Forum Upgrade to Version 3.4
Oops, that is what I meant.
I just tried it again and it worked fine (didn't redirect to url4short.info) but went to head-case.  Has anyone else run into this?
  • Replies 122
  • Views 37.6k
  • Updated version of tapatalk installed, this should fix the existing issues with it and the new forum software version.
  • What was the exact search phrase you used?  Want to see if there is anything to do this.   Actually I'm seeing this now - will investigate.   EDIT - This issue is now resolved.  Please let me know
  • Is it just me or are "Likes" not showing up on posts any more...my Tapatalk notified me of a like, but I went to the post and couldn't see it...
I use Firefox and all the post controls are greyed out. You can still post images using {img} ... {/img} with regular brackets
When you see the post controls greyed out - do you see the first button - the BBCode one?  Make sure it's switched on.  If that's not the issue could you take a screenshot of what you are seeing?
Todd,
BBCode is turned on for me (links work, text options work) it's just the image dialog box that crashes.  I'm going to chalk this up to being on what is largely considered to be an unsupported browser and just use the [img*] tags at work.
Maybe this has been said already, but whenever I switch to the black theme it reverts back to the white theme after a while.
Yeah, it's doing this to me now, too. Don't know about the logout part, I don't logout. But when I close the window, and come back, and open a tab into head-case, it's white again. And the bottom left hand corner is slightly different -- instead of just having a single "Change Theme" button, it has a thing that says click to change manually, and when I click it, it refreshes with the InfiniteDark theme.
That's due to some changes I made to help mitigate the issue of people getting stuck on the mobile version.  Based on browser it should to force you to the default theme.  Still waiting on an updated version of infinitedark anyways.
The issue that was keeping people stuck on the mobile theme has now been fixed.  Due to this I've also removed some of the changes I made that may have interfered with anyone trying to use the Infinite Dark theme.  I'm still waiting on an updated version of the Infinite Dark theme so don't be surprised if everything doesn't work correctly with it.
Tapatalk released an update I believe on the client side and it's still broken here at Head-Case.
Todd, just curious, do you have statistics on the popularity of various User-Agents on Head-Case?
I wonder if I can post from None Moar Black...
EDIT:  Apparently so.
Edited by Voltron
i've been able to post on the pc, but not the mac (regular retina distiller mode) in chrome until yesterday / this morning (most recent time i tried)
will try out dark theme on it tonight, but dark is working in xp chrome for me now
Edited by aardvark baguette
Still waiting on a server side update to Tapatalk, the new version is supposedly in testing now so hopefully the wait won't be too much longer.
I actually do have quite a bit of data on user-agents and all that fun stuff (thanks Google Analytics!):
Device Type:
Desktop:  82.6%
Mobile (includes Tablets): 17.3%
OS:
Windows: 58.17%
Mac OS X:  22.06%
iOS:  13.44%
Android:  3.78%
Browsers:
Chrome:  31.31%
Safari:  25.42%
Firefox:  25.17%
IE:  12.30%
Still seems broken in tapa talk. Could see grawks post in latest thread header, but don't see it in the thread itself. The web view is OK, though. Sent from my Nexus 7 using Tapatalk 2
