What Are You Building Today
Jealous of the whole Sawstop setup.
  • Replies 2k
  • Views 481.1k
They are a lot cheaper than new fingers.
21 minutes ago, naamanf said:
It keeps the material pressed down on the table and the wheels are angled to keep it pressed against the fence. Basically does the same thing feather boards do, helps make straight cuts and adds some safety against kickback.
I love those things, btw. I think they are about the best table saw accessory I have found. They are helpful for sheet goods, but where they really shine is in long rips of hardwood. Cutting trim pieces, for instance.
as someone whose thumb is still whole because of a sawstop, I would pretty much refuse to touch a non-sawstop table saw.
If I had the room, the SawStop PCS is the only one I would consider. I was leaning towards the little Pro cart one but its minimal cut capabilities did not seem worth the up charge, I guess the finger saving is the up charge.
Glue Up Kit Holder for the wall.  Need to run through the router and get it glued together.
Put together an over complicated wood smasher.
Edited by naamanf
I cannot wait to see what you get up to with that beast. Very envious.
I thought it was from the basement in Pulp Fiction.
6 minutes ago, swt61 said:
That thing is massive.
Coming from the TICE, high praise indeed.
It’s a damn good thing you bought that robot driller, than would have been tough as shit to do by hand.
In case anyone was wondering, I am now a Chopmaster.
Edited by VPI
That is a very nice miter saw!
Not familiar with that blade. Details?
Ah, it's a forrest. They are the best blade I know of.
Came with a 60 tooth that was excellent at smashing, but not tuned for actually cutting.
Now I need to figure out how to make a zero clearance insert without having any of the tools (bandsaw, bench top sander, skill) I actually need to make one.
1 hour ago, naamanf said:
Drilled four holes.
IMG_3596.MOV
I have drilled a lot of holes in my day, but never in such a sexy ass way!
I think I got a bit firm there.
Why?  For the chop saw? Every zero-clearance insert I've seen comes as a solid piece and you just run the blade thru.  I feel confused.
Need to build one myself. They do not sell a zero clearance that I have found. Need to cut the wood, shape it to fit, route out some for clearance and make it the proper depth to be level with the table.
Edited by VPI
Measure.  Provide measurements to fellow idiot w/ CNC router and laser cutting tools.
Easy for my drilling robot, just need exact dimensions.
