What are you Grilling now?
So I wanted some new year pork belly... Loaded up the grilla with three chunks.
At about 9pm last night they were hovering around 180 degrees. I was going to give it another hour and give it a check.
Well I had walked out to a grease fire happening. Pulled the pork (what was left of it) and put out the small fire.
Some cosmetic damage:
and three pork briquettes.
The middle one might have some salvable pork on the inside. I will deal with that later.
I need to clean everything up because I have a slab of salmon to smoke up.
Happy New Year! 🥳
  • Replies 899
  • Views 204.3k
  • I did sous vide picanha for the first time today. A simple rub of spices, smoked salt and olive oil, then cooked in the bath at 133F for 6 hours. The 'grill' part comes from very briefly finishing on
  • shellylh
    shellylh
    Having an infrared side burner on the grill is pretty fucking awesome. Thanks for the tip Marc. Indirect heat @225F for 30 minutes and then a 30 second sear per side on the infrared burner.
  • Smoked chuck roast. Much better than I expected. And a great excuse to use plenty of horseradish cream sauce.
Shit, Mikey.  I've read a few stories about grease fires but that's pretty extreme.  Do you think it was just from the belly or was there some built up grease from the grill/smoker not draining properly or something?  Regardless of root cause, that sucks.
I think it was a combo effect. I thought I cleaned the drip tray and dump trough after my last brisket, but probably not good enough. The belly was good and fatty, so there may have been more juice than previous runs. And there seemed to be more dust in the pellet bag when I was filling the hopper. So this may have led to it throwing more sparks than normal with the blower. I have sifted pellets previously to reduce dust, not this time.
So - I will clean more thoroughly, sift my pellets, and buy less fatty belly (the last one will not happen).
On a positive note. After cleaning, I ran it up to 500F and back down, no issues, then smoked a lovely slab of salmon (not pictured). It worked like a charm. So the my thoughts on it just being cosmetic seems to hold out for now. I will pick up some high temp paint to give the open metal a coat.
Also as a side note, since I setup fiber internets I didn't put the grill on my network yet. The app would have told me if it got to cold, or in this case too hot. So adding the grill to the network is another task.
:sadcat:
My heart almost broke. So glad for that last bit.
Couple of coats of high temp engine paint.
Looks like poop, but it is protected and ready to go. Ran it at max temp for a while to cook of any vapors, then smoked a salmon.
I'm back...
  • 4 weeks later...
12lb American Wagyu Shoulder.
SnP only. 12 hours @225.
Good smoke. she'll eat.
Edited by mikeymad
  • 3 months later...
On 7/4/2026 at 3:51 PM, Grahame said:
The first 3 were that good?
Did you see the picture? Of course they were that good! Are you really Doug trolling us?
'Murica
Resistance is futile. You will be assimilated.
Starting off gently with what the Australians would call "a sausage sizzle"
Spousal approval achievement unlocked.
PXL_20260922_000014331.jpgPork experiment. Hatch Chili pork butt. Pre-Seasoned wet rub from Costco.
14 hour low temp smoke on the pellet grill, the last 3 hours wrapped in paper. and then rested for 2 hours. Shredded just a couple handfuls for supper.
1792870494502.jpgShouldn't this be in the baking thread? Well technically both.
I tried an experiment. A pretty standard sourdough mix at 78% hydration. Formed yesterday, sat overnight in fridge. Baked this morning on pellet grill.
I use a cast iron dutch oven/combo cooker. I heated the grill to 500 with the cast iron. loaded and scored the bread lowering the temp to 450. I took it out of the cooker and baked in the grill at 350 for an additional 30 minutes.
The oven spring wasn't great but good enough, And I probably could have baked it a little longer. But there is a decidedly Smoky flavor to the entire crust. I'm not sure if I would want it all the time but it's pretty darn yummy.
Why can't I stop drooling?
