Audeze LCD-3
The energizers work from pretty much anything. I regularly use a 10W Class T amp (very optimistic 10W at that) when I can't be bothered to connect some of the "proper" amps and it sounds just fine. I must say though that I wasn't very impressed by the WEE. I just don't feel that it is a upgrade over the SRD-7's and I have a large question mark over the quality of the transformers used.
  • Replies 718
  • Views 193.8k
  • CarlSeibert
    CarlSeibert
    Wow. First off, thanks for reminding me that Debbie Harry was/is a major babe. Who can sing. I'll have to dig out an old LP or two. I liked her back in the day. Half a dozen pages ago, Grawk said t
  • Al, that one sentence posted on HeadFi would serve as both conclusive evidence and an act of war. Have (moar) fun!
  • Why are you dissing my wonderful collection of polka and 70's German porn music tracks? You are such a snob... We can at least agree that my 007's are a bit special given my OCD need to set them
Thanks. More things to think about...
I agree about the Rwa audeze edition. I thought it sounded terrible with the lcd2 and the liquid fire is only mediorce for me with them. I have the lcd2 right now with a ba and it is a really good match so I am hoping that the lcd3 will be also. Should have them tomorrow so I guess I will find out.
I will admit, the thought of going energizer/stax and avoiding the quality control of Audeze is fairly appealing. So many failures on a $2000 product has added to my hesitancy in going ahead with an LCD3 rig.
As the owner of a RWA Isabella I can say I am very happy with how the HE6 and HE500 sound with it. Also the amp via a 30.2 drives the K1000 very nice but I believe (still testing) I prefer the balance out of the Isabella.
...but is it any better than the >100$ amps you can buy with the same circuitry let alone something that is not a dirt cheap chip amp? That is the bigger question...
Actually RWA cases are pretty barebones in person. I'm sure hoping your not paying for casework in this instance!
You're paying for Vinnie's grocery bills.
It would be nice to tell folks about the "back emf" and how that plays with certain circuits. I don't know, you could throw in high-ish end tube amp as a reference that the LCD's doesn't sound well with them.
About that back EMF: I see very little in the way of electrical signal phase change through the drivers, or impedance changes. How do we know there's a lot of back EMF from planars? Kevin?
β22, GS-1, BA. This is Head Case after all.
I believe Birgir claimed there was a lot of back-EMF from these. Don't recall whether Kevin has said what he thinks or not...
Don't forget to throw an O2 in there also :rolleyes:
Edited by Pars
Here's my interpretation of a back emf generated by a magnetic planar speaker:
If you consider a planar magnetic headphone, it consists of a series of permanent magnets in some fixed configuration with a membrane suspended in between the magnets. On that membrane/diaphragm are circuit traces through which the current flows. As this current changes it induces a magnetic field (see ampere's law) that interacts with the fixed magnets and causes the daiphragm to move. However, it is important to also remember the dual of ampere's law, faraday's law, which states that a change in magnetic field will induce an electric field. I believe theoretically the magnetic fields due to the fixed magnets in a planar magnetic driver is supposed to be uniform, however obviously in real life this is not going to be completely true. Therefore as the traces on the diaphragm pass through areas of varying magnetic field strength an electric field ie. a back emf.
As to the magnitude of the back emf I don't have a clue.
Tyll - Perhaps an ecp audio L-2 or an Anedio D2.
Didn't see either of these listed over at IF - maybe you could kill two birds with one stone.
Tyll,
FOTM = Dark Star and Liquid Fire
Reference = β22
Controversy = O2
That's the way I'd play it...
As with everything in life, nothing is free so while we get ruler flat impedance from the planar drivers then we have to deal with the back emf instead. This has proved to be substantial enough to upset amps so it should certainly be taken into account. The ringing people are reporting with certain amps (OTL tube amps etc.) is caused by this to some extent. When Kevin got my LCD-2's he reported back that they needed current and not voltage (4V rms being way too loud) and I concurr, you need an amp which can deliver the ever so elusive current. Low output impedance is also a must which rules out most tube amps. High bias Class A solid state amps being the natural parter then. I'm getting good results with the Dynalo but a Dynahi should be even better, the new version even more so. Some good speaker amps wouldn't go amiss. Know anybody who owns a Pass XA-30.5?
