The Multi Amp aka Dynalo Mk2
Ordered off board version of golden reference boards from seeedstudio 1.6mm 2oz copper
Will have some extras for grab when my order gets here.
Kevin, are Golden reference boards finalized? You mentioned that there is oscillation unless some parts are not omitted...
  • Replies 1.6k
  • Views 545.4k
  • johnwmclean
    johnwmclean
the oscillation was in the ltspice simulation.
board run now, will know for sure once i build it.
possibility of z-foil .15 spacing resistors, going to screw up
the ground plane on the back
will try later
no 20 ohm z-foil resistors that i can find...
Texas components make them to order with no additional cost.
It looks good all SMT.
And quite straightforward.
I have just finished Sjostrom's Qrv-08 today, which is trickier with it's massive PS.
  • 4 weeks later...
one of my boards can't be adjusted below 1.3v/-.4v, can/should I change r26 to get the values closer to 0?
Also getting like 3V input DC, is this normal? Right now I'm floating everything and tying IEC ground to earth, amp boards are taking com from the power one supply (equivalent)
Edited by nopants
those are bipolar inputs, with a bit of offset current, so you really need a 10k input pot, or 10k
resistors to ground. other than that I listened to my latest set of boards on the new power supply,
and there is definitely a noticeable difference in noise with iem's.
I'll throw in a tkd then, you think that will help both input and output dc? does the input dc even need to be zeroed?
can't really zero the input dc. some of the that340 are better than others.
if you can get the lsk170/lsj79 parts, those sub directly. and have
much lower offset currents.
on the 8 boards I have done, all adjust to less than 1mv.
The conductors are too small to let the bass molecules though...
Back when Monster cable was first selling their cables with 3 sizes of wire (fat for the bass and thin for the treble), Frank van Alstine offered to wire the thin ones to an AC plug and plug it in while a Monster salesperson held on to one wire in each hand.  For some unfathomable reason, the salesperson declined. >:D
Thinking wear and tear.
Don't want these pairs of 3pin xlr anchors hanging down my neck.
What's the intended current through Q6 and Q9? Simulated THD seems to be minimal (0.021%) at ~4mA. Still getting high 3rd harmonic (-64.5dB, the 2nd is -77.8dB).
balanced in, balanced out, 7vrms out into 50 ohms 1khz
goldenreference power supply at +20.0000, -20.0000
(hand trimmed resistors)
thd is .011% which is actually the base line of this particular meter
typically .003% on the quantasylum400
and less on the audio precision
Neat. Still curious about the currents through Q9 and Q6. Could someone measure voltage drop across R3 and R15? Thanks.
I happened to order 3 extra amp board sets when building this amp and I won't be using them.
Anybody needs a set, send me a PM and I'll ship them your way for cost of postage. These are rev 9, with smd ptza06/56 and the rest through hole.
UPDATE: all board sets spoken for.
Edited by MLA
all boards gone
1.25 volts
160 ma current draw on each rail at 20v
Hi Kevin:
How hot do the heatsinks on your GoldenReference PS get at this condition?
I just tried running my SUSY Dynalo with the GR PS running on 18V rails and about 18mA per output mpswx6 devices (360mV voltage drop on the 20 ohm emitter resistors). I was using the same heatsinks as shown on your pic but they got too hot to the touch and I had to put much larger heatsinks on. I am a bit surprised.
Edited by mwl168
i had a variac on the power transformer and lowered the voltage to about 3 volts above the regulation minimum.So it really depends on how much voltage is on those transistors. With a total of about .5 amp, they can get warm.
Thanks Kevin.
I did not think of the variac idea, I'll give that a try. My toroid has 22v secondaris so the voltage drop on the pass resistor is quite high. I did test the PS without load and the heatsinks didn't even get warm.
one other thing, i went to bigger heatsinks since that picture when i'm driving both boards.
the heatsinks are the ones from the blackhole amp driver
Hmmmm... I was going to do about the same thing as Michael, though I was planning on 20V outputs with 22/23V toroid. Must look up this blackhole amp driver to see what heatsinks I will need to get.
