Forum Upgrade to Version 3.4
  • Replies 122
  • Views 35.4k
  • Updated version of tapatalk installed, this should fix the existing issues with it and the new forum software version.
  • What was the exact search phrase you used?  Want to see if there is anything to do this.   Actually I'm seeing this now - will investigate.   EDIT - This issue is now resolved.  Please let me know
  • Is it just me or are "Likes" not showing up on posts any more...my Tapatalk notified me of a like, but I went to the post and couldn't see it...
BTW, just found out the "Jump to Page" function doesn't work. When I put in any page number, it always goes back to the first page.
I don't know if this is a problem with google search, the new forum software or something else.
Recently, I have had some problem when I search head-case from google (using site:head-case.org) and then click on a link.  I don't know how often this has happened (maybe in the past couple of days?).  It takes me to something like http://url4short.info/a00e9662.  Then I can't get anywhere from that.  It happened on both my computer and the ipad so I don't think it is something on my end (hope not!).  I looked around a bit and this has happened on some other forums.  One place said it was due to Tapatalk being activated? ???
Thought it may be due to the upgrade.  For now, I'll just search directly in HC.
This happened again to me again. Clicked on a link to HC from google and it took me here instead. http://url4short.info/a00e9662
EDIT - This issue is now resolved.  Please let me know if you see it again.
Be careful with that link.  WOT says it has a "poor reputation", which means that it might be downloading malware to your computer.
  • 4 weeks later...
I'm not certain if its since the last forum update, but embedded videos are no longer showing up on my iPad 4 and iPhone 4. Where there should be videos (or at least some kind of placeholder for them), there are just empty spaces. Both iPad and iPhone are running iOS 6.1.
Oh, and fwiw, I can still see embedded videos on other sites (e.g., local news paper site), but not here.
Edited by Salt Peanuts
What was the exact search phrase you used?  Want to see if there is anything to do this.   Actually I'm seeing this now - will investigate.   EDIT - This issue is now resolved.  Please let me know if you see it again.
Just saw this post. Thanks. What was the problem?
I've been having a lot of 'failed to connect to forum' problems when posting on Tapatalk lately. I THINK it's when quoting on a reply.
Along with today's update of the forum software I also installed an updated version of the server-side tapatalk code.  We were running a couple releases behind so hopefully this fixes that issue.
  • 4 weeks later...
New update for tapatalk installed - also enabled a serviced called Viglink about a week or so ago.  It's a monetization tool - if it becomes a nuisance or doesn't generate much of anything it'll get turned off.  Should have a fairly decent idea of whether or not it'll stick around by the end of next week.
Can you turn off the VigLink Insert portion of the tool? I don't mind legit links being converted to affiliate links, that's handy. It's the auto-linking of random terms that irks me. It makes it difficult to tell whether someone actually inserted a link or whether it was thrown in by the tool.
I can't see a lot of posts on Tapatalk now.  It has no picture, no name, just the number of the post.
Same. Please fix? :)
Still having issues?  I haven't heard any other reports and have been using it myself with no issues.  There is a new Tapatalk 4 out that you might want to try.
