- Today
It's probably a sort of pilot project - if they don't lose their shirts on Type I, maybe they'll fire up Chromium and Metal cassette production later. And what is this stuff for, anyway? Hobbyists, or real music production work? Will most of these tapes go into cheap Tanashin-knockoff Chinese cassette players? Are we playing with analog for analog's sake - should a new cassette transport include noise reduction like Dolby S or is it a solved problem already (Digital Compact Cassette)? Wouldn't it make sense for a new cassette transport to use direct drive instead of belts and fewer parts for reliability? I'm putting this Nakamichi Dragon vs. LX-5 comparo and a boombox review below just for reference - there is a small niche market emerging...
- Yesterday
But only Type 1 / Ferro ? "The cassette tape used is the latest production and is manufactured exclusively for Revox. The excellent analog sound of the new Revox cassette tape is made possible by the legendary Grandmaster formula. This Revox cassette gives the best results with the Ferro/Normal Position Type I setting on your cassette player." https://www.horchhouse.com/en-us/products/grandmaster-c90-empty-cassette Disappoint. No Metal? Compact Cassette tape types and formulations - Wikipedia https://en.wikipedia.org/wiki/Compact_Cassette_tape_types_and_formulations tapeheads.net/threads/cassette-type-1-2-3-4-strengths-evaluations.2999/
I thought this was worth mentioning - Revox announced they are selling new audio compact cassettes, Type I C60 and C90 - what a crazy time we live in: https://www.theabsolutesound.com/articles/new-blank-cassettes-now-available-from-revox/
dsavitsk replied to Knuckledragger's topic in Miscellaneous
I truly don't get why Stax didn't just modernize the SRM-002. Make it all SMD, add a couple of li-ion cells, a bluetooth receiver and just profit. Make it in a nice plastic housing with both a 5 pin output and the 002 plug. No stupid USB input which just complicates everything.
Hahaha, ok, now it’s clear, apparently my neurons decided to slack off for a bit
Hehe, I should have been more specific but they have stopped production of them. No replacement for the SRS-002 as they hope people will use the SR-003Mk2 with the D-10. That makes 30 years of continued production of the portable system coming to a close.
Are you talking about yours earspeakers? Any details, what happened?
In other Stax news, the SR-009S and SRS-002 are both dead now.
EdipisReks1 replied to Knuckledragger's topic in Miscellaneous
- Last week
pioneer a09 clone zero feedback output buffer
clever huh? first time i have seen this. what it really is, is some local feedback around the current mirror. the lower impedance load forces the current source to supply more current to the drive of the output transistors. all those output transistors in parallel really form an extremely stiff drive current without global feedback. in single ended form, perfect for low impedance ribbons. and 30v/10a switchers are cheap. lot of heat however, 1.5 amp bias current. (total) i have a single ended gain stage to go with it. basically half of the balanced version with a cfa capable input section. input section can have local feedback as shown. or remove that resistor. updated to current version pioneera09pre.pdf -
Funny:) I think for the existing AIs it is easiest to be funny than design a working circuit. There are a lots of funny people in the internet for source. How long?
i have not think it will design the circuit this AI is a chatting machine learn from all the chats from the internet. (my keyboard is bad so there will be mistakes) I read about AI circuit design it exists. But it is f*cking good from this standpoint. I think I found its main source for the circuit but the result was not the same. I was awed but I like it because I can use it not for this day to day.
AI is not yet at the stage where you should trust the answers given you. For example, I used an AI to translate an algorithm (Reverse Bits in Word by Lookup Table on this "Bit-Twiddling Hacks" page) to Rust, and the values in the lookup table that it came up with -- it had trouble converting the macros to values, plus it didn't use macros -- were wrong. Fortunately, I know Rust well enough to have vetted and corrected the answer, but I feel the same needs to be done for everything -- let it suggest to you, but don't copy and paste the answers, make sure you understand everything it's doing with its solution. That said, it can be a very powerful tool -- I used the entire translation (fraction of a second) and vetting process (an hour or two at the most) as a learning experience. I would recommend you do the same with your efforts. E.G. don't assume that the fault was yours, make sure you understand exactly what the fault was, and learn what it would take to fix it. Or if it was the AI's fault, learn what it would take to have caught it before building the circuit.
jokerman777 replied to kevin gilmore's topic in Do It Yourself
Curious what's the purpose of Q1/Q24 pair? The configuration seems to improve thd noticeably. -
I do not remember I ever started a topic but I am here for a decade or more. I am playing with google AI for a time and I like it. I left out chatgpt so this is new for me. I liked to think I am good to search info from the internet but this thing is so much better. Specifications, go not go situations with some equipment so much easier to resolve. I was curious I asked to design a opa548 virtual ground circuit for me ( this is why diy) and I built it. Not so complicated circuit, I built it and almost worked. The problem maybe was the messy breadboard not the AI, a pin had to be grounded to stabilize the opa. I was a software developer, supporter all my time so I know this AI something like a mirror for as so it is about as stupid as us.
(waits for another Alton Brown post before posting another American Gods post)
So sad about the Reiners..... What a legacy Rob is leaving.... RIP as well to the victims at Brown University and in Bondi Australia. I think we need aliens to come and spray the earth with "let's get along" mist. This is a fucking crazy world.....
R.I.P. Meathead. He sure brought joy to my life.
Alternating subjects continued. I liked American Gods as a bit of a guilty pleasure kind of show, but I'm not sure if we finished it or not.
