  • Replies 5.4k
  • Views 1.4m
The language barrier is killing me, but if someone wants to do a group buy on
the sockets, we can get the 9 pin ones for a bit less than $14 each, and i still
don't know how much the 8 pin sockets are.
I'm in. :) I have no idea how many I'll need but 20-30 sounds about right.
What sockets? I am in for whatever I will need for my amp and can pitch in to the pre-purchase effort if helpful.
More info on the teflon sockets when i get it. Maybe someone else can do the
group buy, otherwise i'll do it. At some point soon i may need a bigger house :D
So they say measure twice and cut once.
I kind of believe in measuring about 12 times and cutting once.
(especially with these prices on the circuit boards)
http://gilmore.chem.northwestern.edu/t2chassis7.jpg
http://gilmore.chem.northwestern.edu/t2chassis8.jpg
KG has also asked me to see if anyone would be interested in a group buy for Alps RK50?
What sort of standard deviation do you get?[/me-being-funny]
My sister is in textiles, but I don't think she'd get that.
how much?
how much?
probably around 800 but i would have to check the current pricing. they may have revised it since the dollar dropped
I'll "need" a bunch of 4 gang pots soon so I'm looking into TKD and P+G options to see just how much cheaper they would be. Handy for those of us that don't need just one RK50... :D
Last time i checked, balanced P&G were about $580, but the price has likely
gone up.
I can check with one contact that I have if it'd help. The same guy quoted ~$250 for 2 gang P&Gs. Be aware that I don't think P&G makes pots higher than 10k (15k on special order occasionally) so that may be a factor.
I do think that the P+G won't be cheap but if you could check Nate, then that would be great. The low impedance isn't a problem for me but for others it might be. As for TKD, a 4-gang 2500 series is roughly 180
Seems like there should be a decimal point there somewhere, I could imagine it being $126.00. What sockets are these Kevin (PM if you like)?
CMC I'd wager
Be a hell of a lot easier to get them from Parts Connexion, wouldn't it?
PCX Image
CMC Image
CONNEX Socket 8-pin, Octal (KT88, 6550, EL34, etc.)
CONNEX Socket 9-pin, (12AX7, 12AU7, 12AT7, 6DJ8, etc.)
Look like the same thing to me and while PCX's price is a bit higher I'll contact them about quantity discounts over the 25+ discount they list on their site. How many of each are required for each amp?
I dunno. I picked my lot up in person in China. I think I paid around $6 each for the octals with my mother-in-law doing the bargaining.
