Closed - KGSSHV Carbon and GoldenReference HV PS Group Buy
  • Replies 419
  • Views 93.6k
  • Yep, this has to be the most confused/confusing GB I've seen. From simple concept to kitchen sink...   EDIT: it was suggested in a pm that I might want to elaborate on what I find so confusing. I do
  • Thanks all for your prompt responses and payments.  I sent PCBnet all the latest version Gerber files yesterday for final confirmation of quotes. I will place the order soon as I receive the confirmat
  • I have built one of the Fat PS boards , kgsshvpssicfetsinglenewrightfat gerbers dated Tuesday, ‎July ‎28, ‎2015, ‏‎2:38:28 PM and want to report that it works... 408vdc at anything above 310vac input,
are you planning to fork your input  stage into its own board? should make that with melfs and cards like how stax does it haha
I'm a fan, seems like more flexibility for mounting
Edited by nopants
its an ultra quiet and extremely stable power supply. the on board version is suitable
for just about anything however, does not care. kind of overkill for kgsshv etc
but there still is nothing better.
how many are interested in this?
http://gilmore.chem.northwestern.edu/kgsshvcarboncirclotron.jpg
I'd certainly be interested in the circlotron boards.
My selections look good.
I'd prefer the latest boards with the opto servo.
The only difference between the V2 and V3 board is the addition of the opto server for the V3. The rest of the circuit is identical between V2 and V3.
I'll add a column to the table on my first post to track those that opt for the V3 boards.
I had asked for quotes on small quantity of the V3 boards in anticipation of this. I have a few caculations to do yet but at a quick glance and given the volumes we currently have, the V3 board will likely be 2x the cost of the V2 board. This is more due to the massive quantity ( > 120 ) we have on the V2 boards.
Same will likely apply to the single skinny PS which we have much lower volume than the other 2 PS options.
yes
I have to to get it in the box
but currently the 900v supplies are too big
not sure what to do about that yet
the 1kv connectors are huge, but have not
found suitable wire yet. the 5kv wire is a bit
hard to work with.
Mine is correct.
Regarding v2 or v3, would like 4 x v2 and 2 x v3 (so the same 6 in total).
Mine is correct.
Please add 2 skinny power supply boards for me.
If the V3 amp board is going ahead then 2 x V2 and 2 x V3.
I am interested in the circlotron boards too if there is a group buy.
Edited by samsie
yes
hard to work with.
a bit hard to piece together with mental images. if you're still committed to the 5u case, there's the option of using their riser plates in order to get some inner surface area, in the spirit of mitochondrial walls erector sets:
Edited by nopants
The numbers of boards is correct for me.
If not 4 x V2 will be fine.
Thank you again.
Already edited my first post, but I'll take all v3 amp boards.
Mine is mostly correct :)
To clarify, can I get:
2 v2 amp boards
2 v3 amp boards
2 single psu
2 single fat psu
Thanks again for putting together this GB
Updated the GB participants details in my first post, added one column for the Carbon V3 amp board and updated the numbers based on the recent posts. Please check and let me know if correction is needed.
Quotes continues to come in and I have some ball park figures for the board cost but they will change because of the fluctuations of numbers.
I traced the single fat boards today but not the skinny ones yet. Again, I cannot guarantee there are no issues in any of the boards included in this GB, any help with tracing the boards will help identify potential issues so Kevin can correct them before we have the boards fabricated.
Thanks!
Edited by mwl168
The circlotron sounds scary from what I've read serious HV territory. Soon Kevin will be releasing designs that can power your house. Or seriously make the lights dim when powered on.  :kitty:
Updated my post in indicate all V3 boards (6).
Thanks! =)
Just a heads up!
I asked Kevin to do a split version of both the Golden Reference HV without the Bias supply, and with the big caps be off board for direct chassie mounting. Also asked for a split version of GR LV, and asked Kevin to do a Bias Supply that have both PRO and NB. Finally I asked Kevin to do all boards less than 2U(80mm) in width
The HV PSU has always been made of two positive PSUs in series, so the only difference between a +/-HV and two +HV in series will be the PCBs are cut in two.
In rgrds to LV PSU, Kevin has done a real complementary negative PSU for the GR LV, but according to Kevin there are no advantage/disadvantage to use two postive LVs in series to get +/- LV.
So as far as I can see, the positive single PSU boards gives everybody more fleksibility in terms of how to mount in a chassie, without any real disadvantage (apart from a bit of extra wire).
I am pretty sure that Kevin can be pursuaded to do a 'usual' LV (78/7915 type) for those who prefere that to the Golden Reference LV.
I suggest that the GB offers either the full PSU (HV/LV/Bias/caps onboard) or Single HV (caps offboard), single LV, Bias(w. PRO & NB)
I think Mike should clarify (sooner rather than later) what he does and doesn't want to offer...I'm too lazy to keep track of all the forks at this point. You seem to have gotten like 2 unique versions of the supplies for use in your own case?
Based on what's in his sheet as of today, I'll change/fix my entry to:
4x V3 amp boards
2x dual psu (1 set)
1x single fat PS
1x single skinny PS
and similar to Kerry I'll pencil in interest for the Golden Reference LV.
Thanks!
I have updated my post to 4x V3 Amp boards.
Below is the updated list.
V3 Amp pcb
4 boards
DUAL PSU pcb
4 boards
Dual LV PS pcb
4 boards
Thanks for organizing the GB
I'll add Golden Reference LV options to the GB, both the dual (goldenreferce3.zip) and singles (goldenrefernceplus4.zip and goldenreferenceminus4.zip). Help will be needed to trace these boards, I may not have time to trace them all before placing the order. Again, keep in mind that board cost will be high if volume is low.
I'll also add the NB board option but I don't think Kevin has posted the Gerber file yet. It's a stand alone board that provides both pro and normal bias.
Updated first post to include Golden Reference LV and Bias board options and GB details accordingly.
New participants please read the first post in detail and be specific with your request.
Thanks!
it might be less of a hassle for you to open the sheet to the public and let us edit the quantities?
Edited by nopants
Heres and online copy of the latest overview from MWL168; I hope I got everyone right (please check)
https://docs.google.com/spreadsheets/d/1GWDWwLfsIDtwn1HB-x76lS6WyWwLd5lwsORFKiUuuEQ/edit?usp=sharing
If someone whats to participate please add your alias by first adding a blank line above the "END" (I guess the SUM will continue to work that way).
/S
Edited by sorenb
Please note that the spreadsheet is not editable.
@insanity: should be fixed, thought that I gave everybody edit acess ...apparently not :palm:
