Stax plug
This may be a stupid question, but I just received some cooper 76-S6S sockets from Allied and I can't for the life of me figure out how the retaining ring fits around the socket. Any pointers?
  • Replies 57
  • Views 31k
  • I did some test prints of Stax jacks with different pin-hole diameters. As you can see, they are obviously 3D-printed, but the material is rated to withstand up to 195 °C. So far I’ve been usin
  • From a post somewhere else. I also tested HA-3FXX pins, but I like above pins better. Disadvantage is I had to destroy good Neutrik connectors to get the pins out. Made in Sketchup.
  • simmconn
    simmconn
    I found a 2.3mm receptacle contact with a lantern-type spring insert, which should be able to tolerate some radial misalignment without too much change in the mating force. I've been toying with the i
If anybody has a more elegant answer than "just mashes on from the back" I haven't heard it yet. That's what I did.
You do "mash it from the back", but it takes a bit of care. Try to keep the pressure even all the way around as you push so the ring doesn't get bent or broken.You'll only get one chance. I support the front of the jack with a block of wood and press the ring from the rear with a socket wrench slightly larger in diameter than the back side of the jack. Remember to keep the "teeth" of the ring pointed towards you as you push.
That is, in fact, more elegant. Much.
Real one. Seller might have more, haven't asked. Price isn't cheap.
http://www.ebay.co.u...=item45fc2894d4
-edit-
He;s also selling an Orpheus key for £80.
http://www.ebay.co.uk/itm/key-Sennheiser-Orpheus-HEV90-no-ED-9001-/300583272168?pt=UK_AudioVisualElectronics_HomeAudioHiFi_Headphones&hash=item45fc28bee8
Edited by Duggeh
Any reason the original stax inlet is superior, less the bragging rights?
I doubt it. It looks nicer certainly, but then the white teflon ones look even better.
The old Amphenol sockets aren't exactly the correct size so they grab a bit too much. The Stax sockets are much nicer but not 80+$ nice...
Does Woo still sell the teflon connectors? Might be better off just going with them... (IMO better than using cheap connectors that might change the shape of expensive Stax cables)
Wonder if that's the same Wiktor with the WTB ad for a T2 on HF
Same one.
That guy is nucking futz with his prices. $33K for an Orpheus system? Yeah right.
I checked with them today. He said they no longer make the teflon ones and they use the Amphenol connectors now
Pretty sure justin is going to make a batch of the teflon jacks.
I'm planning on making a small run of teflon plugs.
Once i find suitable pins.
A new (and better) source of these jacks and plugs would be greatly appreciated.
My small hoard of the Amphenol jacks is pretty much exhausted. As a source of last resort, I still have a few left. But for general purposes, they're gone. In the unlikely event I ever get more, I'll post it here.
Frank,
When you have a minute check your private messages here. Also, I have a few jacks (amphenol) and one plug if someone is in need.
Hi Kevin, I seem to recall from somewhere that these needed to be machined for correct fit? If that's right are your spares already turned down? Either way, I'd be interested in at least a pair. Cheers
I was doing some googleing tonight and found a neat tutorial on HF showing how to fit one of the amphenol/wpi jacks into a neutrik xlr housing. Definitely looks better than the stock amphenol one, has a better mounting solution, and shouldn't be very expensive to make. Could be a decent alternative to teflon ones if no one ends up making some or they are too expensive. I'm not sure about what the rules are here for linking to HF, so you can find it by googleing "amphenol stax jack"
  • 13 years later...
Hi,can I "convert" my 6 pin male plugs to 5 pin (pro configuration) simply by removing the centre pin or will it destroy the whole set up? ( Got a pair each of old SR-5 and Gamma ). Want to reconfigure them for Stax SRM-D10.
Asking for a friend...
You can't plug normal bias headphones into a Pro bias output, that will just blow them up even on trash like the D10.
If it is just the plug you want to modify, no you'd need to connect the left side bias somewhere in the cable as it is only connected to the center pin.
  • 2 months later...
So far I’ve been using them for about 2 years without any issues.
