This stream auto-updates
  1. Past hour
  2. In my opinion the current prices on ebay for a Keithley 2015thd are rather high. Some of its more interesting features are only available via gpib and the programming guide has multiple errors and omissions and does not in some cases give vital information which means figuring out simple things like how wide in Hz a FFT bin is, is a real pain in the **** - and the width varies with the fundamental frequency in non-linear way. Keithley provide no software or programming libraries and so you are left on your own. You can't even get the frequency of a bin or ask for the bin at a certain frequency on the 2025/6thd (you can on the (2015/6P) which seems crazy. The user interface on the keithley is not that intuitive. Due to some (I assume) design limitations it only has as a maximum of 1023 fft bins which limits its resolution and for fundamental frequencies less than 60hz it can't differentiate noise from distortion since the bin width is the exactly the same as the fundamental, i.e. EVERY bin contains distortion and there are no noise bins. Despite this it will give you a thd+n result for a fundamental of 50hz with no warning that its actually a thd without n calculation! If you set the keithley up with filters or limit the number of harmonics the keithley can not provide unfiltered results. i.e. it only shows on screen and passes to a program the filtered results. There is no way to get at the raw readings. So from a programming point of view its often better to do a full fft and the calculate the thd, thd+n, sinad, noise and apply filters in software than rely on the keithley to do it. On the thd version the fft automatically locks onto the highest bin as the fundamental and if there are two highest bins this causes issues. The fft on the thd has no reliable way for you to manually specify the fundamental frequency, there is a hack but you can only specify a sub multiple of the fundamental frequency in the range 20-68hz and even then the fft is not as clean as automatically locking. The harmonic calculation is limited to 64 harmonics regardless of how many harmonics are present in the fft. there are also some firmware bugs (at least in the firmware I have) and there seems to be no reasonable way to get new firmware. The built in signal generator only goes from 10hz to 20K and has a surprising amount of jitter and at 20 hz it can output 19.Xhz which causes issues. The thd/thd+n and sinad only accept fundamentals from 20hz to 20K and at 20Khz there is only the fundamental and 1 harmonic since the fft is hard bandwidth limited to 50khz. Noise calculations are limited to fundamentals in the 60hz-20K range. In short the Keithley shows its age and requires a lot of programming and reverse engineering to understand what's actually going on under the hood. The 2015P and 2016P remove many of the programming limitations of the 2015/6thd and it would be interesting to know if a thd could be upgraded to a P model - it might only be a firmware change since the thd programmatically seems to be a gimped P with certainly very useful programming features missing. Unfortunately the P models are double the price of the thd...
  3. Today
  4. I'm a 30/32 guy on the road. I think my Roubaix maxes out at 32 and that's what's on it now. I have a pair of 30s in reserve for when those wear out and won't sweat the difference.
  5. Yesterday
  6. Tried 40s now trying 28s. These feel faster for sure but not sure how they'll do on shittier roads and more challenging decents. Thinking the sweet spot for me might be 32s.
  7. You know, I normally hate harsh vocals. But every once in a while, it brings me joy. Like this. (And Nemophila.)
  8. Unifi is great, but often it's hard to get their equipment because of high demand. They've been steadily improving on the software management side, too.
  9. robm321
    Get your game on!
    Now that's commitment
  10. I don't use mesh but I will definitely also recommend Unifi. I have a Cloud Gateway, a U6 WAP and one of their switches. The whole system was a dream to setup and piecemeal upgrade-able should I need it. No required subscriptions or cloud BS either for the security-minded folks.
  11. Last week
  12. Look into unifi wifi https://ui.com/wifi It's meant for covering a large area with easy integration of multiple access points. You could put one access point in the main house and another in the loft over the garage and you should have excellent coverage everywhere. You would need to install the controller on your computer to set everything up, but once it's running you don't really need to do anything else. It would also give you the ability to easily monitor it all while you're away. You could continue to use the current router, or you could use a unifi router (I have an extra in a box that I never opened of you want it).
