July 30, 200917 yr comment_260954 mobile.head-case.org works great on both my Touch Pro 2 and SE C510a. Thanks! Report
August 4, 200917 yr comment_262565 Yeah I'm also seeing the problem with loading big threads on tapatalk. It will load 9 or so posts of the stax thread and doesn't give a button to load more posts. So hopefully it gets improved because otherwise it is a nice app. Report
August 5, 200917 yr comment_262899 mobile.head-case.org works great on both my Touch Pro 2 and SE C510a. Thanks! work ok on my TP2 but it seems to not auto fit the screen, is this happening to you as well? Report
September 4, 200917 yr comment_273209 fyi the issues with big threads on tapatalk are supposed to be fixed now. Report
September 4, 200917 yr comment_273213 it doesn't say there's an update for me, and big threads are still a problem. I use it for pm and smaller threads tho, and just switch to the browser for the big ones. Edited September 4, 200917 yr by grawk Report
September 6, 200917 yr comment_273896 Been using tapatalk here as well and it's been working well for me. EDIT - One odd behavior I've noticed is that posts I've made from tapatalk doesn't show up as "Last Post" when you go to the main forums page. For example, Dan's post above is showing up as the "Last Post" for the "Suggestions" sub-forum even though my post here was made after his. Edited September 6, 200917 yr by Salt Peanuts Report
September 6, 200917 yr comment_273908 It probably just needs refreshing, and there probably is no way to force it to do so. Report
September 15, 200917 yr comment_276476 any way to increase the size of the page numbers on the mobile theme? maybe make it ---1---2---3---... Report
September 16, 200917 yr comment_276677 Can I ask that the Go-to-last-post button be added into the mobile theme? If there isn't someone good at editing VB themes, I can work out how to do it on another forum I run and pass along the info. Report
September 17, 200917 yr comment_277253 It would be cool if you could filter subscribed threads for those with new messages in them, too. But no biggie. Report
September 17, 200917 yr comment_277260 It would be cool if you could filter subscribed threads for those with new messages in them, too. But no biggie. The control panel does that Report
September 18, 200917 yr comment_277566 Hmmm. I see a link that says "View all subscribed threads". It looks like the one in the full size version. When I follow it, I get the same list of subscribed threads - which is all of them as best I can tell - and the same option "View all subscribed threads". Click the link again and the same list is returned. This with Opera on a Windows Mobile 6.1 device. Stand by. I'll try Internet Exploder and see how it behaves. .......... same behavior in IE. Report
September 28, 200917 yr comment_280564 for those of you using tapatalk, it's up to version 1.3 now and i've installed the latest version of the server side software for it. Report
September 28, 200917 yr comment_280584 Thanks tkam. Looks like 1.3 has some nice enhancements (full pagination, view online members and one-click message). Report
September 28, 200917 yr comment_280597 1 step forward, 2 back. Long threads are broken again. Looks OK to me. Edit: You're right. It can't deal with truly epic threads on the "What Are You Listening To" scale, but lesser large ones like "What Did You Do Today" etc. seem fine. Edited September 28, 200917 yr by Hopstretch Report
December 22, 200916 yr comment_307978 They've made some nice UI changes over the last few updates, but it still can't handle the big threads. A real pity. Report
December 22, 200916 yr comment_307980 There's a trick, and then it works. If you hit a thread it gets forgetful on, back out, hit refresh, then you can enter and read the end of the thread. Report
December 22, 200916 yr comment_307995 i updated the server-side plugin this morning, it was a couple versions behind. Report
December 22, 200916 yr comment_308000 fyi there's also a version of tapatalk available for android. it's currently in beta you can find it in the android market by searching for tapatalk Report
January 9, 201016 yr comment_313738 TapaTalk seems to be working pretty much perfectly now after the last update. Report
