shellylh Posted December 16, 2011 Report Posted December 16, 2011 I have a friend who asked me a headphone question that I couldn't answer. He has a pair of Ety ER4P and recently got shocked in the ear while wearing them (he was walking and was wearing a fleece if that is relevant). I haven't ever experienced this myself. Is this not abnormal or should he contact Etymotic about it? Sounds painful.
skullguise Posted December 16, 2011 Report Posted December 16, 2011 If no loose wires, I think it could be just a nasty static electricity shock?? The fleece note made me thing of that....
RudeWolf Posted December 16, 2011 Report Posted December 16, 2011 I'm not sure if the current needed to drive dynamic let alone IEM type headphones is sufficient to cause an electric shock in an ear. Hmm... Maybe he experienced some kind of a static electricity discharge?
mikeymad Posted December 16, 2011 Report Posted December 16, 2011 hmmm never heard of it shelly... I have been using my er4s for about 5 years now... I seem to be okay ..
Torpedo Posted December 16, 2011 Report Posted December 16, 2011 It probably was static electricity, I've had some of those shocks using the PS-1 and other cans, but never with IEM.
shellylh Posted December 16, 2011 Author Report Posted December 16, 2011 I seem to be okay .. That is debatable. :evil: That (static electricity) is what I thought. With a quick search, I did find something at HF on it but didn't know whether to trust the OP. http://www.head-fi.org/t/310723/fyi-basic-guide-to-in-ear-canalphones-rev-4 "10. Static Electricity Discharge through IEM It is possible to experience a static electricity discharge though IEMs. In a cold climate with low humidity, a static charge may build up on one's body. The cable that carries the audio signal from the headphone jack to the IEM has metallic wire inside. This wire is also a path to ground through which the static charge can travel. Though one's ears are touching the plastic parts of the IEM, there is metallic wire inside. A static charge often has a high enough voltage to leap from one's ear to the metal inside of the IEM, discharging the static electricity via the cable and into the device playing the audio signal, e.g., CD player or MP3 player. The amount of electrical current in such a static discharge is not harmful, though the discharge itself can be startling. It is important to note that such static discharges are "acts of nature" and do not indicate that one's IEMs are defective, nor will the static discharge cause harm to the IEM. Note: If you are regularly shocked by your headphone, it could indicate a leakage in the wiring. You should contact the manufacturer for repair in such a case."
swt61 Posted December 16, 2011 Report Posted December 16, 2011 In Alaska, during winter it wasn't uncommon for my earbud cables to rub against my polar fleece jacket lining, and give a static shock. Just one of those things you get used to in a dry climate.
Duggeh Posted December 16, 2011 Report Posted December 16, 2011 As someone more in the wet, I've worn my Etys in driving solid horizontal rain and never had a shock from them.
justin Posted December 17, 2011 Report Posted December 17, 2011 rain would make it less likely to occur.
Duggeh Posted December 17, 2011 Report Posted December 17, 2011 (edited) Static shock yes. Shorting something out, maybe not? I also wore the SR-001 in heavy rain and they didn't suffer. Edited December 17, 2011 by Duggeh
Wmcmanus Posted December 17, 2011 Report Posted December 17, 2011 Sure he's not just being a drama queen?
kirkwall Posted December 17, 2011 Report Posted December 17, 2011 (edited) In Alaska, during winter it wasn't uncommon for my earbud cables to rub against my polar fleece jacket lining, and give a static shock. Just one of those things you get used to in a dry climate. I've had that too. This week, in fact, while pretending to jog in -18 C. Teach me to exercise in anything but the finest weather. No noticeable effect on the Shures I was wearing. k Edited December 17, 2011 by kirkwall
Tyll Hertsens Posted December 17, 2011 Report Posted December 17, 2011 I've had that too. This week, in fact, while pretending to job in -18 C. Teach me to exercise in anything but the finest weather. No noticeable effect on the Shures I was wearing. k Yup. Me three. Its dry up here in Montana, happens all the time. Not with IEMs that I can recall, but woulnt be surprised.
bhjazz Posted December 22, 2011 Report Posted December 22, 2011 rain would make it less likely to occur. which explains why I've never experienced this in Seattle.
CarlSeibert Posted December 22, 2011 Report Posted December 22, 2011 I'm going with static discharge. That I've never heard of such a thing in south Florida only makes it more plausible. I've experienced some nerve misfire sorts of sensations that have felt like shocks, but they were in big muscles (Well, not that I have big muscles. It's relative.) This doesn't sound like that.
