robm321 Posted May 12, 2023 Report Posted May 12, 2023 I'm getting tendonitis just thinking about it. 1 2
Aura Posted May 12, 2023 Report Posted May 12, 2023 not ready to do final P100 comments yet until i do some espresso for a period of time but just dropping in to say apparently “burr break in” is a real thing. in the past few weeks the amount of fines has dropped considerably on all of my various beans and i feel like i’m nearing the final state of these burrs and ease of use in purging between doses. which is to say - no purging. there is nothing left from each dose. it is completely zero retention. 2
EdipisReks1 Posted May 16, 2023 Report Posted May 16, 2023 (edited) My opinion is that “burr break in” is basically just nooks and crannies getting filled with coffee oil/debris. That’s a pretty substantial physical change; I can see it making a difference, even if I haven’t noticed it particularly with my own gear. How are you liking the grinder in general? Have you been doing pour over only? This grinder is probably more than I want to spend, but it’s on my list of considerations for if I upgrade. Edited May 16, 2023 by EdipisReks1
Augsburger Posted May 16, 2023 Report Posted May 16, 2023 (edited) On 5/12/2023 at 5:24 AM, EdipisReks1 said: 40 grams in a hand grinder would be rough! I gave up hand grinding once I got married. Edited May 16, 2023 by Augsburger 4
EdipisReks1 Posted May 26, 2023 Report Posted May 26, 2023 With the new pricing I think I’ll be getting the single burr Duo and the SSP MP burr. Also I should have my espresso machine back in a couple weeks! 1
Spork Posted June 20, 2023 Report Posted June 20, 2023 I prefer beans that have aged a week or 2 after roasting, I find they have a more mellow flavour than freshly roasted. But - they must be freshly ground. That means pods are out for me. You don't need a high-end machine for great results, my machines (one in the kitchen, one in my camper) are identical. So get a decent machine and get it dialed in to make coffee the way you love. (Most of the people I go camping with also seem to like coffee the way I make it). 4
robm321 Posted June 20, 2023 Report Posted June 20, 2023 Interesting. I prefer them roasted within two weeks. Agreed, they do mellow out but also taste old and the bloom is usually flat.
grawk Posted June 21, 2023 Report Posted June 21, 2023 it definitely matters on the coffee and roast type for how long it takes to get to ideal and when that drops off. 5
HemiSam Posted July 11, 2023 Report Posted July 11, 2023 I tried the Intelligentsia coffees for the first time. Very good! I will be buying from them again. HS 5
EdipisReks1 Posted July 14, 2023 Report Posted July 14, 2023 On 7/11/2023 at 7:40 PM, HemiSam said: I tried the Intelligentsia coffees for the first time. Very good! I will be buying from them again. HS Black Cat is my “house” espresso. It’s good stuff. Breville can’t be fixed. The steam boiler has a failed weld. Looks like it was bad from the factory. You can’t get the part, unfortunately. Now I need to decide what I replace it with. I’ve been happy with the Flair 58 for espresso, but I miss milk steaming. I could just get another Breville Dual Boiler, but build quality leaves me a bit shy to the idea. I really liked the machine, though. I’m guessing either a Mara X or the Argos Odyssey, probably. I guess it depends on whether I want a cup warmer or not. 1
grawk Posted July 14, 2023 Report Posted July 14, 2023 I found another blueberry bomb. Yemen: Mocca Mattari, Sana’a Governorate from Coffee Bean Corral It's very yummy. I have another one that I have more of to try roasting next. If that one turns out well, I'll offer it for sale. 3 2
EdipisReks1 Posted July 29, 2023 Report Posted July 29, 2023 I think I’m just going to get another Breville Dual Boiler. A new new one, with a warranty, that they will still support. I’ve also decided that I neither need nor want a new grinder. I think not having an electric machine for a while got me past the FOMO and GAS over the Niche Duo. I’ve been pulling just delectable shots with the Niche Zero and Flair 58. 3
HemiSam Posted July 29, 2023 Report Posted July 29, 2023 Approaching two years that I purchased the Lelit Bianca. I ultimately plumbed it directly to water and added a filtration system to make it simpler. This thing is a tank. At first I was using it a few times a week. it's almost a year I use it almost daily. So time for a service and it was good to see how clean things were. Replaced the group head filter and gasket. Gasket was hardening but not brittle by any means and the IMS filter looked very good given usage. Included is the replacement group head filter. The original gasket is in black and 8mm. I bought both 8.0 and 8.5 and the original size was best. Very little to clean under the filter. And finally the product I use to perform backlashes every 1-2 months (mostly latter...). Happy brewing... HS 3
HemiSam Posted July 29, 2023 Report Posted July 29, 2023 Reading Jacob's post and realized I forgot to include the actual machine...LOL. So surprised how well it's held up simply by using terry cloth and water after uses. 3 1
HemiSam Posted July 29, 2023 Report Posted July 29, 2023 Filter setup in case it's of any use to anyone. Houston has very hard water. HS 2 1
EdipisReks1 Posted July 31, 2023 Report Posted July 31, 2023 (edited) I sourced a replacement steam boiler, so I should be back up and running after it arrives from Australia and I have it installed. $150 plus repair cost is a lot cheaper than a new one! That is sweet, Sam! That machine still looks amazing, and plumbed in is living the dream! Edited July 31, 2023 by EdipisReks1 2
HemiSam Posted July 31, 2023 Report Posted July 31, 2023 Nice score, Jacob! I took a hard look at those machines and almost pulled the trigger on one. HS 1
HemiSam Posted July 31, 2023 Report Posted July 31, 2023 The latest from Intelligencia. I somehow managed to forget the Black Cat...ugh. Picked up some Hidden City espresso roasted by Oak Cliff out of Dallas. Sourced from a small local shop that does a nice job. Tasty. HS 1
EdipisReks1 Posted July 31, 2023 Report Posted July 31, 2023 I’m interested in knowing how those two beans are!
HemiSam Posted July 31, 2023 Report Posted July 31, 2023 The blend is tasty, Jacob. I’m using it with the chemex. The blueberry and honey are there, but it’s not the blueberry bomb I’ve had in years past out of Ethiopia. I’ll provide thoughts when I get to the Guatemalan. HS 1
EdipisReks1 Posted August 11, 2023 Report Posted August 11, 2023 Picked up an open box BES920XL for about 2/3rds retail. I’ll be back up and fully running soon, hopefully! 3
HemiSam Posted August 11, 2023 Report Posted August 11, 2023 Awesome news, Jacob! I bet you'll get many a year out of the replacement. I opened the single origin Guatemalan Francisco Martinez from Intelligencia and it's very good. The dry cherry notes definitely jump out at you. It reminds me a tad of the Yemeni cherry bomb coffee from the Austin joint that was recommended I believe by Voltron? Not as refined as that but similar first note. HS 1
EdipisReks1 Posted August 11, 2023 Report Posted August 11, 2023 That sounds really good. I need to buy some new beans; I’ve just been drinking Black Cat the last couple months.
