January 2, 20206 yr https://www.electric-kingdom.net/post/behringer-releases-clone-of-beyerdynamic-dt-770-studio-reference-headphones See, this is why I hate Behringer, they reverse engineer technology, and then undercut the original. I’m alright with it when the technology is long since out of the market, as is the case with many of their synthesizers, but this is ubiquitous! Grr...
January 2, 20206 yr Not really sure how much is truly "reverse engineered", other than cosmetics. I think Beyer makes their own drivers, at least for most of their pro lines. The Behringer driver is 53mm, while Beyer's is 45mm. Beyer also makes multiple impedance variants of many of their pro models (250ohm, 80ohm, 32ohm). But your point is taken.
January 2, 20206 yr The copy so heavily undercuts the Beyer that is seems kind of spiteful. If the sound is anywhere close to the original, it seems like it would just about destroy it at half the price?
January 2, 20206 yr The original is sold at a cheap enough price. Does Behringer want to compete with Beyer? On the other hand, how long do patents last?
January 2, 20206 yr Author 52 minutes ago, jose said: On the other hand, how long do patents last? If they used a different size driver, then it’s technically a different design.
January 2, 20206 yr Author 3 hours ago, jpelg said: Not really sure how much is truly "reverse engineered", other than cosmetics. I think Beyer makes their own drivers, at least for most of their pro lines. The Behringer driver is 53mm, while Beyer's is 45mm. Beyer also makes multiple impedance variants of many of their pro models (250ohm, 80ohm, 32ohm). But your point is taken. They're marketing it as a clone -- clone==reverse engineered. But your point is taken as well. I would phrase it thusly: after they reverse engineered it, they forward engineered it from there -- presumably to give them some cost-cutting options, but also maybe so that they could protect it as a different design.
January 2, 20206 yr 2 hours ago, Dusty Chalk said: If they used a different size driver, then it’s technically a different design. I'm not sure. The same happens with the imitations of the "Beast". Although the driver is different, they are copying an industrial design. Another matter is that Beyer, after 1000 years of manufacturing the DT770, has granted or sold the patent.
January 2, 20206 yr Author Yeah, I'm no lawyer, so I'm literally doing that thing that we all hate: hypothesizing. Oh, also, persecuting, convicting, and judging.
January 3, 20206 yr 19 hours ago, jose said: The original is sold at a cheap enough price. Does Behringer want to compete with Beyer? On the other hand, how long do patents last? Territory dependent, but 17 years is a good guide.
January 3, 20206 yr In pharma-industry here in Europe are usually 10 to 11 years. In the US they are somewhat longer I think 20 in some cases. Far from this, the DT770 has been in production for more than 20 years so it would not surprise me if its design patent is expired or that Behringer and Beyer share shareholding. Something that catches my attention is that the new model is called "DT330/DT660" which would lead to suppose that it is a model "inferior" to the DT770.
January 3, 20206 yr You're absolutely right Jose - any patent covering the DT770 will have long expired.
January 3, 20206 yr So B&H photo had a discounted return. I ordered one at $10 off. No brainer. I'll find a use for it at that price. I don't currently have a closed set of headphones.
January 3, 20206 yr Author 5 hours ago, jose said: Something that catches my attention is that the new model is called "DT330/DT660" which would lead to suppose that it is a model "inferior" to the DT770. Actually, the original link says it’s called the BH 770. Where did you see DT330/DT660? 4 hours ago, ktm said: So B&H photo had a discounted return. I ordered one at $10 off. No brainer. I'll find a use for it at that price. I don't currently have a closed set of headphones. Oh, good, please do report back. I am very curious, myself.
January 3, 20206 yr I had a Beyer dt770 years ago. Son #2 destroyed it. Seems late night gaming is very intense?????
January 3, 20206 yr Some online reviews not too positive.....one example: I had to take a chance for the price! They look like the Beyerdynamic 770's but that's all they do. Broke them in over night hoping for better sound but in the AM they were still super thin sounding. Also had a friend in Nashville who purchased the phones from another vendor and he said he had the same issue.On a tone generator you can hear frequency down to 15hz but low end is not reproduced accurately when listening to music. Sounds like they roll off at 200hz.I think the Extended Bass extended right past these phones! Ha!
January 3, 20206 yr 1 hour ago, Dusty Chalk said: Actually, the original link says it’s called the BH 770. Where did you see DT330/DT660? Umm.. here ? Ah no, sorry I´m mistake. it´s a Superlux.
January 3, 20206 yr I forgot to comment that the German-Maestro also have identical Beyer housings and I would swear they also use the same drivers. I have several German_Maestro at home and they are very similar to their Beyer counterparts. German-Maestro webside
January 4, 20206 yr Oh my goodness, at this rate, Uli is going to have a brainfart and clone the Neutron. Is there no end to it?
January 12, 20206 yr Well, it's official. They suck for music. The low end is all attack and no decay. Drums sound all hollowed out. Eq isn't going to fix this. These are going to be used with the tablett. They isolate and are fairly efficient. I can now watch bad anime in the same room with the wife. Edited January 12, 20206 yr by ktm
