August 2, 201412 yr comment_647284 I say go bike shopping for new carbon, and find a better lbs to fix the C'dale. One bike just isn't enough. Also, get a vintage steel Colnago. And a Ti Serotta. That's a good start. **BRENT** Report
August 2, 201412 yr comment_647322 I would think the LBS would know that. Are they somewhat versed in vintage? The drive side cup on English (ISO) threading is left hand thread, and this bike most certainly has that threading. Post 4761 confirms that (1.370 x 24tpi is english or ISO, sometimes marked 1.375 x 24tpi). Remind me again, you were trying to get this out of the Cannondale in order to put different components on the frame? Kroil or Freeze Off would be something to try. If the cup is the type that has wrench flats on it and you have a bench mounted vise with sharp jaws, you can clamp the cup in the vise and turn the frame. Do you have any of the bottom bracket apart? Down to just the fixed cup still in the frame? Do you need the cup? EDIT: You could also try Sheldon's trick tool at the bottom of this. If you could get someone to try it with an impact wrench, might be even better: http://sheldonbrown.com/tooltips/bbcups.html Yeah, trying to get the bottom bracket off to replace it, the current one grinds a bit and the threading for one of the pedals is gone. Everything but the fixed cup is off, and I don't need it anymore. The Freeze Off looks interesting, Report
August 3, 201412 yr comment_647335 Sheldon's bolt thing supposedly works very well. Remember that that cup is LH thread, so CW to loosen. If it were std. threads, you would need a LH bolt and nut to do Sheldon's thing. Get a grade 8 bolt and nut (or whatever he recommends in the link I had attached. Report
August 3, 201412 yr comment_647340 Here's a YouTube video of "the Sheldon Brown method". https://www.youtube.com/watch?v=Oa8ztfXcHkg Report
August 3, 201412 yr comment_647342 About a minute of freeze off, a hammer, and a 25" breaker bar, and it is finally free! And my new bottom bracket arrived today too. . Report
August 3, 201412 yr comment_647348 I just swapped a 9 speed cassette onto a better 26" wheel I picked up, so I think the red white and blue fsr should be rideable. I'll test it tomorrow. I may also need to replace the fork, but I'll find that out soon enough. Report
August 3, 201412 yr comment_647389 Cool Colin! SO that freeze off shit actually works? This was an aluminum cup in an aluminum frame (Cannondale)? Might have to try this on my friend's bike that I so far can't get the drive side crank arm off of. Report
August 4, 201412 yr comment_647462 Definitely aluminum (Cannondale) bike, forget if the old bottom bracket was aluminum or steel threads, but it was 100g heavier than the new one. I ended up switching the derailleurs between the two bikes, so now have all ultegra 6500 on the cannondale, new KMC X9.93 chain, and a new front derailleur cable, and then went out for a spin. Felt good, even though I am still super slow: http://connect.garmin.com/modern/activity/556708808 Report
August 4, 201412 yr comment_647467 Looking at the saddle position I can't help but wonder if you would be better with a zero offset seatpost. Report
August 4, 201412 yr comment_647468 What you should really be wondering is if I have any clue on how to set the fit. Report
August 4, 201412 yr comment_647472 That had crossed my mind. There are a thousand videos on youtube but I like the series from Art's. https://www.youtube.com/watch?v=VrZBjOloChg Report
August 4, 201412 yr comment_647483 I think you should just get a new fit when you get your new bike... And then have them set up the C'dale as well for a few bucks. **BRENT** Report
August 4, 201412 yr comment_647490 I decided to kick my own ass yesterday. 76 miles, 4300ft of climbing including a half mile long section at +10% right in the middle of the ride. I did a bad job hydrating and consequently ended up cramping badly for the last 11 miles. Still managed the whole trip at a bit over 16mph which is a lot slower than I'd hoped but by the end I was just happy to survive. Report
August 5, 201412 yr comment_647580 Sorry to hear that, cramping sucks. Another budget friendly old model bellwether jersey. http://www.ebay.com/itm/281403933254 Black and white with grey side panels and red trim is not as fugly as the last one I posted and it's also available in 2X http://www.ebay.com/itm/281403954371 Report
August 5, 201412 yr comment_647581 Ended up slightly adjusting my seat height and moving it back about an inch based on several fit guides I read/watched. Now my stem seems to be too long, 110mm and I think I need about 90mm. Now that I think about it, I think I moved my saddle as far forward as it is above because I felt too stretched out. Report
August 5, 201412 yr comment_647585 Colin, You might try riding it as-is for a little while to see if you can adjust some. When I first started riding the Calfee it felt way too long but through a combination of riding it more and making some fit adjustments I've got it pretty comfy. Report
August 6, 201412 yr comment_647626 Went for a 27 mile road out of Old Orchard beach. Beautiful area. Nice rolling hills. The garmin 800 did a great job with navigation. This is most of the route I borrowed:https://ridewithgps.com/routes/5203858 [Edit] Route: https://ridewithgps.com/routes/5572087 ..... Edited August 8, 201412 yr by CD44hi Report
August 7, 201412 yr comment_647819 You guys think I should buy this Cycle Cross bike? I really like COMPALANO COMPONENT. Looks pretty sweet from the picture. http://washingtondc.craigslist.org/nva/bik/4607723624.html Edited August 7, 201412 yr by VPI Report
August 8, 201412 yr comment_647941 Did 23 out of old orchard again today! Absolutely gorgeous weather. Then hit the beach until a few mins ago. I could most definitely get used to this )https://ridewithgps.com/routes/5571922 ..... Report
August 8, 201412 yr comment_647956 Nice. I did the trip to work and back again today (41) which puts me near 160 for the week. I'm shagged. Report
August 8, 201412 yr comment_647957 I did the trip to the train and back today (3) which puts me near 9 for the week. I'm on the verge of collapse. Report
August 9, 201412 yr comment_647990 I broke my personal record coming home from work by 5 min yesterday. I have been chipping away at it slowly... http://www.strava.com/activities/177056155 1h35m I set 2 personal best segment times and stayed on the leader-board for a Strava segment. On my Brompton. I'm not sure if my Heart rate is correct as my HRM is all screwed up. Funky firmware update, I think. Report
August 9, 201412 yr comment_648030 Question for you all. My seatpost was stolen yesterday, along with my seat, and I'm not sure of the best way to go about measuring for a new one. Do I just measure the diameter of the hole without the clamp engaged? If it's any help, this is on a Trek Lime Light coaster bike. Thanks Report
