GRLV split and combined, and any other boards Group Buy
Hello All...
Since there were a bunch of requests for more GRLV boards I'll do another round.  I've also added the boards listed below that are in demand.
  Also, as a side note if you're looking for boards from my last GB I have one set of Dynahi boards, four or five Dynalo Mini, and a few volume pot boards left.  Send me a message if you need any of those.
Sign up Sheet: https://docs.google.com/spreadsheets/d/1Z1L3MQuuY4ZTUyPQb1qBmVJp8MtC7qEzBUui3z5dFrQ/edit?usp=sharing
Balanced\Unbalanced board (both smt and through hole)
Through Hole  http://gilmore.chem.northwestern.edu/boards/diffinput3.zip
SMT  http://gilmore.chem.northwestern.edu/boards/diffinput3smtd.zip
Diamond Buffer (both smt and through hole)
Through Hole  http://gilmore.chem.northwestern.edu/boards/dbuf1.zip
SMT  http://gilmore.chem.northwestern.edu/boards/dbuf2.zip
Balanced Source Switch (Microprocessor controlled)  http://gilmore.chem.northwestern.edu/boards/baseboardbal3.zip
Dynalo Mini (with TKD pot)
Dynalo  http://gilmore.chem.northwestern.edu/boards/kgdynalobal9.zip
Current Feedback Amp (Electrostatic) Version 2  http://gilmore.chem.northwestern.edu/boards/cfaelectrostat2.zip
BH Ultramini Version 4  http://gilmore.chem.northwestern.edu/boards/kgbhultraminipsv4.zip
Golden Reference Low Voltage Version 6 combined http://gilmore.chem.northwestern.edu/boards/goldenreference6.zip
If you need 4 gang volume pots for these amp boards see cspirou's TKD group buy here:
https://docs.google.com/spreadsheets/d/1qq-ZR84X_Ik1KyHVINC6cdwdEbZ-HRh2Wf2VVBJZBkw/edit#gid=1096418962
Edited by sbelyo
  • Replies 163
  • Views 34.8k
Thanks for doing another round, I plan on getting at least 4 x GRLV6 combined boards.
Edited by kpeezy
You must be a glutton for punishment Steve :)
I'd be in for some version of the ubal board, maybe others.
+1. The effort is highly appreciated!
I'd be in for the SMD ubal->bal board and a pile of diamond buffers..
Yeah, I definitely am a glutton for punishment:rolleyes:
I'm interested in that board as well
Thx for the GB,
I am interessted by megatron but I think I am the only one
Thanks for the GB efforts.
I am interested in GRLV, DYNALO and DYNALO_MINIboards.PM sent.
BR
Alex
Thanks
I´m interested in Unbal/Bal, diamond buffer and maybe others too.
no need to post the attenuator board. I got one from sorenb. I believe he has more if anyone else needs any.
Although I wouldn't mind if you can get this controller board.
Edited by cspirou
noted...
I'm hoping to open up the spreadsheet tonight.  Been a little busy and it's my son's 17th birthday today (time flies)
Okie Dokie...
The sheet is open
So far we have the GRLV combined and split, the Unbalanced\Balanced board (through hole), the diamond buffer (through hole), the dynalo, and dynalo mini with TKD pot.  Of course I will confirm the boards are ok and in final versions.  I would love to build the CFA so I will check to see if it's possible to add that board as well.
Were you going to do the SMD Ubal board? That's the one I was interested in. Also, I assume the diamond buffer boards are single, so you would need 2 of these for each Ubal board?
Thanks!
Yep, I'll add the smt boards
Add my boards.
A friend of me is interested on SMD boards but depend on price. Can I increase my order when we know the price?
Add
Edited by jose
posted final smt version of the ubal to bal board.
the smt boards should be cheap because they are tiny, ubal board is 2.42 x 2.12 and the diamond buffer is 1.46 x .8
I would like 4 of the ubal boards, and 8 of the diamond buffer boards please
You got it...
For the Current Feedback amp, is that board still being tweaked?
the GRHV is the best, I used the BHultramini because:
It was already built,
and its the same size as one of the GRLV single "fat" boards
so its smaller, cheaper, and works for 400v.
seems like bh mini is ideal for the cfa, simply for the sake of cost effectiveness
it was for me, keeping size down and the cost to try it.
many choices here, how big do you want it to be?
how much are you willing to spend?
If you really like it then try the better supply's, fancy Cap's,
Or Giant heart stopping defibrillator Caps, on and on...
seems prudent to use it then if you ask me
remember that there is both a dynamic and electrostatic current feedback amp.
using the bh power supply on the dynamic amp is going to result in much magic smoke.
