This stream auto-updates
  1. Today
  2. Whelp, I got through half of it, but Bloomberg had it taken down before I could make it to Friday. So... how does it end?
  3. Love you guys. Put in some decently hard work this week. 46 mile gravel loop Sunday around the seacoast, a few runs, and the back/forth commute today add up to over a 100 mile week and it's only Thursday. I'm a little over half way to my fund raising goal. Onward. Upward.
  4. Roberta Flack & Donny Hathaway by Roberta Flack (1972) https://album.link/ksm7qv8qvcfv0 Example: Holy poop!! What a great album.
  5. RIP Brent Hinds of Mastodon Died in a motorcycle crash
  6. Yesterday
  7. Chicken or Beef? Decisions Decisions. Technically, that's Cottage Pie.
  8. Yes, I noticed that too. But I found those machining marks only on the inner rear panel, left and right sides. The rest of the chassis looks clean. I’m pretty sure they just used 3-axis machining, which is still miles better than what I could do on my home-garage CNC. Of course, 5-axis is another story, and I’ve been thinking about designing some more complex curved surfaces where 5-axis paths would actually make sense. Overall though, I’m quite happy with how this chassis turned out. I haven’t yet checked all the PCB mounting hole positions against the boards, but so far it looks promising.
  9. I guess the machine shop cheaped out and didn’t use 5-axis tool paths for those steep facets. Otherwise we wouldn’t see the tool marks after heavy sandblasting. This should really have been a cast part. No objections from the environmentalists from the other side of the pond? I’m surprised.
  10. I've posted this artist before, very smooth voice and nice writing....just an easy and joyful listen.
  11. The original Jecklin Float Electrostatic headphone wasn't much chop sonically - yes it had vast, bright dynamics, but at the expense of no bass whatsoever. Also, no-one in their right mind would wear these anywhere near a camera. They didn't hold a candle to any version of the Stax Sigma or Sigma Pro and so they were sold.
  12. RIP to Frank Caprio, the "Kindest Judge In The World." I've seen a lot of his videos, and some of them brought me to tears. https://www.nbcboston.com/news/local/nicest-judge-frank-caprio-dies/3793798/
  13. Done a while back, just putting this to the top of unread 😊
  14. Good riddance.
  15. I aim to please!! I think these are old though... but can't find anything on them.
  16. New Doc just dropped - I am busy for the next 4 hours.
  17. I was hopping that the latest version will be a lot better than the old I still have ... and not using. Now my hope was killed by Spritzer, thanks!
  18. jpelg
    Deals
    ^I was today-years old when I found out this type of thing existed!
  19. the power supply is clearly labeled as +350 and -350. so an absolute maximum of 1400 volts peak to peak stator to stator. which is 500vrms. not 630 vrms. the same as every stax amp with these power supplies. srmt1 all versions, srm717 srm727 etc. looks almost identical to the koss circuit with bipolar outputs replacing the mosfets. push pull. no idea of maximum output current. lots of opamps with huge amounts of feedback. if its cheap enough, might be worth it. probably not.
  20. Focus on the Family founder James Dobson croaked. Suddenly I'm in the mood to say good things about Hulk Hogan, if you take my meaning.
  21. Hehe, this unit was never set to 115V so unless it was natively 230V, I'd doubt it. There are a few of these floating around out there though, at least 4 have sold in recent months and this one was by far the cheapest.
  22. The pics are too low res to make any values out but it looks like it is multiple opamp stages feeding into a low power push-pull stage. I wouldn't call that reference in anyway. The person doing this doesn't seem to understand RMS values and that bias supply is super sketchy... None of those resistors are rated for that voltage. Clearly voltage divider into RC filters but one 2010 resistor to ground and the ballast is a 1/4W unit? Yeah... no.
  23. Ouch, what a state of the art chassis! Lamborghini-class, congrats!
  24. I’m up here at 12,000 feet, eating a bagel while tweaking my amp. Altimeter says it’s all good.🤞 And you know what, if you’re interested, I actually have an upcoming spare CNC chassis set (one PSU case and one amp case). I’d be more than happy to send it your way just for fun, freely. Let me know your thoughts.
  25. Fascinating chassis work. How about the scale of the altimeter? Small pointer one lap 1200 feet, two laps 2400 feet?
  26. In the past few months, I haven’t been idle. Besides finishing a T2 Mini, I also continued to refine the GG chassis design. Through these experiences learning 3D design, I decided to completely re-draw the CAD files and hand them to a professional factory for prototyping (yes, I don’t believe a hobbyist garage CNC can really handle this job☹️). Below are some photos of the sample unit. This time the chassis is fully CNC-machined, which is why you can see the extremely thick panels and the more complex geometric structures compared to earlier versions. The side heatsinks are not separate parts. They are directly CNC machined into the chassis walls. At the same time, the bottom cover is split into two independent left and right plates, each with a grid-style cutout design. You can remove only one side of the bottom cover to do testing or adjustments without disturbing the entire chassis. The grid pattern reduces weight while maintaining mechanical strength, and it also improves ventilation inside the chassis. More updates will follow soon.
  1. Load more activity
