- Today
- AnTek transformers are made in China.
- Yesterday
I know I've posted this before, but I was just forced to revisit it, and it's just as much an earworm as it ever was- AnTek transformers are made in China.
I don't think they ever hid that they were made in China but they are great transformers. Very consistent in quality which is hard to come by these days. Plus they oversize all of the cores so they run cooler and with less chance of any nasty behavior. As somebody that has ordered transformers in bulk from China, they stop being cheap very quickly once you ask for some proper specs or even worse... actual bloody copper in them.- The Knuckledragger 3rd Memorial Slow Forum Post
I love this album.. Eddy Grant "killer on the rampage"- AnTek transformers are made in China.
- The Live Music Thread
Listened to a couple tracks -- this is great! Thanks for turning me on to them. Music on TIDALDakhaBrakhaSee the releases of DakhaBrakha on TIDALMusic on TIDALДахаБрахаSee the releases of ДахаБраха on TIDAL- Songs You Came Across On Some Streaming Service And Thought Your Head-Case Buds Might Enjoy Too. No Critical Endorsement Implied. Fuck Vevo etc.
Well that's too bad. For reference, my hearing damage is bad enough that I can't tell the difference than when it's just my hearing. At least shoegaze still sounds like shoegaze.- The Knuckledragger 3rd Memorial Slow Forum Post
This is a not so funny incident locally around 10-15 years ago, where an elderly lady put the car in reverse instead of forward, and pushed the pedal. Shot back and pinned someone by the legs against a brick wall. Life changing injuries.- The Official Head-Case Photography Thread.
I wasn’t able to photograph the "buck moon" earlier because of the heat and heavy dust in the air. But this weekend, the conditions cleared up, and I managed to capture something. I’m happy that the different colors on the surface are visible. PD. Until they install fiber optic cable at my house in the South, my internet access is limited, and I can’t connect very often.- The Live Music Thread
DakhaBrakha....holy shitballs were they great! Highest recommendation! Great musicianship, and a massive connection with the audience (they played a small space in Portsmouth NH, they've played here before and a good chunk of the audience had seen them before). I didn't know they did this, but they auctioned off two paintings (and a pair of drumsticks) to benefit Ukraine. I won one of the paintings, and got backstage for a pic with the band and to tell them of my partial Ukrainian heritage! A wonderful night, filled my heart!- Songs You Came Across On Some Streaming Service And Thought Your Head-Case Buds Might Enjoy Too. No Critical Endorsement Implied. Fuck Vevo etc.
I dunno, maybe. Appreciate the concern, but some of my faves were struggles initially, so I at least want to semi-understand, before dismissing. The vocals, so prevalent, feel like syrup on everything at this point. And I love My Life in the Bush of Ghosts and most of Sigur Rós. Anyway, easier to swallow, except requiring stamina... Bill Evans, Last Waltz (the last concert).- The Knuckledragger 3rd Memorial Slow Forum Post
- Last week
^^ interesting. I like the tune. I have the new album in my queue, but have not touched it yet. -- So, I listened to 'petal', and it was coming off strange on my headphones. Like it was over driven, sounding like woofer buzz. I have had this before by actually overdriving speakers. So I checked out the first track 'kiss me' and it had some of the same qualities. I double checked by pushing these through my emotivas a bit and yep it sounds like they made a choice. Engineered by Lou Carrao with Max Martin all over the place on the album. Maybe they think it is a 'raw' sound, but it just sounds muddy to me. Regardless I do like the song itself, self actualizing and pissed. It has not turned me off of the album, I will probably listen and report in the other thread. thanks Dusty.- Songs You Came Across On Some Streaming Service And Thought Your Head-Case Buds Might Enjoy Too. No Critical Endorsement Implied. Fuck Vevo etc.
Goes hard 🙃- AnTek transformers are made in China.
- Post what you're watching
Before Psychedelia, There Was SPACE AGE Music- The ultimate DIY? A Stax SRM-T2!
Both the power supply and amplifier chassis are approximately 290 mm × 400 mm × 90 mm, so it's actually fairly compact considering it's a full-size T2. The power supply uses five GRHV regulators and features plug-in bias daughter boards, making it easy to switch between different bias voltages. Right now it supports both Normal Bias and Pro Bias outputs. The PSU also includes about a 50sec high volt soft start. In addition, there's an AC inrush limiter on the mains input. After roughly one second, a relay bypasses the current-limiting resistor, reducing the inrush current seen by both the filter capacitors and the tube heaters during startup. On the amplifier side, most of the passive components are SMD, which helped reduce the overall PCB and chassis size. The amplifier topology stays very close to Kevin's original T2 schematic, but I added support for several different implementation options to make the design more flexible. It supports three different CCS configurations:10M90, 10M90S + DN2540, and the original T2 complex CCS. The active battery section is also configurable. It supports: LED string reference, LT1021 reference. For the 2SK216 and 2SJ79 positions, I added an extra pin so they can be replaced directly with TTC and TTA devices without modifying the PCB. The overall goal wasn't to redesign the T2, but rather to preserve the original circuit while making it easier to build, maintain, and adapt as some of the original parts become increasingly difficult to source. The chassis is CNC machined by a local machine shop. One detail I paid particular attention to was the top cover of the amplifier chassis. I designed it so that the EL34 tube sockets sit perfectly flush with the top panel, which I think gives the amplifier a much cleaner appearance. Additional ventilation slots were added in the center section for airflow. The side heatsinks are sandwiched between the top and bottom panels. This not only gives the chassis a cleaner look and prevents the sharp heatsink fins from being exposed, but also makes it much less likely that you'll scratch your hands when moving the amplifier. To make sure the heatsinks can still dissipate heat efficiently, I also added ventilation openings in the top and bottom panels wherever they cover the heatsinks. I've also been thinking about turning this project into a group buy, although I'm not sure how much interest in the T2 still exists today. The main motivation would be to reduce the chassis cost, since having a single custom CNC chassis made is quite expensive. If enough people were interested, the machining cost could come down significantly.- AnTek transformers are made in China.
AnTek transformers are made in China. I purchased the AS‑4T400 (400VA, 400V) transformer and the AS‑3T350 (300VA, 350V) tube transformer to build the Blue Hawaii and Carbon amps. The cardboard packaging had “Made in China” labels, and some of them were partially peeled off. If I had known they were made in China, I might have bought them directly from Taobao.- Which Cooking Are You?
So Saturday we smoked spare ribs and a brisket in our new smoker This was early in the smoking before the ribs were sauced and wrapped in aluminum foil and before the brisket was swaddled in butcher paper.- Analysis
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
