- Past hour
Yum. I love a good Puttanesca. Thanks for the recipe.
- Today
Too remote to protest, so I fought against clean air. Last varietal that I received in the gift pack for my buddy. Gurkha Beauty - 6,5”x58 A really nice smoke. Heading into the 30s again with 20s tomorrow. This winter will end at some point. I think I'm in the third or fourth false spring.
- Yesterday
The wifey and her bestie cooked up a homemade pasta puttanesca last night that was spectacular. I got curious so searched a bit... This recipe from the NYT garnered a lot of love for those less inclined to eyeball it... https://cooking.nytimes.com/recipes/11583-pasta-puttanesca HS
Godspeed, James Tolkan.... https://deadline.com/2026/03/james-tolkan-dead-back-to-the-future-top-gun-1236768221/ HS
If they can fix the QC issues everybody is talking about, then I'm hyped. I never had issues with my sets but then again... I don't use them all that much.
I'm also interested in Halo Acoustics though I can't find their headphones in stock at Taobao. I also heard they're making a headphone in the 10,000 RMB range.
Dusty Chalk replied to Knuckledragger's topic in Off Topic
Root Down - Live ! by Jimmy Smith (1972) https://open.qobuz.com/album/0060254782508 Example: Getting a Friday groove on with Jimmy.
Ross “The Boss” Friedman, Legendary Dictators and Manowar Guitarist, Dead at 72.
Sure @Pars - the rice is from the NYT Cooking site: https://cooking.nytimes.com/recipes/1022318-cilantro-rice?smid=share-url. That might be paywalled, always tough to tell with NYTC so let me know if it doesn't come through. It's the kids favorite rice. My only tweak is I use a little less onion powder and sub in some garlic powder. Enchilada Sauce - Ingredients 1 pound tomatillos 4 cloves garlic 2 jalapeno peppers 2 poblano peppers 2 serrano peppers (I usually can't find these so just up the poblanos) 2 tablespoons chopped cilantro ½ tablespoon cumin 1 tablespoon spicy chili powder Salt and pepper to taste 2 cups chicken broth Juice from 1 lime Instructions Preheat oven to 350 degrees. I actually just use the broiler, on low and first and then ramping up to high. Doesn't really go any faster but gives better char on the peppers in my experience. Peel away the dry husk and rinse the tomatillos. Chop them in half and set them skin sides up onto a lightly oiled baking sheet. Slice all of the peppers in half lengthwise and set them onto the baking sheet. You might need more than one sheet. Also, remove the innards of the poblano before placing them. Add the garlic to the baking sheet and bake for 20-30 minutes, or until the pepper skins are nice and charred. You can also broil them, but don't set them too close to the heat source. Remove from heat and let everything cool a bit. Peel the skins from the peppers, if desired, and add to a food processor with tomatillos. Squeeze the garlic from their skins and into the food processor they go. **tip, but the peppers in a foil pouch and let them steam for a bit to make removing the skin easier** Add cilantro, cumin, chili powder and salt and pepper. **tweak - I use less chili powder, and leave the cilantro till the very end. I think the flavor is better that way** Process to combine. **I use an immersion blender in the pot I cook the stuff in after adding the broth** Add chicken broth and lime juice and process until smooth.**adjust broth amount based on how thick/thin you like your sauce. Pour the green enchilada sauce into a pan or a pot and simmer for 5-10 minutes or so to let the flavors fully develop. **don't over-cook the sauce. I cooked it all day once and the flavor seemed to break down too much. ** Final Assembly I always use corn tortillas, heating/softening them in the microwave in batches of no more than 10 as instructed on the package. Use anything from rotisserie chicken to baked, boiled, grilled, etc., as long as it's shredded. I usually season the chx lightly with homemade taco seasoning (Alton Brown's 19). 1.5lbs is usually enough for 20+ enchiladas. I stuff each tortilla with chicken and cheese, roll, place in a greased glass dish until its full. There's never too many enchiladas. Top liberally with sauce and cheese, bake at 350 for 25min (covered) and then uncover for another 5 minutes. Fresh grated cheese is always best, sometimes there's time, sometimes there's not. It's not a huge difference, but a nice one if you have the time. I usually mix colby-jack and cheddar. Go all out and get a little queso fresco if you want to go full fancy.
- Last week
I don't know if this should be under podcasts, listening to, or here, but Norah Jones Is Playing Along with Jason Isbell
Those look great Nate! Would you share the recipe?
The L500 pads are virtually the same, a bit thicker but it won't change much. Same for the L700 pads but they will both also melt away. I always use the all leather pads from China now, cheaper and much better quality but you need to get them onto the plastic mounting plate from the original pads... which is a bit of a pain
My friend's L300 pads are melting. Will there be any negative consequences on the sound if he switches to L500 or L700 pads? Also holy crap the build on that X1 clone looks worse than some $20 headphone from the 1990s
Knuckledragger replied to Knuckledragger's topic in Miscellaneous
It's an interesting unit Not the sharpest thing in the world, but it focuses quickly. The out of focus areas are warm and fuzzy, so it has good bork-eh. Probably best used outdoors. -
Yes, Birgir, it looks like you're right... I installed a 3A fuse - This time he held out and didn't burn... I installed jumpers on 2 and 5... and it looks like smoke is coming from one of the diode bridges, D11, at the bottom... It's not much, but still... I immediately turned it off I'll look for a modern replacement... It looks like it's 30 years old and needs replacing... along with the d12... It looks like the problem isn't with the slow blow fuse...
MASantos replied to kevin gilmore's topic in Do It Yourself
I guess it would need extra spacing between the bcp and heatsink to acomodate the relays. Looks very nice, if you end up ordering boards for a finalized version, could I bother you with a set? I have a GRLV configured at 24V which could be put to work. I guess one of those mini dissipante cases from modushop should be a nice fit for this.
