Compact, medium power speaker amp?
The AX-7e is another great integrated. I only heard it with one pair of speakers though.
That was mean. It made me laugh.
I don't see a budget/price/cost mentioned.
Fisher?
I'm going to continue to flout Musical Fidelity because I love them so much:
Nu-Vista M3 or Tri-Vista 300 (both were said to be able to drive my Dynaudio 4 ohm speakers, despite not stating so in the specs).
Amazon.com: Musical Fidelity A5.5 Integrated Amplifier: Electronics
AudiogoN ForSale: Musical Fidelity A-1001
Other manufacturers that I would recommend:
AudiogoN ForSale: Cambridge Audio Azur 840 A v2 (except, you know, zero feedback)
AudiogoN ForSale: Cambridge Audio Azur 840A v2
AudiogoN ForSale: Marantz Reference PM-KI-pearl
  • Replies 59
  • Views 13.1k
The Channel Islands D-100s look decent, but you'll need a preamp or line controller for volume control.
Ta guys. I bought an Exposure 2010S off Agon and will give that a shot. Nonetheless, if anyone sees a silver Primare I30 going used anywhere, please holla. ;)
The Monarchy blows the Micro away. I have owned both.
Unless you upgrade the Micro's power supply, then the Monarchy goes into the corner and sulks. :D
Bump ... I'm going to be using a GS-1 for a preamp so I'm in the market for a small amp.
I'd like to know more about this Monarchy and Micro comparison you both posted about. Morphsci, what were the power supply upgrades for the Micro?
A little OT, but I have a quick question that those here can probably answer for a speaker n00b. Does the F5 have enough juice to power the Harbeths?
The micro system was two being run as monoblocs with a custom external PSU that was bigger by about 50% than both amps combined. I would look at the price but in reality a Monarchy may be a safer bet especially if it is a newer one. The micro's are starting to get a little long-in-the-tooth so may be in for some refurbishing depending upon how hard a life they have led.
Thanks. I'll keep an eye out for a Monarchy. Looks the Pro version is the one to get.
