June 25, 201313 yr I use Pedro's Ice Wax as well. Got it cheap off Chainlove. I use another Pedro's wax but I can't remember which. It's more viscous and I basically use it to clean the chain more than anything else. But generally I'm pretty lazy with chain maintenance.
June 25, 201313 yr There was a good article on the various types of lubes and their effectiveness in Velo magazine. Here's a link to the preamble to the article but I may still have a copy at home I can scan. http://velonews.competitor.com/2013/02/bikes-and-tech/six-watts-from-lube-boulder-lab-separates-fact-from-friction-fiction_264446 The finding was though that parrafin wax was best though you do have to take the chain off and soak it in it. Of the ones that wasn't a giant PITA I believe Pedro's Ice Wax was one of the best. I use both Pedros Ice and Pro Gold. I guess I should just switch to only Pedros. Edit: You can also get it free here (though I think you have to make an account): http://www.friction-facts.com/test-results/free-reports/chain-lube-test Interesting article! I am most concerned with maximum chain life, which though hinted at here, isn't directly measured. The Chain'l seemed to perform middle of the pack in terms of efficiency, and is not really dirtier than other lubes I've used after a few hundred miles. I've never tried any of the dry lubes, and might just for the hell of it, particularly one which has a lot of PFTE in it.
June 25, 201313 yr Paging Mike - ~58CM Calfee w/ a short top tube. http://forums.thepaceline.net/showthread.php?t=131858
June 25, 201313 yr The HT is 15mm taller. The TT is 2cm longer. The ST is about right. The HA on the Gunnar is 72. Any thoughts on whether it could work?
June 25, 201313 yr I'm useless to you for that type of judgement, I just saw a shortish TT and thought of you.
June 26, 201313 yr Wow that's a very tall head tube. I thought the Gunnar had a tall one until I saw this one.
June 26, 201313 yr Marshall, have you tried wiping the chain down lightly with a rag with a solvent (mineral spirits) on it? The lube only needs to be in the rollers, anything else is unnecessary. You are applying a drop to each roller, then wiping it down after it has had time to soak in, aren't you? Yep, I usually wipe it down with a solvent soaked rag after a ride and then apply more lube, let it soak for a few minutes, take the bike for a quick spin around the block and then wipe it down the drive train with a clean, dry rag and then wipe it down with a solvent soaked rag again before riding it. With it being as dry as it was the dust on the Kal-haven trail was like really, really fine cement dust and even the tires get caked with it. Last night's storms will help matters for a few days but....... There was a good article on the various types of lubes and their effectiveness in Velo magazine. Here's a link to the preamble to the article but I may still have a copy at home I can scan. http://velonews.comp...-fiction_264446 Good read, thanks for sharing it. Edited June 26, 201313 yr by Mister X
June 26, 201313 yr Mike, I'd say it is likely a pass based on what I see so far. You would likely need to put on a pretty short and negative angle stem to get the HB close to where they should be. Are you running any spacers etc now? Raffy I think the HT on my frame is 24cm I don't have my ordering spreadsheet with me. That said it's also a much larger frame. Edited June 26, 201313 yr by Dreadhead
June 26, 201313 yr Wow that's a very tall head tube. I thought the Gunnar had a tall one until I saw this one. Raffy, Bear in mind that the HT on my Roubaix (a 58cm frame) is 225mm.
June 26, 201313 yr I figured but you and Chris are at least a foot taller than me so that makes sense My puny 125mm HT is too tall for me.
June 26, 201313 yr Chris, thanks. I am going to pass. I am comfortable on the Gunnar, no need to try to make something built for someone else fit me. Thanks for the heads up Nate. One of these days, I'll find one that fits.
June 26, 201313 yr I'm eyeing a bike purchase for my 40th birthday, probably a custom of some sort, maybe a Calfee. I've got a few years to mull it over.
June 26, 201313 yr I think I will wait the just over 7 years for my next bike purchase, when I turn 60.
June 26, 201313 yr I'm gonna have to turn tricks to fund my next bike purchase. Anyone now a good sugar momma around here?
June 26, 201313 yr Yes, I need to be less picky with my clientele moving forward. Why do you think I'm trying hard to get into great shape?
June 27, 201313 yr Mike, as much as I am afraid of going Campy ... I've always thought of you as somewhat campy Raffy.
June 27, 201313 yr Author I think I will wait the just over 7 years for my next bike purchase, when I turn 60. You do have a birthday coming up this week, right? So glad you're older than I am.
June 27, 201313 yr Picked up Assos UNO bibs and 2 pairs of Assos socks for $163 shipped from Ribble. That's about $50 less than what I would have paid at the LBS just for the bibs. And the LBS's wonder why a lot us go online to but stuff? No shit Sherlock! Edited June 27, 201313 yr by raffy
June 27, 201313 yr BTW, Giordana Silverline Bibs at Competitive Cyclist for $42. Only XX-Large left though. Paging Nate.......
June 27, 201313 yr The sizing chart says XXL fits like a 40-44" waist. Just how fat do you think I am?!?!
June 27, 201313 yr The sizing chart says XXL fits like a 40-44" waist. Just how fat do you think I am?!?! I think he was going with XtraXtraLong... If only they had XL Women's, I'd be all over that. **BRENT**
