- Today
Jimmy Scott - Nothing Compares 2 U
- Yesterday
I miss Dr Leo. Thanks Internet.- KGSSHV Carbon Build Thread
Wanted to say that i have a headinclouds built KGSSHV from 2017. Rarely used, maybe 500 ish hours over the years. Turned it on yesterday to fizzle. Found both blue 680uf caps have blown... Hopefully nothing else. Will be reading this topic in the coming weeks!. Lucky i still have a Kerry T2 to use.- Songs You Came Across On Some Streaming Service And Thought Your Head-Case Buds Might Enjoy Too. No Critical Endorsement Implied. Fuck Vevo etc.
More Bill Evans, Nardis - 1970- The Headcase Stax thread
Ordered a set of the Hongshu EHA-1 because a good friend got his and really liked them. He sent me som pics of the internals of the complimentary amplifier that you get in the same package as well:- The Knuckledragger 3rd Memorial Slow Forum Post
OMG. How did I not know about this and him? Thank you. Plowing through the Riz Ortolani YT channel now.- Last week
One for @blessingx -- possibly an all-time disconnect between vibe and content.- The Quest for >2000 Vppss
Okay, I finally confirmed the source of the problem today. It looks like the LSK389 input stage is simply extremely sensitive and is very easily picking up magnetic field noise from the power transformer.- What are you EATING right now?
Tried a relatively new restaurant near us, Kirkwood. Short rib and old fashioneds very respectable. Service was super. HS- The Quest for >2000 Vppss
Yes, those. Will have a look with the scope on the output but it'll be a while, I've put this project away for a few days while waiting for the right top and bottom chassi plates.- The Quest for >2000 Vppss
Thanks for the information. It looks like 5pF is also stable on my build, although I’m using the SMD version of the power supply boards. When you mentioned the “dual current sources”, what exactly did you mean? Are you referring to the two current source stages before and after the power supply on Kevin’s latest board? I’m using PZTA42 for Q9/Q10 instead of TTC004A, so perhaps that’s something I should investigate next. I also have a pot at the input, just like your build. If you have access to an oscilloscope, could you check the O+ and O− outputs? On my board there’s a roughly 120kHz sine wave (it changed to around 96kHz after I experimented with MLCCs on the RKZE outputs), and it seems to be related to the isolated DC/DC supply. I’d be interested to know whether your board shows the same behavior, even if it’s not audible.- Post what you're watching
Did some testing last night on a second build I'm doing for a friend. Psus regulate and are stable with 470pf in place, at least for the 20 min I left it on (Kevins latest board with dual current sources). Have no noise either (never had on a Carbon), but have a pot in front. Also, I'm using TTC004a rather than pzta42 as drivers for Q9/Q10.- Songs You Came Across On Some Streaming Service And Thought Your Head-Case Buds Might Enjoy Too. No Critical Endorsement Implied. Fuck Vevo etc.
I checked the datasheet as well. Since I’m already feeding the converter from a GRLV, I don’t think the input side is the issue. One interesting thing I noticed is that the datasheet for a compatible replacement part (with essentially identical specifications) recommends adding an LC output filter for noise-sensitive applications. The example value is around 0.47µF on the output. I don’t have any 0.47µF MLCCs on hand at the moment, but I’ll probably place an order next week and give that a try to see if it helps reduce the remaining noise.- What are you listening to Part the Third
Damn, that sounds intriguing. Will give it a listen.- The Live Music Thread
@swt61 - very cool that you got to see Charlie. He came through H-town with Leon Bridges and unfortunately we were traveling so I missed that opportunity. I look forward to getting to enjoy him live one of these years... HS- The Live Music Thread
- What TV show are you watching now?
I’ve just finished binge watching Ann Droid. More than entertaining, I’d say.
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
