This stream auto-updates
  1. Today
  2. GoGo Penguin "Necessary Fictions" The interplay between the drummers of GoGo Penguin and Mammal Hands is fascinating: Rob Turner, Jesse Barrett and Jon Scott. I consider all three drummers to be great, with fantastic sounds and grooves that give both trios a lot of character. I love the tracks where they play syncopated rhythms... microtextures or simply seem to be off-beat before returning to the correct tempo.
  3. Agreed. This year is such a disaster that they did something they've never done and changed the rules mid season. I'll keep my expectations low but we'll see.
  4. In preparation for Forza Horizon 6:
  5. Yesterday
  6. Good Lord. He's the Akakichi no Eleven meme come to life.
  7. Punch Brothers just dropped a new track. New album out at the end of the week. This track really features new member (I am a fan) Brittany Haas on fiddle. Edit: oops I meant to drop this in the Video thread, oh well, leaving it.
  8. Impressive.
  9. I am smitten -- this is gorgeous, right up there with Ólafur Arnalds. Thank you for sharing.
  10. Yesterday: Finally had a clear "two person" day, so Out with the Old. Well 💩, that explains a lot. No time to tilt the the house, so In with the New: Good enough for one day. I must say using a laser level is a game changer ensuring that things are level and line up, even if the building is out of true. Just remember: And then today, some finishing touches, and cable management. And then finally voice automation. Because: Of course. Some non ideal / contrived syntax commands because: reasons, but that's balkanized home automation. Looks nice though (Marin OLED 2 time club)
  11. I've always been a fan, but jiminy, this 1 minute is sublime.
  12. ❤️ Belated Happy Piano Day ∞ ∞
  13. new to me. Pretty melodies plus soundscapes.
  14. Last week
  15. Join Ternus has a chin for the ages.
  16. Tim Apple stepping down to be replaced by John Temu. Oh, sorry! I don't have my reading glasses on. that's John Ternus.
  17. I discovered them in January... I like the drums, but I admit I still find it hard to listen to them.
  18. Skooby somwehere back in the thread. This is a nice sturdy box using it as heatsink is a good idea.
  19. Patio Brunch
  20. For Dada, Puzzle is their definitive album (albeit in a pretty short career) and would be my recommended next album listen
  21. knock your socks off.
  22. Also, I have been thinking about doing a revised layout for this amp, but adding some things such as Kevin's protector board, and possibly adapting the circuit used by nwavguy in the o2 for battery management to delay startup until the 2 Meanwell bricks had both come up, since this is what is causing the large DC offsets at startup (and possibly at shutdown as well). I know the protect board would take care of the startup issue so might be overkill for the additional circuit. The board would have to be larger in size to accommodate these changes, which should also have some benefits thermally. Large heatsinks for both the Amb regs and the onboard regs would also be a good idea. This is just at concept phase right now, and I'm not really interested in on for myself, but might do it anyway. If so, I will ask Kevin for permission to use his protect board circuitry for this.
  23. I know there isn't much interest in these amps anymore, but wanted to post my findings regarding thermals. I spent around 3 hours yesterday testing the one I have in for repair to evaluate whether these run cooler with no heatsink, heatsink only, or heatsink with a spreader bar to tie it to the top cover. @johnwmclean had at one point suggested that he thought these might run cooler without. I forget which user suggested and implemented a spreader bar, which for them resulted in lower temps. I used a thermocouple with the covers on to do this test. For the 1st case (no HS), I put the thermocouple on top of the upper right transistor in the L- channel. For the other two tests, the thermocouple was touching the collector tab. I tried to wait long enough for things to stabilize completely, which never really happened. Even after an hour or more, the temp would go up 0.1 ºC every minute or so. Here are the results: bare 91.8 (shortest test, around 45 minutes) HS only 92.6 (approx 1 hour +) HS w/spreader 87.1 (1 hr 20 min) all temps in ºC. Ambient temp 22.1 ºC. It appears that w/spreader is the winner. That temp was going up slower than the other two, so I would guess that the margin is a bit larger. i made the spreader with a couple of pieces of 1/8" and 1/16" thick aluminum x 1" stock.
  24. Got the Cervelo back out on the road on one of our few sunny spring days so far. It was windy, but still a nice rip around town.
  1. Load more activity
