Continuation of R2R DAC Discussion From Stax Thread
I completely agree that a chip, or hybrid solution would be best. In fact the concept of using a laser trimmed metal foil R2R network, where the foil network was layed down by photolith ought to be superb, hermetically sealed and dry nitrogen filled. Cheap it would not be...
  • Replies 146
  • Views 70.1k
  • mypasswordis
    mypasswordis
    All this talk of R2R DACs pushed me to future proof my setup. Just bought a DAC with PCM1704s and PMD100, so now I can relive HC circa 2010. I still also have my Parasound DAC1100 I bought from a memb
  • kevin gilmore
    kevin gilmore
    well its 2016, soon to be 2017, and it might as well be 2009/2010 because lampizator is round 2 of singlepower. I was waiting to get a picture of the board so that I could disprove just abou
  • kevin gilmore
    kevin gilmore
    so I bought a bunch of different 10mhz master reference oscillators to see if there was any difference. and yes there is a big difference, this is my favorite. a rubidium disciplined ocxo
Although DF1704 TI paired with PCM1704 has been outdated and surpassed by FPGA based digital filter, PCM1704 is still a very good chip even after over 10 years of production. Sad to be obsoleted. As I know, TI stopped all audio R2R chip production. So we have to look into discrete design or use AD chip sth like Schiit used. Even for AD5791, it is only 20bit so when playing 24bit data, some calculation must have to be done.
Edited by joehpj
I have a DAC based on AD1862 (20 bit) and I like it better than a same DAC based on PCM 1704, by a lot. Actually I don't really understand why people treat PCM 1704 as it is the best R2R dac chip ever. Engineered better? Sound wise better?
All Sigma-Delta Chips are using that calculations to decode PCM, the highest bit of a hybrid Sigma-Delta chip has as I know 6 bits. So if you do not have any problem with it, why do you think about 20 bit R2R dacs has problems with decoding 24 bit? cuz they are already outdated, cuz you care about the remaining 4 bits is left behind? If a dac can decode 20 bits perfectly, IF, I do not hecking care about the remaining 4 bits.
Anyway, what I extremely curious about is this:
http://www.transient-audio.nl/DAC_TWO.html
Are they using on shelf dac chips in it with a simple closure? WTF is in that closure? Anyone got some info abou it?
Edited by Sechtdamon
my guess is that the transient part is all discrete, and very similar to the soekris with fewer bits. and like the soekris, opamps to do the se to balanced, and more opamps to do the filter.
there are no off the shelf 24 bit dac chips. if there was, things would be much easier regardless of their price
... and encased in a crystal controlled oven to negate any temp drift....
PCM1704 was a 24bit dac. But the ENOB was less than AD5791. Why is that different?
That was the point I wanted to reach Dr. Gilmore, thanks.
Interesting thread guys. The Chip type (in R-2R) as we are talking here does seem to have an effect on the sound. And I guess discrete different again, quite possibly surpassing a chip? But the effect of the filtering used and the quality of the power supply and output stage after the chip also has a big impact IMO. Having trawled through various R-2R DACs in the past it seems that has a marked effect on the sound you will get.
so the 2 piece version will be capacitor coupled output, the 4 piece version will be dc coupled output, the newest version of cast and cascode fet buffer.
for balanced you will need 8 pieces. i'm sure a version of this is coming.
as far as I know, no dsd  but it should be capable of that.
pricing is finally rational
Been going through some of the old threads on old multi bit dacs. Is Filburt's favorite opamp THS4032 (with the fancy decoupling) still the one to go for if you have to settle for an opamp i/v? Or are there other opamps that are better now? I haven't been able to get Filby's modded Assemblage sound out of my head, ever since I listened to it.
That is what I used on my Rotel 991 (still haven't gotten around to discrete in it yet) along with 8xxx for the buffer/SE ->bal. It was touchy for decoupling. I used the Aries DIP adapters with on pin decoupling and no sockets for the 4032s.
Awesome! How does it sound? And what discrete i/v were you planning on using? You wouldn't happen to have some of the borbely stuffed saved up would you?
It sounds good, probably not as good as my 855 with an rbroer (diyaudio) discrete, but much better than the stock opamps.
I have one of Colin Toole's discrete stages partly built for the 991. Still haven't decided whether to leave the ad8599 (IIRC) in as the SE to bal converter or to use something discrete there.
What's the latest news regarding a Denafrips DAC being spotted in Iceland?
P.S. Looks like 2017 will be the year of the R2R dac. I sort of feel torn between a RME ADI-2 Pro and one of these Asian miracles.
Yeah I bought one... blame Kevin as he's such a bad influence on me.  :)  It's shipped but I have no idea when it will arrive...
definitely blame me.  its my fault.  its always my fault.
This is definitely the year of r2r
and the start of the end for megabuck stupidity.
Can I blame you too for the 150$ Wiha wire stripper I bought which really doesn't like PTFE wires?  I need a new cartridge for those...  ^_^
It will sure be fun to compare it to the MSB.  They sent me message asking for my email address so they can send me the drivers so that is a good sign.
The Soekris modules are also sitting here but I have no idea what to do with them.
That's just grand. You ninja those right before me and now they collect volcanic dust...
Well, get 7-9V of AC or DC, fashion a spdif input and you should be able to have music.
I'll throw something together eventually as I need a balanced DAC for my test setup.  What is the USB input of choice these days?  Still XMOS what ever?
i use the stripmaster. does teflon just fine.
justin has managed to go thru a few sets of dies, mine are still original 30+ years later, although i recently bought a new one as the handles on the old one are falling apart.
I normally use the Wiha 36050 stippers but they do wear out after a while with the 24# teflon stuff.  The Wiha 24672 is supposed to be better but I need the bloody PTFE cartridge for it...
I'd use this - https://www.minidsp.com/products/minidspkits/nanosharc-kit
You get superior DSP control, extra inputs and remote volume/input/filter control. Supposedly the DAC should be input agnostic due to FIFO reclocking.
