Mobile theme
  • Replies 73
  • Views 37.2k
Yeah I'm also seeing the problem with loading big threads on tapatalk. It will load 9 or so posts of the stax thread and doesn't give a button to load more posts. So hopefully it gets improved because otherwise it is a nice app.
mobile.head-case.org works great on both my Touch Pro 2 and SE C510a. Thanks!
work ok on my TP2 but it seems to not auto fit the screen, is this happening to you as well?
  • 5 weeks later...
it doesn't say there's an update for me, and big threads are still a problem. I use it for pm and smaller threads tho, and just switch to the browser for the big ones.
Edited by grawk
Been using tapatalk here as well and it's been working well for me.
EDIT - One odd behavior I've noticed is that posts I've made from tapatalk doesn't show up as "Last Post" when you go to the main forums page. For example, Dan's post above is showing up as the "Last Post" for the "Suggestions" sub-forum even though my post here was made after his.
Edited by Salt Peanuts
any way to increase the size of the page numbers on the mobile theme? maybe make it ---1---2---3---...
Can I ask that the Go-to-last-post button be added into the mobile theme? If there isn't someone good at editing VB themes, I can work out how to do it on another forum I run and pass along the info.
It would be cool if you could filter subscribed threads for those with new messages in them, too. But no biggie.
Hmmm. I see a link that says "View all subscribed threads". It looks like the one in the full size version. When I follow it, I get the same list of subscribed threads - which is all of them as best I can tell - and the same option "View all subscribed threads". Click the link again and the same list is returned. This with Opera on a Windows Mobile 6.1 device. Stand by. I'll try Internet Exploder and see how it behaves.
.......... same behavior in IE.
Thanks tkam. Looks like 1.3 has some nice enhancements (full pagination, view online members and one-click message).
1 step forward, 2 back. Long threads are broken again.
Looks OK to me.
Edit: You're right. It can't deal with truly epic threads on the "What Are You Listening To" scale, but lesser large ones like "What Did You Do Today" etc. seem fine.
Edited by Hopstretch
  • 2 months later...
They've made some nice UI changes over the last few updates, but it still can't handle the big threads. A real pity. :confused:
