!
Happy shared birthday Chris. Happy smoked salmon to me. opened a half bottle that has been kicking around for a couple decades. 1968 BV Burgundy cheers
