November 24, 20241 yr comment_950518 It looks like the NC pins of the relay on the board are floating. I wonder if tying these to ground would take care of it? Report
November 24, 20241 yr comment_950519 53 minutes ago, Pars said: It looks like the NC pins of the relay on the board are floating. I wonder if tying these to ground would take care of it? If that were the case though, I'd get thump on headphones too, no? No thump with headphones or speakers, just the sub. Common denominator is the sub out is only thing that has a reference to PS Gnd. Voltage divider for the sub out is: +out > 10k > 1k to PS Gnd. Sub out taken from junction of 10k and 1k. Report
November 27, 20241 yr comment_950563 Can anyone help me? Some resistors in the schematic are 600R and 680R, while the 1.22 Gerber file is 300R and 600R. Some resistors are 4.2K and 50K, while the schematic is 1.9K and 25K. Which is the correct resistor value, and where can I find the latest CFA3 schematics? If I only keep SS, do I not need to populate the 4.2K and 600PF CAPs? Thanks Report
November 27, 20241 yr comment_950565 600 or 680 can be used. 680 will be slightly higher front end gain 300 is correct 4.2k is just higher gain than 1.9k I don't remember what the 50k and 25k are -- SS feedback resistors? if so also just higher vs lower gain If only using SS, it's possible you can eliminate the 4.2k, as long as there is still another resistor in parallel with it. what you would do is measure the gain with and without the SS feedback resistors, and choose values so you have ~6dB less gain with the SS feedback resistors installed Report
February 27, 20251 yr comment_953174 Hello everyone, a question to Uberamp. Can i use Uberamp as a headphone amplifier for planar headphone such as susvara or DCA expanse if i add a pot before Uber3? Should i reduce the gain resistor? Thank you for your help😊 Report
February 27, 20251 yr comment_953192 And why not take the CFA3 for the Susvara or other planars? Report
February 28, 20251 yr comment_953200 I will also make a CFA3. Just want to try Uberamp on headphones, maybe it will be more impressive 😊 . Just want to know if it is possible use Uberamp as headphone amp with a pot Report
May 8, 20251 yr comment_956063 Been running my CFA3T at 150ma bias current per CFA2 board for quite some time. Just cranked it up to 200ma. I'm mounting the transistors direct to heatsink without an intermediary L bracket or such. After a few hours of on-time, I'm seeing about 55C on the cases of the hottest output transistors, so well within safe range once the junction>case temp math is done. Heatsink around 40-45C. Some of the bc555/6 are getting a bit warmer than I'd like though, so going to throw heatsinks on the hot ones as well. Sound wise, I think I hear more "speediness", highs/mids that are a bit more pleasing/engaging, and some increased weight and definition in the low end. Could just be my brain though. I've had been driving my Ascend Sierra Luna V2 monitors directly from the CFA3T to great effect. I added a sub line out via voltage dividers from each + terminal, and ground taken from PS ground to feed a small sub for this desk setup. And it's been bliss. Report
May 14, 20251 yr comment_956282 Working on a shrunk CFA3 layout this week, here is what it looks like. Haven`t tested it yet. The dim is about 8.6 inches * 3 inches per channel. Not small enough, but I bet someone can make it better by SMDing. Report
May 18, 20251 yr comment_956417 On 5/14/2025 at 3:09 PM, Shawn said: Working on a shrunk CFA3 layout this week, here is what it looks like. Haven`t tested it yet. The dim is about 8.6 inches * 3 inches per channel. Not small enough, but I bet someone can make it better by SMDing. Good job! Almost mountable to one of these heatsinks! https://modushop.biz/site/index.php?route=product/product&path=284&product_id=733 Report
September 18, 20251 yr comment_962208 Hello, testing CFA3P here, seems to work fine, but it is running really hot at 150mA bias, wanted 250mA bias, but this impossible with used sinks. Powered with 30V PS. Do I need to change some values to run it with lower bias than designed 500mA? Thank you! Report
September 27, 2025Sep 27 comment_962515 On 4/22/2015 at 6:09 AM, kevin gilmore said: the new verskon uses the bc parts Report
October 14, 2025Oct 14 comment_963319 HI All, After a long hiatus, I finally got back around to trying to spin up my CFA3 (rev 1.2) boards. After letting the magic smoke out of the output resistors a couple of times, replacing them, backtracking a few things / posts etc I finally got 1 side of one board to the reasonable point from both a dc offset and bias perspective without letting the magic smoke out. The other side of the board is still way off on DC offset (.4v) but nothing is smoking, so before I started probing that side of the board, I decided to plug my other one in to see where it was at. After backing off all the pots and then plugging it in, the output resistors immediately went nuclear on one side. I de-soldered them and I think the heat from the meltdown coupled with me de-soldering those resistors a few times now weakened the copper traces on the board and I have now lost a couple of pads on the output resistors. I know I could make a fairly simple repair to try and get it working at least for proof of concept but coupled with the other issues I am having with the board I think it may be time to start from scratch rather that de-soldering all the transistors etc on the board and swapping them out trying to find the core issue. Does anyone have any headphone boards they can sell? I would either look for a single replacement 1.2 board or look for a pair / quad (?) of later boards and make a new complete pair. If anyone can assist, please dm me. I am based in the US but happy to pay freight from OS if needs be. Cheers, Ben Edited October 14, 2025Oct 14 by bdinnev Report
October 15, 2025Oct 15 comment_963338 The gerbers are available. Why not just get your own run? Report
