November 1, 201412 yr comment_658751 Gentlemen, I've just read the first 70 pages of this thread. Beside the reading pleasure (yeah, I'm getting as crazy as you all, finding that reading technical things is enjoyable), I saw something extremely special... This project is something I haven't seen before, and my English is too short to put proper words on it. Dr Gilmore, you have been quite busy doing this between bottle washing. Congrats to everyone that finished their T2. Edited November 2, 201412 yr by G600 Report
November 28, 201411 yr comment_662125 The on-semi announcement kind of throws a wrench in the works for the newer version of the T2 doesn't it? That being said, I have a few pieces of the mpsw06 left. Do we need to match the hfe, since it's a sub for the 3381? Report
November 28, 201411 yr Author comment_662131 We can use the Fairchild parts but I don't relish the thought of having to do the matching for a couple of T2's. I might have a line on some 2SC3381's so there will probably be two layouts. Report
November 28, 201411 yr comment_662133 mpsa06 is fine for those, very low power. Fairchild version should be available for a long time. Report
November 28, 201411 yr comment_662134 good to hear, in that case I think the main hurdle will still be the power fets. Report
November 29, 201411 yr comment_662213 Just curious. Did Stax use c3381 in T2 servo. Edited November 11, 201510 yr by JoaMat Report
November 29, 201411 yr Author comment_662214 Stax used 2SC2291 but the schematic has it hand written on it "or 2SC3381". Report
November 29, 201411 yr comment_662229 the one i had used the 2sc3381 parts same silicon, one was a 5 pin, the other a 7 pin Report
November 29, 201411 yr comment_662242 How about HN4C51J as replacement for 2sc3381? It's a Toshiba dual NPN common base in sot-25. Edited November 29, 201411 yr by JoaMat Report
November 30, 201411 yr Author comment_662347 Not a whole lot of fun soldering those by hand though... Report
December 3, 201411 yr comment_662745 my heart is being pulled so many ways I don't know what version to make Report
December 3, 201411 yr comment_662758 my heart is being pulled so many ways I don't know what version to make All of them. Because d-_-b Edited December 3, 201411 yr by nikongod Report
December 3, 201411 yr Author comment_662759 To add to your pleasure I will probably do a third version. It will be tailored to the parts I can buy in bulk but leaning more towards the original design. I've been stocking up on parts just in case I build some so a special version is in order. Report
December 3, 201411 yr comment_662805 All of them. Because d-_-b It's kind of an issue Ari, if I have boards lying around I somehow always end up populating them. It's part of the reason I have shied away from p2p work, aside from incompetence. I started looking at the newer board files, do they have to have offboarded heatsinks? I got the impression that the original footprint was to match with aesthetics of the amplifier board. Report
December 4, 201411 yr comment_662921 I was looking for one-off deals and found this for fabbing the boards. There's enough area to do a run of the original, so that should encompass all of the current variations that currently exist. Plus black is free, which is of course priceless Also some leftover space to add some boards if you were so inclined, was going to try to see if I could shove a dynalo in there Does anyone see issues using 1oz copper for this? There are also some more recent options such as PCBway which has criminally low prices, but I can't justify using this without forming a group Report
December 4, 201411 yr comment_662927 would not do 1oz copper. too thin. 2 oz minimum, the original boards were 3oz Report
December 4, 201411 yr comment_662928 The original boards are badass and could cave in a skull. :dusty: Report
December 4, 201411 yr comment_662929 fair enough, china it is. I think PCBWay quoted me 5 boards for 350-ish for just the amplifier Report
December 5, 201411 yr comment_662934 If you want to split the cost I wouldn't mind taking an original board set (with the old sand like the 2sc3675's). Is that quote for the shrunk (400mm depth) boards? Report
December 5, 201411 yr comment_662935 No that was for the original board, http://www.pcbway.com/pcb-board-quote.html Report
December 10, 201411 yr comment_663741 I am not sure it would. In the BH I can say it sounds much better to my ears* but didn't really measure any different. Edit: compared to the CCS that the BHSE uses. I still prefer the original CCS. Edited December 10, 201411 yr by luvdunhill Report
