October 30, 201412 yr Author comment_658574 input stage runs at 4ma, so yes it will work the original part was higher capacitance and krell used a 10k pot because of it. 10k part is still a better idea Edited October 31, 201412 yr by kevin gilmore Report
October 31, 201412 yr Author comment_658654 is lsk489 any easier to source? a pair of lsk170's or 2sk170's also works Report
October 31, 201412 yr comment_658656 Biggest problem is shipping fees. The BOM points Trendsetter, but they are charging 4 times the parts price for shipping... Everything works like that from here. Guess I'm not in the good person's little papers ! Nevermind. Report
October 31, 201412 yr comment_658658 So LSK389A (hard to source in old Europe !). I bought from Micross in the UK (https://www.micross.com/ecommerce/shop-default.aspx) Their postage charge is still high, but more reasonable than trendsetter and there is no risk of additional customs charges since it is from the UK. Also, I got my parts delivered within the same week as I placed the order. //UFN Report
November 2, 201411 yr Author comment_658872 notice that 2sk170 or lsk170 are not pin for pin, you have to bend the pins to get the correct pinout Report
November 2, 201411 yr comment_658890 The drain and source are interchangeable. Seems odd, but most jfets have this property. Report
November 2, 201411 yr Author comment_658902 lsk170 and 2sk170 have the gate in the middle, not the either end like the dual. Report
November 11, 201411 yr comment_660078 Have now finished putting the amp together and without the opamp in place I get around 7mV offset on one channel, but around 1.5V on the other. The amp otherwise seems stable although I haven't listened to it yet. Any ideas as to what i need to check to find the problem? //UFN Report
November 11, 201411 yr Author comment_660084 you have to use the servo on this amp. not designed to work without it. you would have to very carefully match the input fets Report
November 11, 201411 yr comment_660091 So nothing out of the ordinary as long as putting the opamp in will zero it out? Was just surprised that the difference is that big based on previous posts here //UFN Report
November 12, 201411 yr comment_660164 1.5VDC? That's a lot and I think the servo can't eliminate that much offset. Report
November 13, 201411 yr comment_660253 Were the inputs grounded (or the pot installed) when making the measurement?So nothing out of the ordinary as long as putting the opamp in will zero it out? Was just surprised that the difference is that big based on previous posts here //UFN Report
November 28, 201411 yr comment_662127 UFN, there is obviously a fault. For a 2N5564 with a data sheet specification for maximum offset of 5mV between the pair, this circuit should see a maximum of 25.6mV output offset for a worst case 2N5564 with the servo disconnected. This thing doesn't need a servo if it's using a matched input pair like the 2N5564. The servo can be removed and a trimmer potentiometer used to trim R3 and R4 to shift the drain currents of the input pair to null the input offset and therefore the output offset. R45 could be removed and R46 replaced with a 750Ω resistor to keep the gain the same. With the added benefit of removing the LF pole created by C8, C9 not the least the extra distortion caused by those electrolytics. So a true DC low frequency response. Edited November 28, 201411 yr by CraigBuckingham Report
November 30, 201411 yr comment_662270 I thought spritzer would be first to call me out on this. Anyway, 1.5V offset is way too much, there is a fault. Report
November 30, 201411 yr comment_662307 Despite the departure from klone status, I am interested in your improvements. Have you implemented any of the modifications that you're outlining? I have a spare board which I might consider stuffing. Report
November 30, 201411 yr comment_662337 Since it is off topic and is probably not what the majority of members would agree with I'll refrain further from any suggestions keeping with the spirit of the topic being a clone. It would be more appropriate to create another topic or probably keep it to PMs. Report
November 30, 201411 yr comment_662371 I think creating a new thread (topic) for it would be better than PM, but it's up to you. Report
December 1, 201411 yr comment_662425 Agreed. Public record (and review) would be better than a bunch of PMs. Report
December 1, 201411 yr comment_662477 Finished my KSA5 and am very pleased after a relativly short listening session. Board parts are standard from the BOM with extra attention paid to closely matching the parts. Goldpoint controls, Vampire RCA's, SUMR transformer. A big thank you to Kevin Gilmore for making this project possible! Me Report
December 1, 201411 yr comment_662481 1.5VDC? That's a lot and I think the servo can't eliminate that much offset. Were the inputs grounded (or the pot installed) when making the measurement? UFN, there is obviously a fault. For a 2N5564 with a data sheet specification for maximum offset of 5mV between the pair, this circuit should see a maximum of 25.6mV output offset for a worst case 2N5564 with the servo disconnected. This thing doesn't need a servo if it's using a matched input pair like the 2N5564. The servo can be removed and a trimmer potentiometer used to trim R3 and R4 to shift the drain currents of the input pair to null the input offset and therefore the output offset. R45 could be removed and R46 replaced with a 750Ω resistor to keep the gain the same. With the added benefit of removing the LF pole created by C8, C9 not the least the extra distortion caused by those electrolytics. So a true DC low frequency response. Thanks for the replies guys, I have been away and unable to retest until today. I was pretty sure I had the inputs properly grounded last time, but I removed the board from the case, reflowed a couple of suspicious joints and then retested it with better cabling. Now I get around 8mV on one channel and 22mV on the other without the opamps, and less than 5mV on both channels after fitting the opamps again. Not sure what exactly the problem was, but it looks like I've fixed it //UFN Report
December 1, 201411 yr comment_662482 Finished my KSA5 and am very pleased after a relativly short listening session. Board parts are standard from the BOM with extra attention paid to closely matching the parts. Goldpoint controls, Vampire RCA's, SUMR transformer. A big thank you to Kevin Gilmore for making this project possible! <snip> Me Nice work on that chassis! //UFN Report
