January 31, 201214 yr comment_494676 The energizers work from pretty much anything. I regularly use a 10W Class T amp (very optimistic 10W at that) when I can't be bothered to connect some of the "proper" amps and it sounds just fine. I must say though that I wasn't very impressed by the WEE. I just don't feel that it is a upgrade over the SRD-7's and I have a large question mark over the quality of the transformers used. Report
January 31, 201214 yr comment_494689 I agree about the Rwa audeze edition. I thought it sounded terrible with the lcd2 and the liquid fire is only mediorce for me with them. I have the lcd2 right now with a ba and it is a really good match so I am hoping that the lcd3 will be also. Should have them tomorrow so I guess I will find out. Report
January 31, 201214 yr comment_494695 I will admit, the thought of going energizer/stax and avoiding the quality control of Audeze is fairly appealing. So many failures on a $2000 product has added to my hesitancy in going ahead with an LCD3 rig. Report
February 1, 201214 yr comment_494837 As the owner of a RWA Isabella I can say I am very happy with how the HE6 and HE500 sound with it. Also the amp via a 30.2 drives the K1000 very nice but I believe (still testing) I prefer the balance out of the Isabella. Report
February 1, 201214 yr comment_494849 ...but is it any better than the >100$ amps you can buy with the same circuitry let alone something that is not a dirt cheap chip amp? That is the bigger question... Report
February 1, 201214 yr comment_494866 Actually RWA cases are pretty barebones in person. I'm sure hoping your not paying for casework in this instance! Report
February 1, 201214 yr Author comment_494884 You're paying for Vinnie's grocery bills. ... and his gold crowns Report
February 2, 201214 yr comment_495070 ...but is it any better than the >100$ amps you can buy with the same circuitry let alone something that is not a dirt cheap chip amp? That is the bigger question... You could be right, or perhaps not. Report
February 2, 201214 yr comment_495086 Got to get the review of the LCD-3 done. What amps should I use? Report
February 2, 201214 yr comment_495092 It would be nice to tell folks about the "back emf" and how that plays with certain circuits. I don't know, you could throw in high-ish end tube amp as a reference that the LCD's doesn't sound well with them. Report
February 2, 201214 yr comment_495099 About that back EMF: I see very little in the way of electrical signal phase change through the drivers, or impedance changes. How do we know there's a lot of back EMF from planars? Kevin? Report
February 2, 201214 yr comment_495109 I believe Birgir claimed there was a lot of back-EMF from these. Don't recall whether Kevin has said what he thinks or not... Don't forget to throw an O2 in there also Edited February 2, 201214 yr by Pars Report
February 2, 201214 yr comment_495112 Here's my interpretation of a back emf generated by a magnetic planar speaker: If you consider a planar magnetic headphone, it consists of a series of permanent magnets in some fixed configuration with a membrane suspended in between the magnets. On that membrane/diaphragm are circuit traces through which the current flows. As this current changes it induces a magnetic field (see ampere's law) that interacts with the fixed magnets and causes the daiphragm to move. However, it is important to also remember the dual of ampere's law, faraday's law, which states that a change in magnetic field will induce an electric field. I believe theoretically the magnetic fields due to the fixed magnets in a planar magnetic driver is supposed to be uniform, however obviously in real life this is not going to be completely true. Therefore as the traces on the diaphragm pass through areas of varying magnetic field strength an electric field ie. a back emf. As to the magnitude of the back emf I don't have a clue. Report
February 2, 201214 yr comment_495127 Tyll - Perhaps an ecp audio L-2 or an Anedio D2. Didn't see either of these listed over at IF - maybe you could kill two birds with one stone. Report
February 2, 201214 yr Author comment_495138 Tyll, FOTM = Dark Star and Liquid Fire Reference = β22 Controversy = O2 That's the way I'd play it... Report
February 2, 201214 yr comment_495140 As with everything in life, nothing is free so while we get ruler flat impedance from the planar drivers then we have to deal with the back emf instead. This has proved to be substantial enough to upset amps so it should certainly be taken into account. The ringing people are reporting with certain amps (OTL tube amps etc.) is caused by this to some extent. When Kevin got my LCD-2's he reported back that they needed current and not voltage (4V rms being way too loud) and I concurr, you need an amp which can deliver the ever so elusive current. Low output impedance is also a must which rules out most tube amps. High bias Class A solid state amps being the natural parter then. I'm getting good results with the Dynalo but a Dynahi should be even better, the new version even more so. Some good speaker amps wouldn't go amiss. Know anybody who owns a Pass XA-30.5? Report