  13. I have Orbi and Asus ZenWifi setups in different places, now I need one for the Michigan compound. Old Apple Airports have gotten us this far. From reviews and best lists, the top contenders seem to be Eero and TP-Link Deco. For what it's worth, here's the main challenge: There are three separate buildings in the compound, the main house with the cable internet connection is down slope from the three story shop/garage/loft set into the slopes and lastly another cottage across from a garage. The in-laws have hard-wired ethernet cables running to two both ends of the main house and the top floor loft in the middle building. The biggest challenge is getting a decent signal to the third building from the second story loft. We do not have major demands or multiple smart devices -- people just want to be able to stream video in all three locations. Either I just leave the main house the way it is and try a modern mesh system between the loft and the cottage or I try to have a single mesh system with at least one unit in each building and hope they bridge. I'm not sure if it makes sense to connect mesh units by ethernet where possible or if they only are meant to bridge between themselves wirelessly. Any thoughts are appreciated on the approach and favorite brands/models.
  14. I had some interaction with Dr. Gilmore a few years back discussing what kind of tests to perform on a DIY T2 that I had started, 7 years ago was it? Don't recall. Thanks for giving the info on methods to test electrostatic amps, I'll post those on Audio Science Review there are actually people there curious about this, and yes I know Amir (the main guy) has a hard time thinking beyond his accepted paradigm of using a klippel robot to test speakers (doesn't work with Magneplanars but he can't see that) and testing amplifiers into load resistors. However he's not the only one on the site with an interest in testing things, and there isn't much info out there about PROPER testing of amps for electrostatics. I would LOVE to see some actual published test results on the "better" designs you have come up with as compared to the venerable Stax amps, but I can't find any such. I would have thought that Spritzer's Mjolnir Audio site would have published some test results, but I haven't found any.
  15. I'm heading in to work tomorrow at 3am to trigger the time lapse camera that I setup this afternoon using my A7IV. If all goes to plan it'll take at least 3000 still frames over a 24 hour period and not fall from the sky (it's mounted ~100' in the air). It's on a smallrig mount with multiple tethers so it shouldn't be capable of flight and should be rigid enough to be stable/consistent throughout. If I get the video cleared for public release I'll post it.
  16. RIP Marjane Satrapi, director of ‘Persepolis’, “who died of sadness a little over a year after the death of Mattias Ripa, her husband and the love of her life” https://www.hollywoodreporter.com/movies/movie-news/marjane-satrapi-dead-persepolis-director-56-1236613671/
  17. miloz never contacted me. i would likely not respond if he did. get one of each of these from ebay. keithley 2015 6.5 digit thd multimeter and a hp 82357b (or later) usb to gpib adapter. yes, the 82357b is a fake coming out the wrong end of the agilent factory (no shielding on the plastic) in china. but work absolutely identical to the real one which is about $600 new. unlikely to pass fcc radiated noise tests and a windows 11 laptop. then contact james king for the software package. ebay price about $600 total for the 2 pieces. (about $7k brand new) have at it. rated for 2000 volts peak to peak. no attenuators or other hacks needed. many of the used 2015 will require replacement of the display for about $75, and unsoldering about 100 connections. but the software does not require a well lit display except to put it into the right mode after you turn it on. accurate to .002% Thd+N. built in balanced signal generator that matches the same specs. single box solution. better than any stax amp with 50 to 60db of gain. the Noise component overwhelming the signal. no way i would pay $35k for an audio precision and then pray that the required attenuator does not cause trouble. I would much rather pay that much for a set of CCB brakes and wheels. retired 9 years now. i only do things that are fun. like 30 to 130 in the Z06. over and over and over. and yet no tickets (yet).
  18. Which has probably been bounced back as that is not my domain name.
  19. I wrote an email to you using [email protected]
  20. What the actual fuck is this? How is posting in an open forum "reaching out to me"? Copied from the Audioretards forum: Did you send me a PM or an email? No... so how did you reach out to me? Go ask the retard in chief over there on how to test electrostatic amps... as he did such a good job last time. Wasn't the quote something like, how can anybody listen to this as it measures so badly? Yeah... stellar work there.
  21. Oliver Lieb's latest release -- nice background music, pretty much designed for coding/researching/reading/&c. Just energetic enough to energize me; just diverse enough to keep my interest without demanding to be engaged with my frontal lobe. https://oliverlieb.bandcamp.com/album/recovered-frequencies-vol-1
  22. HiWire
    Get your game on!
    It's the biggest Forza Horizon ever... the game world is huge and it's incredible.
  23. Cumbias Chichadélicas 2
  24. Half my Steam friends list is playing FH6 and nothing else at this point.
  1. Load more activity