October 15, 2025Oct 15 comment_963340 47 minutes ago, Pars said: The gerbers are available. Why not just get your own run? Last time I checked it was during COVID and the figures just didnt stack for small runs up so had not thought about it this time round - but have just placed an order to get a batch made so will have a few spares - have gone with the CFA3 split boards and a whole new set of components so fingers crossed in the next week or so I have 2 boards working successfully. Edited October 15, 2025Oct 15 by bdinnev Report
October 15, 2025Oct 15 comment_963342 Ordering from places like JLCPCB is pretty economical. I hope you did 2oz copper and at least 1.6mm PCB thickness? 10 boards for ~$90 shipped (this for the v1.2 full board). Edited October 15, 2025Oct 15 by Pars Report
October 15, 2025Oct 15 comment_963344 15 minutes ago, Pars said: Ordering from places like JLCPCB is pretty economical. I hope you did 2oz copper and at least 1.6mm PCB thickness? 10 boards for ~$90 shipped (this for the v1.2 full board). Yeah I did 2oz copper. Shipped for 5 pairs (split) boards (I know, 1 left over . . . . .) it came in at $135 - duties, sales tax etc . . . Edited October 15, 2025Oct 15 by bdinnev Report
October 22, 2025Oct 22 comment_963718 Looks like I had better get the hot air gun and soldering iron out . . . Report
November 27, 2025Nov 27 comment_965696 Anyone has some experience or tips simulating CFA3 SS mode in Ltspice? The transient analysis is barely moving for me, with or without servo, single ended or balanced input, not with arbitrarily large time step size neither, only way I tried to make run through is making open loop gain too low such that the close loop gain is no longer maintained by the ratio of the feedback resistors. I wonder if it's the cross feedback thing making it so slow. For reference CFA2 with current feedback runs fine; CFA3 open loop mode also runs fine, I'm getting gain of about 3.3 with gain resistors set to 10k || 1.9k, is this expected? (I use Jfet on the input) Thanks! Edit: Also attaching my ltspice sim file CFA3_ltspice.zip Edited November 27, 2025Nov 27 by jokerman777 Report
December 2, 2025Dec 2 comment_965798 So I have spent the thanksgiving break playing around with ltspice, mainly wanted to do a 3-5W class A into 32 ohm balanced amp and started off with Kevin's CFA2/CFA3 design, and comes down to something like this, basically a slightly reduced CFA2: Just thought I want to put here for some input before trying to actually make it, which I'd much appreciate if any 🙂 I mainly have questions around: "floating tail" input (just like uberamp/preamp2025 input) instead of separate CCS (like dynalo/CFA3 input): Works in sim but in reality I don't know if I can just send feedback this way and make it fully differential with CF. When input is single ended where one side is ground, due to the feedback it seems to be amplifying the voltage disproportionally on two sides while overall differential gain is maintained. A problem or just an expected behavior that I can live with? (most of time I won't use single ended input) thermal: Is it essential to mount all the transistors in darlington triples to heatsink? Dissipation wise the inner ones don't really run all that hot. Im tempted to just mount the output pairs, planning to run them at around 200mA each phase margin: unsure if I'm measuring open loop gain correctly, am just doing vout / (vin - vfb) on one leg, where vfb is the feedback entry point. other suggestions? Report
December 2, 2025Dec 2 comment_965801 8 hours ago, jokerman777 said: thermal: Is it essential to mount all the transistors in darlington triples to heatsink? I’ve a smd version of CFA3. Only output transistors on heat sink. Bias is servo controlled. Works all right. Output stage with servo looks like this… On 7/27/2024 at 11:36 AM, JoaMat said: Have had a new bias servo working with my CFA3smd something for a few days. Schematically it looks like this, and the new thing is in red square. Now I get a good reference point to the servos. Don’t understand why I didn’t figure this out earlier – slow brain perhaps. All four servos are fed from the same point. So, one trimmer and full control over the BIAS of all channels. Diagram for new servo - 6 minutes from cold. and diagram for old servo (in mA for the first 40 minutes from power on) Please have in mind that the graph for no servo is for my CFAsmd something. I guess the original CFA3 have a different and better behavior – where all tripple Darlington and vbe transistors are mounted on heat sink. Report
December 2, 2025Dec 2 comment_965806 3 hours ago, JoaMat said: I’ve a smd version of CFA3. Only output transistors on heat sink. Bias is servo controlled. Works all right. Output stage with servo looks like this… Thanks @JoaMat, this data is really helpful. From your measurement it does look like I really needed either bias servo or do it like the original for hopefully less drift. Nice soft start behavior too Report
December 2, 2025Dec 2 Author comment_965811 i looked at the ltspice file for a bit. best guess is that there is something wrong with the jfet model that causes issues. replace the fets with bipolar and see if it works right. the reason all the darlington transistors are on the heatsink is so they can thermally track. effects thd. another thing that really effects the thd is the power supply rails. anything under +/-20v is too low and causes much higher distortion. +/-30v is the sweet spot. and once you do that, you end up with an amplifier that is a lot more than 5 watts. in your second schematic, you have taken out the low impedance load on the output of the current mirrors. lots more voltage gain resulting in required high amounts of feedback. definitely not the original design goals. if you want lots of open loop gain, probably best to pick a different design. as far as the bias servo, would have to see thd with and without it. Report
December 2, 2025Dec 2 comment_965812 9 hours ago, JoaMat said: I’ve a smd version of CFA3. Only output transistors on heat sink. Bias is servo controlled. Works all right. Output stage with servo looks like this… I don’t see how the bias servo could have worked. You have the + input of the opamp connected to the amp output terminal, which means the integrator has a dancing reference that it has no rejection of. Furthermore, a divided down version of that amp output signal is shared with other servos, an interesting way to create crosstalk? Report
