Cynric Posted November 6, 2010 Report Posted November 6, 2010 I'd rather go for an ancient, cheap amp like the srm-1 mk-2 with some new psu-caps. Should be a lot better than your transformer box and is not going to blow your wallet.
padam Posted November 6, 2010 Report Posted November 6, 2010 I am very satisfied now, and if it would be my main headphone (it isn't) I would go for the 717 at least but really this is fine, Sigmas are more comfortable with adapters than other Staxes as the detail is limited anyway. And at one point I might feel reaching for a slight EQ-ing that isn't there while the signal always goes through this with the Creek so using it doesn't degrade the sound further. In contrast the SRM-T1 sounded terrible with the Sigmas. Albeit yes an SRM-1 Mk2 should be a bit better and those pairs probably never had a service.
spritzer Posted November 6, 2010 Report Posted November 6, 2010 If you are really cheap then you could build a KGSSHV for 500$ but you'd have to be pretty cheap. The SRM-1 Mk2 is very nice and you can get more voltage swing by running it balanced.
padam Posted November 6, 2010 Report Posted November 6, 2010 Maybe (much) later on when the nicely built amps appear, I am not in a rush and I am sure I would still miss the tweaking a little with the EQ (although when I finally switch to PC there will be new options). And yes of course that XLR connection on the DAC is going to be used later on, but I have a slight noise issue with it (very likely one connector is a bit iffy) which will need fixing later (RCA is dead quiet so I don't care now). These are very nice as it is and I looked it up on that document, they were serviced in 2009.
John Buchanan Posted November 6, 2010 Report Posted November 6, 2010 I was planing on having them converted but I am definitely off from it now, these are way too good sounding on their own so I guess it has a full service at some point and the damping seems to be in nice shape as well and the pads are almost new. If these would have more extension they would be almost flawless but you can't have everything, they are great for what they are, "tiny" electrostatic speakers near the ears ) And my friend told me the Sigma 404 has a honky quality to the upper midrange so might have a bit more extension but the overall sound is not as nice. You might want to listen to the Sigma/404s. There is no honkiness in the upper midrange that I have ever heard. In my opinion, the 404 upgrade was ALL good and without any drawbacks (less of the upper bass hump, more low bass, less treble roll off and retained the magic mids that do piano and voice so well). They are a very addictive phone. The SRD-7 -> Pro is what I use and they sound great. The SRM-Monitor also sounds very nice, but can't hammer the phones like the Studer A68 or the Audio Research VT130 through the SRD-7.
padam Posted November 6, 2010 Report Posted November 6, 2010 It would be surely nice to compare but I like it as it is. By the way, do these newly constructed drivers like in the 507 fit in the shells the same way? On poorly recorded/mastered recordings where my favourite overall phones (HD250II) kill me with the highs I can just enjoy the sound of the Sigmas, so they are just fine for what they are in this form. If I want I just EQ it a little, it doesn't seem to work in a natural way with my other phones but it does here. And yes the two previous pairs I had definitely had more bass than this or I had very bad synergy at that time (probably both). If only it had firmer imaging but there is no point in complaining instead of just listening to the music.
John Buchanan Posted November 6, 2010 Report Posted November 6, 2010 (edited) It would be surely nice to compare but I like it as it is. By the way, do these newly constructed drivers like in the 507 fit in the shells the same way? On poorly recorded/mastered recordings where my favourite overall phones (HD250II) kill me with the highs I can just enjoy the sound of the Sigmas, so they are just fine for what they are in this form. If I want I just EQ it a little, it doesn't seem to work in a natural way with my other phones but it does here. And yes the two previous pairs I had definitely had more bass than this or I had very bad synergy at that time (probably both). If only it had firmer imaging but there is no point in complaining instead of just listening to the music. According to Spritzer's dissection of the 507s, the new drivers are not glued together then attached to the base plate with double sided tape. They are compression fitted together by screw tension applied to a housing box. There is nothing to screw the housing into on the standard Sigma base plate, although transplanting a 507 base plate and housing/driver sounds workable if the new base plate if the same size. I guess by then, the cost is starting to get close to $2000 ($900 for the 507, $800 - 900 for the Sigma), and you are in O2 territory. Edited November 6, 2010 by John Buchanan
padam Posted November 6, 2010 Report Posted November 6, 2010 Those prices are way two much, Sigmas can be had for a lot less and the SR-307 is also a lot cheaper while probably having the exact same driver and precious little difference, maybe I should have written Sigma 307 in the first time.
deepak Posted November 6, 2010 Report Posted November 6, 2010 Are normal bias Sigmas really $800-900 now? I remember them selling for $400-600 not too long ago.
spritzer Posted November 7, 2010 Report Posted November 7, 2010 I can't see any way of transplanting the new drivers. There is no way to move the baffle over to the Sigma either so picking up a used SR-303 is still the best choice.
