November 18, 20188 yr comment_798361 The KSE1500 with foam tips are amazing. Even in noisy environment, the noise isolation is just incredible. Edited November 18, 20188 yr by Mach3 Report
November 18, 20188 yr comment_798364 Yup, they are great on flights though a bit bulky. Crazy sensitive to the tips though... Report
November 20, 20188 yr comment_798480 So a WES is popping up for cheap on my radar, any minor/major modifications to get this thing sounding less H3 distortion and more cleaner with more power? @spritzer @kevin gilmore Edited November 20, 20188 yr by DefQon Report
November 20, 20188 yr comment_798494 1) Install 5 megohm safety resistor in the bias supply following the last bias cap if there isn't one or it is a different value. 2) Toss the output chokes and install good constant current loads with appropriate heatsinks. 3) Install 5 kilohm safety resistors in the output if there aren't any. If you are in the mood, put in a somewhat higher voltage transformer that will allow you to install a regulated power supply. That should fix the major issues, don't know if there are others. Edited November 20, 20188 yr by JimL Report
November 20, 20188 yr comment_798495 ...and redo the input stage as it is idiotic. The one I did with all the same tubes and simple resistor load for the outputs was quite good for a low cost project... Report
November 20, 20187 yr comment_798503 Sound like Weeeessss! For the amounts of work and modifications that one may have to pull to make something work properly....and if someone is already doing that, may as well going for KG high-end designs instead Report
November 20, 20187 yr comment_798508 If you're attached to an all tube design, well almost all, just build a Megatron? Edit:: speaking of woo has anyone seen what's going on inside their new stat amp? Edited November 20, 20187 yr by SeaWolf Meh Report
November 21, 20187 yr comment_798516 No pics of the new one that I'm aware of and no real impressions either. This being Woo I'm expecting the worst but it would be nice to be pleasantly surprised once in a while... ? Report
November 21, 20187 yr comment_798538 One can always hope... springs eternal and all that. The WES is a particular clusterfuck though as it didn't work on so many levels. It's a collection of 4 mono phase amps really so you need the super noisy phase splitter to the circuit for it to work with RCA inputs and then we have the inductor output loads which simply don't work. Add to that a really, really crappy power supply and all the usual Woo audio safety concerns. So back in the day, for those that are unfamiliar, there was some discussion that they were just doing the best they can or some such BS so I said...can I do better? I set some rules, same power supply voltages, same tubes naturally (though not the rectifiers as they are just stupid) and as similar a parts count and general topology as possible. So output caps like in the original, inter stage caps etc. Throw it all in a spare box and here it is: The massive tower was just something I had and as you can see... it is pretty much empty: The chassis was reused from a dac project our resident "circular hole cutter tech" did so extra holes galore and then it was powder coated to look nice. That's why it has only XLR loop outputs on the back. So here is the money shot... Sooooo...this is a small DC supply to run the heaters of the tubes and my SSPS (simple stacked PS) feeding +300/+600 plus bias to the amp. The amp it self is a combination of a modified SRX front end with a new grounded cathode output stage. That pic is from the first testing so there were some changes done later on but it worked well enough and about 1/4th the size of a WES... Report
November 21, 20187 yr comment_798541 23 hours ago, SeaWolf said: If you're attached to an all tube design, well almost all, just build a Megatron? Edit:: speaking of woo has anyone seen what's going on inside their new stat amp? Or, if you're cheap like me, build the SRX Plus. Based on an original Stax circuit, with constant current loads and sources to set the operating conditions. Report
November 22, 20187 yr comment_798564 Both options are good. If you have a tight budget, the SRX-P is a good candidate, I don´t think you will be disappointed. If you have money the Megatron is an incredible amplifier. Edited November 22, 20187 yr by jose Report
November 22, 20187 yr comment_798568 14 hours ago, JimL said: Or, if you're cheap like me, build the SRX Plus. Based on an original Stax circuit, with constant current loads and sources to set the operating conditions. It still costs something like $2k to commission an SRX plus build though... Report
November 22, 20187 yr comment_798587 8 hours ago, Tachikoma said: It still costs something like $2k to commission an SRX plus build though... Wow. It cost me less than $500 to build mine. Report
November 23, 20187 yr comment_798623 2K? ummm. It depends. Do you do it or do you order someone? I think mine, adding everything (cases, custom made trafos and bla, bla, bla...) remained around 1K€ (1.2K$) . I´m sure that if you are conservative and you reuse things like the case or use generic material like trafos, the cost can be quite minor. For this reason IMHO for a small budget, the SRX-P is a great project. Report
November 23, 20187 yr comment_798625 Order someone. In fairness, its understandable - time isn't free. Report
November 23, 20187 yr comment_798626 Ok .I supposed we were talking about doing it yourself (Mod a commercial amp vs DIY a SRX-P) Report
November 27, 20187 yr comment_798788 STAX announced new closed sealing covers and ear clips (eliminating the wire headband) for retro fitting existing SR-001mk2, SR-002 and SR-003/003mk2 IEMs. Supposedly the CES-A1 combo will be available in Japan mid-December. https://stax-international.com/products/ces-a1/ Edited November 27, 20187 yr by Laowei Report
November 28, 20187 yr comment_798842 yup bargain compared to this. https://www.ebay.com.au/itm/STAX-SR-Omega-1-Electrostatic-Headphones-One-of-a-kind/192736088566?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Ddca0e907a47e440a86b6d1d4d4db1198%26pid%3D100675%26rk%3D3%26rkt%3D15%26sd%3D302948944629%26itm%3D192736088566&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Aae159fd7-f30c-11e8-81c2-74dbd18059df%7Cparentrq%3A5a622a211670a99b5d686a2cfffe35cc%7Ciid%3A1 Guess I can kiss goodbye to ever owning one. Report
November 28, 20187 yr comment_798850 7 hours ago, Mach3 said: 55 Buck for some plastic clips? Where did that number come from? Report
November 28, 20187 yr comment_798861 6000 Yen is about that price. Throw in 20-30 buck for international delivery http://audioon.blog.jp/archives/1073265658.html Edited November 28, 20187 yr by Mach3 Report
