DIY cable gallery
  • Replies 606
  • Views 264.4k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
Not the prettiest things, but function over form I guess.. :>
I really need to learn how to braid, braided cables look just amazing.
Banged out some quick and dirty mini/RCA cables last night to use with my Headroom Millett.
Components:
Neutrik NYS231B Mini Plug
Canare L-4E6S Mic Cable
Radioshack Heatshrink *bling*
Canare F-09 RCAs
Total Construction Cost = $10 and will nuke any Monster mini/RCA cable :)
Sound pretty good so far.
Nate
Nate, for "bangin'" those out, they look pretty damn good...
Also, do you have a clear heatshrink over the two channels after they split?
(or do I have to clean my monitor...)
I made these cables using Belden 89207 wire and Eichmann Gold Bullet Plugs. Not the best photos in the world but the cables actually sound pretty good.
Thanks man, they took about 45 min. each to build so either I'm getting better at cables or my standards are getting lower ;D.
On the blue / blue-white cable one pair is in fact covered with clear shrink. I was just messing with the different types/colors that I had on hand since I didn't really care how they looked. So that cable has blue shrink on one side, clear on the other. As far as lessons learned goes I don't think I'll be using the clear any time soon as a single layer cover. The stuff that I have is very thin and I don't think it'll stand the test of time very well. In comparison the red, white and blue that I used on the other parts of the cable is quite nice.
Nate
20awg Teflon coated copper Senn cable for my Balanced Reference due in Friday... just in time for my to leave for Spring Break :(
Sleeving is Reflexive flex for the main part of the cable and Carbon look flex for the ysplits. I used a barrel of a mini plugs for the ysplit to the XLR connectors. I opted to not use one on the Senn connector end to cut down on bulk and weight. Oh and its litz braided...
th_EASennXLR5.jpg th_EASennXLR4.jpg th_EASennXLR3.jpg th_EASennXLR2.jpg th_EASennXLR.jpg
Oyaide plugs with VH audio wire and reflexive flex.
maybe i should get a set of acrolink plugs in the future and make some crazy ass DIY power cords.
Plugs: Eichmann Gold Bullets w/ cable reducers and Neutrick black/gold mini
Wire: Pure Teflon coated silver and pure Teflon coated copper hybrid
Sleeving: Clear Reflexive
KSC35s with Pure Teflon coated silver and pure Teflon coated copper hybrid recable.
That cable looks familar. ;D
Very kick ass cable btw.
  • 4 months later...
  • 4 weeks later...
