Sennheiser HE-1
That very odd...  Now the platinum vaporized is just BS, you need high resistance here which I've confirmed on the HE90 as that was supposed to be gold coated...
Now they could have moved away from mylar and onto something else which has less mass at 2.4um...
  • Replies 69
  • Views 32.8k
  • Bump in the low mids, like old Lambdas (I think about my Lambda Signature), check. Lacking some excitment compared to Staxens, kinda german coldness in the mids, check. Sometimes biting in the highs i
  • I agree on many of your impressions on this. I also had a lengthy listen recently in a quiet environment. Took some eye-candy photos as well.  The build quality, fit and finish of it all is top n
  • Anybody crying while listening to a HE90 should seek some professional help...
The polarising voltage is 650V, so close to Stax's 580V.
Specifications
HE-1 - Headphones
Sennheiser_He_1_inpage_1.pngTransduscer Principal - Electrostatic, Push Pull Princpal
Acoustic operating prinicipal - open
Ear coupling - circum-aural
Contact Pressure - 4.3N
Frequency Characteristic - Diffuse field equalised
Frequency repsonse - 8 - 80,000 Hz (-3dB)
Max sound pressure level - 114 dB
THD < 0.01 % (1KHz, 100 dB SPL)
Connection cable - silver platted , O2 free copper cable (OFC) balanced, shielded 3m
Connector - 9 pin HV connector
Operating Voltage - 780 V DC
Polarization Voltage - 650 V
Max Input - 20 dBV
Weight (without cable) - approx 550 g
HE 1 - Headphone Amplifier
HVE 1 tube headohone amplifier
Max outputlevel - 20 dBV
Frequency response - 5 - 110,000 Hz (-3dB)
THD - typ 0.01 %
Inputs -
Analogue Balance XLR-3
Analogue Unbalanced - RCA
Digital USB - USB Type B
Digital Opt - Toslink
Digital Coax - RCA
Outputs-
9 pin HV socket for separate HEADPHONE 2 storage
Analog BAL : XLR-3
Analog UNBAL: RCA
Weight : 21Kgs
Who wants to bet they are using 800V mosfets for the output?  ;)
  • 2 months later...
I have been into Stax for about a year or so, and I already feel that Stax is ahead of it time.  I am thinking that even Sennheiser is behind, but Sennheiser is in a much better shape to keep pulling onto their ultra-flagship lines to release Orpheus He-1.  Unlike Stax, after reading much into it history, and legendary T2+Omega, I feel so sad, and not sure if Stax will continue on being the same ? I know the latest T8000 was just “cold”
*found more info on the 009*.
  It is awesome
Edited by Whitigir
Stax have never said what the diaphragm is but they might have moved away from mylar.  Plenty of new materials to play with these days...
They did say in general that
New high polymer ultra-thin film material called the super engineering plastics
Stax over Senn for sure, despite the gold ceramic electrodes
  It is awesome
yup,T8000 is another 727 like amp,still haven't enough power.:huh:
  • 4 weeks later...
The best Stax amp is SRM-717. Nothing is better. Its the perfect amp that dose not need any mods to make it sound amazing!
I assume the SRM-T2 isn't being counted because of its pension for self destructing?
Edited by SeaWolf
Lol! I take that T2 travelled back in time to save Stax from bankruptcy. No longer existed in this timeline and on
Edited by Whitigir
Stax SRM-T2 is a useless legendary tech. No one heard of and is lost in time.
Out of all Staxs Amps only the SRM-717 rules as king. And this is done without any help from modders and such. No tubes, no mods or anything like that for 717 to be the best. Because of this 717 is king
No mods except the 717 is actually a licensed KGSS...  :ph34r:
Who is this Esmeralda fucktard? Person doesn't know shit..., but rather opinionated. Good combo. Did head-fi crash again?
Edited by Pars
Or isn't the KGSS an unlicensed 717 ? :ph34r:
Ali
This has always confused me because in KG's original KGSS Headwize article he said that he wanted the best amplification for the then new SR-007 but didn't want to pay the money for an SRM-717 - which implies that the 717 preceded the KGSS.
Well they aren't identical as Stax did fuck with it a little bit but if you look at the schematic it is easy to see where it came from.  There is also a much bigger part of this story which involves some people appropriating this circuit as their own that I'm not going into.
  • 7 years later...
If you were wondering what's inside the headphones, you can see a little bit of it here
