July 27, 201313 yr Chris, I think those are clinchers so the difference is a little less.....I think around 250 grams. That's still a substantial difference though.
July 27, 201313 yr Needs electronic Red 22 and a power meter, but definitely a good start. When do you start racing Cat 5? **BRENT**
July 27, 201313 yr I thought that the 404 where 1650 (without rimstrips) but I was off. I figured between the rim strip and the ultralight skewers 400 was about right. Apparently the ruling from the Internet is that the mad fiber are stiffer side to side. I am not sure I buy that but I have not been done a detailed back and forth.
July 27, 201313 yr Bike was 14lbs 13oz with the Zipps. About 3/4 of a pound lighter with these. I still think the Zipps will go back on the Cervelo and the Mad Fibers will go on the Calfee.
July 27, 201313 yr I was wondering about that after Mike posted his insurance acquaintance. I probably should update my home policy to specifically note the bikes. I guess I could go through the quote process there and see what the cost would be. It would probably end up being more than my car insurance. Nevermind, $3100 a year with a $500 deductible. Edited July 27, 201313 yr by VPI
July 28, 201313 yr Went for a nice, humid as hell, ride this afternoon. Much cooler than the typical Florida ride but it seemed pretty damn warm whenever not moving out there today. Thought I was racing the storm but I should have stayed out longer as there is a bit of sun out now.
July 28, 201313 yr Went to bed feeling crappy and woke up feeling crappy. No ride for me today. Edited July 28, 201313 yr by Dreadhead
July 28, 201313 yr That sucks. Looks like a pretty decent week so you might be able to get some miles in at the office to make up for it.
July 28, 201313 yr Feeling better now but not going to push it. Could barely speak last night. At the lake through tomorrow so I will try tomorrow and back to lake on Friday so may only get one work week ride in but I'm not too concerned.
July 28, 201313 yr Just picked up an Air 9 Carbon to build up as a rigid single speed... Also my first venture into the whole 29er thing. Came with the geared kit as well.
July 28, 201313 yr Sorry to hear you aren't feeling well, Chris. Rest up and get better. Nice pick up, Zach.
August 2, 201313 yr Got in a little ride after work. Went and uploaded to Strava to see my segments and it appears someone went through and marked every segment in my ride as Hazardous so they will not show the leader boards. I am guessing some asshole in the neighborhood is trying to keep people from speeding through but it is on a freaking trail and a lot of the hazardous parts are perfectly flat.
August 2, 201313 yr Took my bike to the LBS today for a tuneup and was informed that I needed a chain as well. 2,000 miles doesn't seem like enough to me, but I don't really know. Thoughts? It's ready to pick up tomorrow so I'm hoping to get in a ride a some point as a part of the pickup and then hopefully get a medium distance ride in Sunday.
August 3, 201313 yr 2000 miles is about right Nate. Especially at the lower cadences you run. Edited August 3, 201313 yr by Dreadhead
August 3, 201313 yr That life isn't out of line depending on terrain, riding style, environmental conditions (sand, mud, etc) and how/what the chain's cleaned and lubed with.
August 3, 201313 yr I would probably put abusive in all those categories so I guess 2k isn't that bad. At least the cassette was still ok.
August 4, 201313 yr 2000 miles on a chain is a lot, most of the roadies I know max out at around 1500. For mountain bikes it's even worse, I'm happy if I can get 800 miles out of a chain before it wears out, and in bad weather I've toasted a chain in under 300 miles. MEC sells chains for $15-20 so I just buy a stack of them and change them out regularly, it's a hell of a lot cheaper than replacing chain rings and cassettes.
August 4, 201313 yr Use KMC's. They're cheap and good from what I've been told. Need to take my own advice, as I usually buy SRAMs (cuz they used to be Sedis).
August 4, 201313 yr SRAM has gone seriously downhill from the Sachs/Sedis days. I had a bunch of Sachs chains from just before SRAM bought them out, they would usually last about 1200km before wearing out. My stash ran out a couple years ago and I ended up buying some SRAM chains, they only lasted 700km or so before they were toast and that was in good weather too. Then I went to KMC since they also have a quick connect link, they go about 1000-1100km before they fail the ruler test. For $15 I can't complain. I haven't used a Shimano chain in ages but as I recall they lasted about as long as the old Sachs chains.
August 4, 201313 yr Great day for a ride here today. Avg temp on the ride was 68. Bit of a rough ride coming off back and leg workout last night. I am worn out. Looks like some DBag went through and marked the majority of this route hazardous as well so Strava won't show me my previous times or the times of other riders. Edited August 4, 201313 yr by VPI
