Closed - KGSSHV Carbon and GoldenReference HV PS Group Buy
mwl168….Thank you for organising another gb. I would like the following please;
Amp pcb
2 sets (4 pcs)
Psu pcb
2x dual PS board
1x Left PS board (skinny)
1xLeft PS board (Fat)
1x Right PS board (skinny)
1x Right PS board (Fat)
Edited by kingofsnake
  • Replies 419
  • Views 94k
  • Yep, this has to be the most confused/confusing GB I've seen. From simple concept to kitchen sink...   EDIT: it was suggested in a pm that I might want to elaborate on what I find so confusing. I do
  • Thanks all for your prompt responses and payments.  I sent PCBnet all the latest version Gerber files yesterday for final confirmation of quotes. I will place the order soon as I receive the confirmat
  • I have built one of the Fat PS boards , kgsshvpssicfetsinglenewrightfat gerbers dated Tuesday, ‎July ‎28, ‎2015, ‏‎2:38:28 PM and want to report that it works... 408vdc at anything above 310vac input,
IMHO the fat version of the PCB looks very interesting and opens new options for the case layout.
Thanks Kevin.
Should I re-trace the dual power supply board?
@mwl168
I have heard from sorenb that there were some quality issues with the kgst boards from the recent GB. I cannot comment on this, because I have not used my boards I got from this GB yet.
Therefore the question: Will you be using the same manufacturer or anonther? I think for an Amp such as the Carbon higher quality PCBs could really be justified, even if it adds a bit to the cost.
Sorenb brough the issue to my attention as well. I do plan on using a different fab house for this GB just don't know which one yet.
Please do let me know if you run into PCB quality issue with your KGST boards. I will file a complaint with the manufacture.
if you have the time check every one of them, but all i did was change a couple
of silk screen labels, and a couple of .6 resistors into .5 which are easier
for people to bend.
the others are just cut and paste from the original
Thanks for putting this together.
I would like:
2x amp sets (4 pieces)
1x single psu set  (2 pieces)
1x dual psu (1 piece)
Have we decided if the split PSU on this GB is the fat or skinny version (or both)? Aside from size, the difference between the fat and skinny is the orientation of the angle bracket holes, yes?
1 set for me please - 2amp boards, and 1 dual psu.
Tks.
The "fat" single PS was released after the GB was started.
I believe the only difference between the "fat" and "skinny" single PSU is the dimension of the PCB based on my quick look through gerber file viewer. Kevin will have to confirm. My guess is the fat single PSU was created to facilitate flexible boxing layout and options.
I need to ask all those that have expressed interest in the single PSU to edit your response and specify specifically if you want the "fat" or "skinny" single PSU if you have not already done so.
I will be getting a spreadsheet listing the participants and options started and posted her at the appropriate time.
Thanks!
Edited by mwl168
Personally I like the fat single power supply for more flexible mounting options.
I have aready modified my post response.
I would also opt for the fat version and change my GB wish to:
2 sets of amp boards, 2 sets of splitpsu (fat version)
@mwl168
It will be a long time until I use my kgst boards. They are just as a backup.
Going to be broke from buying all these boards, is this any less expensive to build compared to the other kgsshv's?
Might have to skip this one out.
I'm still waiting for a Megatron and DIYT2 PCB gb Mike.  ;D
Edited by DefQon
the output stage costs less and uses in production parts
I have done a preliminary BOM with some spare materials, but I estimate the mouser parts alone without spares would be around 300+ dollars. Let alone the PSU Caps are 4*40 dollars.
Any difference in sound vs 1968 or IXYS part output devices?
I think there are some minor differences but not worth seeking out 1968s for the prices they command
the fat supplies are now exactly the same size as the amp boards
all the mounting holes in exactly the same place.
5.45 x 4.05 inches
fits in the dissipante 2U box with the boards mounted horizontal
with ample room for transformer, or 3U box with the boards
mounted vertical, and even more room for the transformer.
the skinny supplies are 3 x 6.5 inches which is a tougher fit
in many boxes.
1. How many amp boards do you want. (one channel on each board, you need two amp boards for one complete amp.)
2 amps (4 each)
2. Which PS (dual,  single skinny or single fat) and how many of them do you want. (you need at least one dual board or two single boards for one complete amp.)
One dual and two single
Thanks!
With the latest matching board sizes, a horizontal mounting setup fits in a Galaxy 388 (not much room to spare on depth). Transformer in the middle, ideally it would be tall and skinny.
With a creative setup, it might just be possible to use a Galaxy 288. The amp boards go on the top panel, possibly inverted, and the transformer sits beneath them. Then the transformer would have to be short and fat.
Major problem with the Galaxy series is replacing the stock sides with true heatsinks. Has anyone ever asked Modushop about doing this?
The Dissipante line is much wider. 450mm, larger than any Galaxy case.
you can always buy random heatsinks and mount them inside. that's what I was planning on doing if my case didn't meet proper sizes
@gepardcv: can you do a sketch showing your idea for chassie? I belive ModuShop do custom chassies ....if one buys five/ten ....it might be a low extra cost ....
