- Past hour
Farus60 joined the community
- Today
^^ this. I had it high in my queue and your post pushed it forward. Not an easy listen. Not that it is not really good. It is pretty great. But it is not for the faint of heart. There are a lot of notes, and they are not in the order that I would expect. But listening deeply there are themes and phrases that emerge that are very rewarding. And some tunes that are absolutely beautiful. Well recorded and minimizes the Jarrett mumble. Side note - last week when I had a friend visiting, I tried to explain - The Köln Concert - It was hard with someone that does not listen to jazz and had never heard of it before.
sorenb replied to kevin gilmore's topic in Do It Yourself
Maybe harder than you anticipate Recently I was sent a not working Blue Hawaii BJT. Turns out the PSU PCB is a clone of Kevins layout ... just flipped upside down, with components firmly mounted on top of the traces ...a year down the road, it went boom, with lifted traces and some literally burned totally. @kevin gilmore has been kind and provided a modified version of his layout to match the mounting studs in the chassis. -
I'd use 300b or 2A3 tubes as load be aware that NOS tubes may have different results from new production tubes -
Armir747 joined the community
Good news: It works! Measured output is 4.9V for the 5V setting, 6.1V for 6.3V, and spot-on 2.5V for the 2.5V setting. I haven’t tested the soft-start function yet — if anyone has good suggestions on how to choose a suitable load resistor for testing, I’m all ears. Bad news: I spent two days figuring out how to hand-solder with a heat pad and heat gun the QFN package. Even when using a stencil, too much paste tends to remain on the pads, which makes them very prone to shorting. As a result, I ended up ruining two boards and some components. At this point, I really don’t feel like assembling the remaining three boards myself. I think it’s best to leave the rest to a proper assembly house.
simmconn replied to kevin gilmore's topic in Do It Yourself
It’s not hard to do a 1:1 clone of the PCB. It’s also a great interview question for a junior electrical engineer to come up with a circuit that does this. However not a lot of them would probably know how a vacuum tube filament/heater behaves. -
- Yesterday
Today ... https://bonair.com/brits/ Lucas electrics has no power here, so here are a few of those that made it.
- 2,075 replies
- 2
- Golf Mafia
- M Sport
(and 1 more)
Tagged with:
Personal History by Mary Chapin Carpenter (2025) https://album.link/gtnmzvcxr3szp Example: Warm and sometimes brooding. A set of tunes from one that seems to know who they are and where they are in their life.
The Blue Nile - A Walk Across the Rooftops Shpongle - Codex VI
cozycactus joined the community
- Last week
Yeah Yeah another Rick Video - but I had never heard the isolated tracks before - pretty darn cool.
MisakaMikoto joined the community
It's impressive. Art is subjective. This piece, especially. https://sfstandard.com/2025/04/20/naked-lady-sculpture-sf/ https://sfstandard.com/2025/04/20/naked-lady-sculpture-sf/
Does the new sculpture look better in person?
Hello Friends, a nice family shot with no load, no current limitation. Have to figure out why the bias doesn't kick in at 580V, otherwise quite happy. Edit, discovered it's the dmm impedance, bias is just right 👍
That was fast! Thanks a lot. -
Find it. I will share the info here anyway if you are curious. The switching freq range is between 900 to 2400(kHz). Lower than the LMQ, but shouldn't have any problems. https://www.ti.com/product/TPS62913
I don't what chip it is. Marking might be???? Very hard to see. 26QH 288 A3HL Including in curcuit is also dual comparator 2093B and .05R sense resistor. Good luck and looking forward a report.
