micon21 Posted July 21 Report Posted July 21 (edited) Earlier I asked about the adequacy of Mouser. We discussed the STN9360. Today I took the MPSA06 out of the package. I measured the hFE and again was surprised by hfe= 438. According to the datasheet hfe= 100. I had three PZTA06's and they show hfe=207. I will have to use c2240, they show hfe=241. I am shocked at hfe=438..... Edited July 21 by micon21
Craig Sawyers Posted July 21 Report Posted July 21 I have well over 100 MPSA06 (don't ask). I've just measured a random sample of a dozen or so. Many are loose, and many are on bandoliers. Measured on a Peak DCA75, all the ones I measured were in the range 135-180 at 5mA Ic. 438 seems high. But Mouser is a five-star excellent supplier - I've used them for years. Although the hFE seems high, it might be an outlier. How did you test it?
Craig Sawyers Posted July 21 Report Posted July 21 Well it really does depend on what you test. I've just run some of my stock of C2240's and they are all high. The one I've just put on the Peak is 453. Sa am I surprised at 438? Well not in the least given the above C2240!
micon21 Posted July 21 Report Posted July 21 53 minutes ago, Craig Sawyers said: I have well over 100 MPSA06 (don't ask). I've just measured a random sample of a dozen or so. Many are loose, and many are on bandoliers. Measured on a Peak DCA75, all the ones I measured were in the range 135-180 at 5mA Ic. 438 seems high. But Mouser is a five-star excellent supplier - I've used them for years. Although the hFE seems high, it might be an outlier. How did you test it?
micon21 Posted July 21 Report Posted July 21 (edited) 16 часов назад Крейг Сойерс сказал: Ну, это действительно зависит от того, что именно вы тестируете. Я только что прогнал несколько своих C2240, и все они показали высокий уровень. Тот, который я только что поставил на Peak, — 453. Разве я не удивлён 438? Ничуть, учитывая вышеприведённый C2240! let's compare our devices when measuring 3675. I assume you have it. Edited July 22 by micon21 надо
Craig Sawyers Posted July 22 Report Posted July 22 That is about right for a C3675. You seem to be jumping around with what you measure. MPSA06, C2240, C3675. I've lost track of what points you are making.
micon21 Posted August 3 Report Posted August 3 I warn you in advance. I am not happy with the purchase from Mouser. I bought several parts from digikey - 9360, 004, 06, 56. They will arrive around August 11. I am very interested in what I will see on the 9350 case, and what the device will show - in hFE mode.
JoaMat Posted August 4 Report Posted August 4 Please be careful with words. I do believe Mouser is a reliable company. 3
Craig Sawyers Posted August 4 Report Posted August 4 Yup. Totally agree JoaMat. I've placed orders with Mouser for decades with zero problems. If Mouser keep an eye on forums, or as a lurking member, Micron21 could end up in hot water. I used to be list admin for a Jaguar forum with 10,000 international members. And occasionally a list member would openly criticize a supplier. But all the major Jaguar parts and service outlets lurked as members on the list. So threats of legal action for defamation were regular, including to the list owner (me). I quit as admin because the stress of being potential sued was too much.
micon21 Posted August 4 Report Posted August 4 (edited) I showed you a photo of the transistors and the gain of the transistors that arrived. I am NOT happy with the big difference in measurements between the datasheet and what I see from the transistors from Mouser. I spent extra money for comparison. I made a test purchase from Digi. I will write the results. Edited August 4 by micon21
micon21 Posted August 4 Report Posted August 4 to achieve additional truth, I bought a device that was recommended to me on our forum - DUOYI DY294. I am waiting for the arrival of both DigiKey and Ali
micon21 Posted November 21 Report Posted November 21 (edited) A small factual statement. I saw in the thread that forum members are also using inexpensive EL34 models, like the Tung-Sol. There are photos of German RFTs and Russian Mullards. I currently own all of the listed quartets. When listening, I noticed that the Mullards (2015) sound significantly better. Edited November 21 by micon21
GeorgeP Posted November 21 Report Posted November 21 9 minutes ago, micon21 said: I saw in the T2 thread that forum members are also using inexpensive EL34 models, like the Tung-Sol. There are photos of German RFTs and Russian Mullards. I currently own all of the listed quartets. When listening, I noticed that the Mullards sound significantly better. It has been a while since I bought them, but the Russian Mullards worked very nicely in the T2, to the point where the benefits of pricier NOS tubes were marginal. 1
mdr30 Posted December 1 Report Posted December 1 Is it possible to use E88CC instead of ECC88 in this T2? They have similar ratings but also some differences.
jamesmking Posted December 1 Report Posted December 1 (edited) 18 minutes ago, mdr30 said: Is it possible to use E88CC instead of ECC88 in this T2? They have similar ratings but also some differences. yes ecc88, e88cc and 6922 can all be used. I believe the e88cc is similar to a 6922 - which is what I have been using in the T2 for years. Edited December 1 by jamesmking
jokerman777 Posted December 1 Report Posted December 1 Some if not all 6dj8/ecc88 datasheet has spec'ed max plate voltage at 130V, which the top tubes operate right around that range, I'd think e88cc/6922 is actually safer bet.
mdr30 Posted December 2 Report Posted December 2 Great. My build is proceeding slowly but well under the safe supervision of MLA. Four Mullard E88CC lie waiting in the box.
