January 8, 201016 yr comment_313179 The AX-7e is another great integrated. I only heard it with one pair of speakers though.That was mean. It made me laugh. I don't see a budget/price/cost mentioned. Fisher? I'm going to continue to flout Musical Fidelity because I love them so much: Nu-Vista M3 or Tri-Vista 300 (both were said to be able to drive my Dynaudio 4 ohm speakers, despite not stating so in the specs). Amazon.com: Musical Fidelity A5.5 Integrated Amplifier: Electronics AudiogoN ForSale: Musical Fidelity A-1001 Other manufacturers that I would recommend: AudiogoN ForSale: Cambridge Audio Azur 840 A v2 (except, you know, zero feedback) AudiogoN ForSale: Cambridge Audio Azur 840A v2 AudiogoN ForSale: Marantz Reference PM-KI-pearl Report
January 10, 201016 yr comment_313903 The Channel Islands D-100s look decent, but you'll need a preamp or line controller for volume control. Report
January 10, 201016 yr Author comment_314043 Ta guys. I bought an Exposure 2010S off Agon and will give that a shot. Nonetheless, if anyone sees a silver Primare I30 going used anywhere, please holla. Report
February 22, 201016 yr comment_328076 The Monarchy blows the Micro away. I have owned both. Unless you upgrade the Micro's power supply, then the Monarchy goes into the corner and sulks. Bump ... I'm going to be using a GS-1 for a preamp so I'm in the market for a small amp. I'd like to know more about this Monarchy and Micro comparison you both posted about. Morphsci, what were the power supply upgrades for the Micro? Report
February 22, 201016 yr comment_328120 A little OT, but I have a quick question that those here can probably answer for a speaker n00b. Does the F5 have enough juice to power the Harbeths? Report
February 22, 201016 yr comment_328126 Bump ... I'm going to be using a GS-1 for a preamp so I'm in the market for a small amp. I'd like to know more about this Monarchy and Micro comparison you both posted about. Morphsci, what were the power supply upgrades for the Micro? The micro system was two being run as monoblocs with a custom external PSU that was bigger by about 50% than both amps combined. I would look at the price but in reality a Monarchy may be a safer bet especially if it is a newer one. The micro's are starting to get a little long-in-the-tooth so may be in for some refurbishing depending upon how hard a life they have led. Report
February 23, 201016 yr comment_328318 The micro system was two being run as monoblocs with a custom external PSU that was bigger by about 50% than both amps combined. I would look at the price but in reality a Monarchy may be a safer bet especially if it is a newer one. The micro's are starting to get a little long-in-the-tooth so may be in for some refurbishing depending upon how hard a life they have led. Thanks. I'll keep an eye out for a Monarchy. Looks the Pro version is the one to get. Report