Cynric Posted November 10, 2010 Report Posted November 10, 2010 Has someone here looked into the buzzing sound of the SRM1 Mk2 (or how to get rid of it) yet? I mean that very quiet and high noise it makes once turned on, sounds like harmonics from the power line 50hz (nothing on the phones, the sound is coming out of the case). Not a big deal - once you turn up the music you won't notice anyway - but it would be nice to have the amp totally silent...
spritzer Posted November 10, 2010 Report Posted November 10, 2010 I've never had that issue. Sounds like transformer buzzing so either it wasn't wound correctly or something on the AC like is making it buzz. Have you tried the amp on another electrical system to see if it buzzes?
Cynric Posted November 10, 2010 Report Posted November 10, 2010 No, not yet. But a friend of mine who also has an srm1 mk2 is having the same issue with his, so i thought it might be a known problem. It's really subtle, sou you either need to know it's there or place your ear right above the vent holes of the amp to hear it...
spritzer Posted November 10, 2010 Report Posted November 10, 2010 I've spent way too much time hovering over opened SRM-1 Mk2's (adjusting the offset/balance) and I've never heard buzzing. In other news, my Exstata with group buy amp boards and a KGSS PSU at +/-350v is finally up and running.
Dusty Chalk Posted November 10, 2010 Report Posted November 10, 2010 I don't remember there being a buzz issue with the SRM-1 Mk2 that I've had (admittedly small amount of) experience with. If your buddy is on the same power system, I would make that the first thing to check.
spritzer Posted November 10, 2010 Report Posted November 10, 2010 One thing that came to mind, are the amps set to 220V or 240V? They are old enough to be 220V if they have never been adjusted.
Cynric Posted November 10, 2010 Report Posted November 10, 2010 Mine is on 240V and as far as I can remember his is too. We do live in the same town, however different houses. I checked with his amp just an hour ago and it does buzz a little (in addition to a 50Hz hum, which mine does not have. I'll see if I can find out from wich parts the sound comes tomorrow.
kirkwall Posted November 11, 2010 Report Posted November 11, 2010 I'm tempted by the 507, but the descriptions of a bright character worry me. I have the Basic system (2050 II) and really enjoy it, and would like to move up the line. Wouldn't want to lose the equable nature of the 202/252 though, and I can't stand forward/aggressive highs. Wondering if the 404s might do the trick. best, k
spritzer Posted November 11, 2010 Report Posted November 11, 2010 The 507 is far better then a stock 404 and the brightness is something all Lambdas have to some extent. Whether the 407 might be the best buy of the bunch is something we'll have to see about. If it is just the 507 with less fancy building blocks then it is going to be a winner.
kirkwall Posted November 11, 2010 Report Posted November 11, 2010 ^^^ Thanks very much for the info -- just read up a bit on the new models and think I'm going to try for a 407, likely with a 323A, given my budget. Looks like there may still be a wait for these (Bluetin says a short wait) so hopefully before Xmas. Even the 202s are pretty great with the music I tend to listen to. Wish I'd jumped into Stax a long time ago. thanks again and best, k
graben Posted November 12, 2010 Report Posted November 12, 2010 I will finally get off my butt and go audition all the new Stax tomorrow. I will let everyone know my comparisons of them. Will probably end up buying a 407 or 507.
graben Posted November 13, 2010 Report Posted November 13, 2010 Here are my impressions of the 307, 407, and 507 If you want the short version I bought the 507. Long version Take my impressions with a grain of salt as it was in a not totally quiet place. I went to my favorite Stax dealer here in Japan. I listened through a srm-600 and a srm-006TS, as well as a little on a 323s. I hated the 307 immediately, it sounded like a 404 and 303. In other words etch. The 407 and 507 were very close. Both sounded great with no etch at all. I felt there was more bass from the 507 also it felt a bit more detailed in transient notes. I would say if you are tight on money don't feel bad about the 407. It really is the best bang for the buck lambda and the sound quality is very similar to the 507. I have a small head ( I usually wore the old head band assembly as small as it would go) and the 507 feels great. My setting is 2 clicks above the smallest setting on the 507. Compared to the SC1 and LNS the 507 beats them both. Well time to get back to my 507s...
HeadphoneAddict Posted November 13, 2010 Report Posted November 13, 2010 Here are my impressions of the 307, 407, and 507 If you want the short version I bought the 507. Long version Take my impressions with a grain of salt as it was in a not totally quiet place. I went to my favorite Stax dealer here in Japan. I listened through a srm-600 and a srm-006TS, as well as a little on a 323s. I hated the 307 immediately, it sounded like a 404 and 303. In other words etch. The 407 and 507 were very close. Both sounded great with no etch at all. I felt there was more bass from the 507 also it felt a bit more detailed in transient notes. I would say if you are tight on money don't feel bad about the 407. It really is the best bang for the buck lambda and the sound quality is very similar to the 507. I have a small head ( I usually wore the old head band assembly as small as it would go) and the 507 feels great. My setting is 2 clicks above the smallest setting on the 507. Compared to the SC1 and LNS the 507 beats them both. Well time to get back to my 507s... Thanks for the impressions. Were all three amps acceptable sounding with the 407 and 507? Which did you prefer?
graben Posted November 14, 2010 Report Posted November 14, 2010 I preferred the srm-600 by a little bit but that may have just been psychological. Both earspeakers sounded great through all 3 amps.
