Balanced to unbalanced board
The idea was a 7 pin header with one pin missing, or a single pin header
might rethink that
originally I was thinking of soldered in right angle pins
  • Replies 260
  • Views 88.9k
  • Messing with this tonight. Its playing into balanced ortho's. the gain is stock at 2 and its just enough, not real loud but sounds just great! yes this is meant for Pre duty, this is on
  • mypasswordis
    mypasswordis
    So I did end up using a female header socket and air wiring the ground. The part number for the 4 pin right angle header is 68016-404hlf. The leds I used are extremely bright orange-red, glad once i c
  • Transformers
Hi Kevin,
I want to ask if how much is the input impedance of your diamond buffer. My source have very high output impedance, around 5000 Ohms, and I am searching for a buffer to drive it.
Best regards,
you probably want the version with the on board servo then. my guess is that the input impedance is something like 10k
now that the lsj and lsk dual parts are available, a 2 channel version would be possible with a much higher input impedance
Thanks Kevin and spritzer for your help. If any group buy for the FET version happens, I will definitely take part in. Otherwise I will also be happy to order PCB to use for myself if Kevin permits.
I have one more question, what is your favorite PSU for buffer stage? I have a Walt Jung PSU with AD586 / AD797, is it good enough?
  • 4 weeks later...
I took a stab at Mouser BOMs for the diamond_buffer and unbal_2_bal SMD boards.  Can someone kindly enough to check and correct the BOMs?  Many thanks!
**** Edit ****
The below lists hadd these changes (thanks to mypasswordis!):
LED from 2V to 1.9V
300-Ohm LED resistors from 250-Ohm
0.1uf C2/C3/C7/C8 caps to 0603 package
10uF C1/C4 to X7R
Other note: OP27G U1/U2 can be changed to other op-amp
Unbal_2_bal SMD
Mouser #                            Description        Order Qty.
757-2SC3324BLTE85LF   Bipolar Transistors - BJT Audio Freq Low Audio Freq Low                      7
757-2SA1312BLTE85LF    Bipolar Transistors - BJT PNP Trans -0.1A LN -120V VCEO                     7
284-APC1206B1K00N       Thin Film Resistors - SMD 1KOhm 0.1% 1206 25 PPM                             4
667-ERA-8AEB103V           Thin Film Resistors - SMD 1206 10Kohm 0.1% 25ppm                             12
667-ERA-8AEB132V           Thin Film Resistors - SMD 1206 1.3Kohm 0.1% 25ppm                            2
647-UWX1E101MCL1        Aluminum Electrolytic Capacitors - SMD 25volts 100uF 8x5.4 20%        2
584-OP27GSZ-R                  Precision Amplifiers LOW-NOISE PREC IC 2.8V/uS                                    2
581-06033C104K4T4A      Multilayer Ceramic Capacitors MLCC - SMD/SMT 25V .1uF X7R             4
710-885012209028            Multilayer Ceramic Capacitors MLCC - SMD/SMT                                      2
710-150120SS75000         Standard LEDs - SMD WL-SMCW SMDMono TpVw Waterclr 1206           4
603-RT1206BRD07300RL Thin Film Resistors - SMD 1/4W 300 ohm .1% 25ppm                                6
Diamond_buffer SMD
649-68016-404HLF            Headers & Wire Housings 4POS R/A HDR SnPb                                           1
279-CPF1206B10RE1        Thin Film Resistors - SMD CPF 1206 10R 0.1% 25PPM 1K RL                   4
279-CPF1206B24R9E1      Thin Film Resistors - SMD CPF 1206 24R9 0.1% 25PPM 1K RL                 2
756-PCF1206R-20KBT1     Thin Film Resistors - SMD .125W 20K ohm 0.1% 25ppm                            1
757-2SC3324BLTE85LF     Bipolar Transistors - BJT Audio Freq Low Audio Freq Low                        4
757-2SA1312BLTE85LF      Bipolar Transistors - BJT PNP Trans -0.1A LN -120V VCEO                       4
710-150120SS75000          Standard LEDs - SMD WL-SMCW SMDMono TpVw Waterclr 1206            2
Edited by Skooby
parts updates
Opamp caps are 0603 package and use 300 ohm resistors for 2V LEDs (actual in circuit voltage will be more like 1.9). You need to at least somewhat match the LEDs before soldering them in so buy some extras
Edit: Y5V caps aren't good, if you are bothering with .1% resistors then get X8R/NP0 or at least X7R
Edited by mypasswordis
On 8/31/2017 at 9:01 PM, Skooby said:
**** Edit ***
The below lists had these changes (thanks to mypasswordis!):
LED from 2.0V to 1.9V
If I understand the comment from @mypasswordis correctly, I believe he was saying that the 2V LED would be 1.9V in circuit. Not that you should change the LED from 2V to 1.9V.
^ yup, and the resistors for the current sources still should be changed to 300 ohms from 250 given the 2V LEDs which run at ~1.9 in circuit. Everywhere in the circuit you see a current source like this, replace with 300 ohms:
Really it's more for the diamond buffer boards than anything else as IIRC I measured about 52 C on the PCB (also using 2V LEDs and 300 ohm resistors) and this was after I added heatsinks
**** Edit ****
LED from 2V to 1.9V
10uF C1/C4 to X7R
Unbal_2_bal SMD
757-2SC3324GRTE85LF   Bipolar Transistors - BJT Audio Freq Low Audio Freq Low                      7
Diamond_buffer SMD
757-2SC3324GRTE85LF     Bipolar Transistors - BJT Audio Freq Low Audio Freq Low                        4
Another edit to your BOM. The transistors should be the BL type, not the GR. So the 2SC3324 transistor should have mouser part 757-2SC3324BLTE85LF
Digikey says that 2SC3324/2SA1312 is NRND and is recommending 2SC2713/2SA1163 as a substitute. Any reason why I wouldn't be able to use the 2SC2713/2SA1163 transistors for the unbalanced/balanced board and diamond buffer?
Comparing the datasheets for 2SC3324 and 2SC2713 it seems like the 2SC3324 has a lower noise figure, but otherwise have identical specs. 0.2dB and 1dB max vs 1dB vs 10dB max respectively. Seems like I should go for the original pair while I still can. Too bad it's backordered on Mouser until March.
Edited by cspirou
Verical has stock of both 3324/1312 and i'm sure some are on ebay too
i also have a lot of them
Verical has 2sc3324-GR but not 2sc3324-BL. KG mentioned that the highest hfe should be used which is the BL version.
  • 5 weeks later...
When matching transistors do you only need to match complimentary pairs? Or do all the transistors on one channel need to be the same?
I try to match complementary pairs, but going from N to P (both BJT and JFETs) usually doesn't match very well. It depends on the devices.
cspirou: I would add an input resistor to ground as well. You can match Q1 to Q3 and Q5 to Q7, but I don’t think matching is all that useful here. If you want to try another small SMD buffer, let me know. I have just ordered some boards now that I have verified their performance versus sims.
I can include matched Toshiba JFETs and the other dual package BJTs are available at Mouser.
