n_maher Posted June 25, 2013 Report Posted June 25, 2013 I use Pedro's Ice Wax as well. Got it cheap off Chainlove. I use another Pedro's wax but I can't remember which. It's more viscous and I basically use it to clean the chain more than anything else. But generally I'm pretty lazy with chain maintenance.
Pars Posted June 25, 2013 Report Posted June 25, 2013 There was a good article on the various types of lubes and their effectiveness in Velo magazine. Here's a link to the preamble to the article but I may still have a copy at home I can scan. http://velonews.competitor.com/2013/02/bikes-and-tech/six-watts-from-lube-boulder-lab-separates-fact-from-friction-fiction_264446 The finding was though that parrafin wax was best though you do have to take the chain off and soak it in it. Of the ones that wasn't a giant PITA I believe Pedro's Ice Wax was one of the best. I use both Pedros Ice and Pro Gold. I guess I should just switch to only Pedros. Edit: You can also get it free here (though I think you have to make an account): http://www.friction-facts.com/test-results/free-reports/chain-lube-test Interesting article! I am most concerned with maximum chain life, which though hinted at here, isn't directly measured. The Chain'l seemed to perform middle of the pack in terms of efficiency, and is not really dirtier than other lubes I've used after a few hundred miles. I've never tried any of the dry lubes, and might just for the hell of it, particularly one which has a lot of PFTE in it.
n_maher Posted June 25, 2013 Report Posted June 25, 2013 Paging Mike - ~58CM Calfee w/ a short top tube. http://forums.thepaceline.net/showthread.php?t=131858
tyrion Posted June 25, 2013 Report Posted June 25, 2013 The HT is 15mm taller. The TT is 2cm longer. The ST is about right. The HA on the Gunnar is 72. Any thoughts on whether it could work?
n_maher Posted June 25, 2013 Report Posted June 25, 2013 I'm useless to you for that type of judgement, I just saw a shortish TT and thought of you.
raffy Posted June 26, 2013 Report Posted June 26, 2013 Wow that's a very tall head tube. I thought the Gunnar had a tall one until I saw this one.
Mister X Posted June 26, 2013 Report Posted June 26, 2013 (edited) Marshall, have you tried wiping the chain down lightly with a rag with a solvent (mineral spirits) on it? The lube only needs to be in the rollers, anything else is unnecessary. You are applying a drop to each roller, then wiping it down after it has had time to soak in, aren't you? Yep, I usually wipe it down with a solvent soaked rag after a ride and then apply more lube, let it soak for a few minutes, take the bike for a quick spin around the block and then wipe it down the drive train with a clean, dry rag and then wipe it down with a solvent soaked rag again before riding it. With it being as dry as it was the dust on the Kal-haven trail was like really, really fine cement dust and even the tires get caked with it. Last night's storms will help matters for a few days but....... There was a good article on the various types of lubes and their effectiveness in Velo magazine. Here's a link to the preamble to the article but I may still have a copy at home I can scan. http://velonews.comp...-fiction_264446 Good read, thanks for sharing it. Edited June 26, 2013 by Mister X
Dreadhead Posted June 26, 2013 Report Posted June 26, 2013 (edited) Mike, I'd say it is likely a pass based on what I see so far. You would likely need to put on a pretty short and negative angle stem to get the HB close to where they should be. Are you running any spacers etc now? Raffy I think the HT on my frame is 24cm I don't have my ordering spreadsheet with me. That said it's also a much larger frame. Edited June 26, 2013 by Dreadhead
n_maher Posted June 26, 2013 Report Posted June 26, 2013 Wow that's a very tall head tube. I thought the Gunnar had a tall one until I saw this one. Raffy, Bear in mind that the HT on my Roubaix (a 58cm frame) is 225mm.
raffy Posted June 26, 2013 Report Posted June 26, 2013 I figured but you and Chris are at least a foot taller than me so that makes sense My puny 125mm HT is too tall for me.
tyrion Posted June 26, 2013 Report Posted June 26, 2013 Chris, thanks. I am going to pass. I am comfortable on the Gunnar, no need to try to make something built for someone else fit me. Thanks for the heads up Nate. One of these days, I'll find one that fits.
n_maher Posted June 26, 2013 Report Posted June 26, 2013 I'm eyeing a bike purchase for my 40th birthday, probably a custom of some sort, maybe a Calfee. I've got a few years to mull it over.
tyrion Posted June 26, 2013 Report Posted June 26, 2013 I think I will wait the just over 7 years for my next bike purchase, when I turn 60.
raffy Posted June 26, 2013 Report Posted June 26, 2013 I'm gonna have to turn tricks to fund my next bike purchase. Anyone now a good sugar momma around here?
raffy Posted June 26, 2013 Report Posted June 26, 2013 Yes, I need to be less picky with my clientele moving forward. Why do you think I'm trying hard to get into great shape?
swt61 Posted June 27, 2013 Report Posted June 27, 2013 Mike, as much as I am afraid of going Campy ... I've always thought of you as somewhat campy Raffy.
boomana Posted June 27, 2013 Author Report Posted June 27, 2013 I think I will wait the just over 7 years for my next bike purchase, when I turn 60. You do have a birthday coming up this week, right? So glad you're older than I am. 1
raffy Posted June 27, 2013 Report Posted June 27, 2013 (edited) Picked up Assos UNO bibs and 2 pairs of Assos socks for $163 shipped from Ribble. That's about $50 less than what I would have paid at the LBS just for the bibs. And the LBS's wonder why a lot us go online to but stuff? No shit Sherlock! Edited June 27, 2013 by raffy
raffy Posted June 27, 2013 Report Posted June 27, 2013 BTW, Giordana Silverline Bibs at Competitive Cyclist for $42. Only XX-Large left though. Paging Nate.......
n_maher Posted June 27, 2013 Report Posted June 27, 2013 The sizing chart says XXL fits like a 40-44" waist. Just how fat do you think I am?!?!
MexicanDragon Posted June 27, 2013 Report Posted June 27, 2013 The sizing chart says XXL fits like a 40-44" waist. Just how fat do you think I am?!?! I think he was going with XtraXtraLong... If only they had XL Women's, I'd be all over that. **BRENT**
