KGSSHV Carbon Build Thread
Try MKS2-.47/63/5T, almost same thing? different price.
Edited by JoaMat
  • Replies 2.1k
  • Views 694k
  • johnwmclean
    johnwmclean
Pars for the golden ref HV on both my blue hawaii builds and my current mini T2 build I used the  gerbers from the file kgsshvpssicfetdual2new This board does not have the cpc117n for the delayed start - but you can implement it via external relays. I made my own bom for it. Note you will need to change a couple of resistors if you dont want +-400V also if you are going golden reference dual LV you dont need the parts for the simple +-15V, the voltage regs,  this are marked on the bom as for low voltage section. Hope this helps. On the silkscreen the caps are 0.047uF 1KV not 0.47uF, So you might be looking at a different board from the golden ref HV I used.
Select
Mouser No: 941-C2M1000170D qvBtn.png
Mfr. No: C2M1000170D
Manufacturer: Cree, Inc.
Desc.: MOSFET SIC MOSFET 1700V RDS ON 1 Ohm
RoHS RoHS Compliant
Availability
2  Dispatches Now
£4.07 £8.14
Select
Mouser No: 747-IXCP10M90S qvBtn.png
Mfr. No: IXCP10M90S
Manufacturer: IXYS
Desc.: Current & Power Monitors & Regulators 900V 1-100mA
RoHS RoHS Compliant
Availability
5  Dispatches Now
£2.60 £13.00
Select
Mouser No: 511-STN9360 qvBtn.png
Mfr. No: STN9360
Manufacturer: STMicroelectronics
Desc.: Bipolar Transistors - BJT Hi Vltg fast-switch PNP pwr transistor
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.697 £1.39
Select
Mouser No: 512-2N3904TA qvBtn.png
Mfr. No: 2N3904TA
Manufacturer: ON Semiconductor
Desc.: Bipolar Transistors - BJT NPN Transistor General Purpose
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.163 £0.33
Select
Mouser No: 512-BC557BTA qvBtn.png
Mfr. No: BC557BTA
Desc.: Bipolar Transistors - BJT TO-92 PNP GP AMP
RoHS RoHS Compliant
 - - Add new 4
Availability
4  Dispatches Now
£0.178 £0.71
Select
Mouser No: 512-KSC5026MOS qvBtn.png
Mfr. No: KSC5026MOS
Desc.: Bipolar Transistors - BJT NPN Si Transistor
RoHS RoHS Compliant
Availability
4  Dispatches Now
£0.557 £2.23
Select
Mouser No: 689-DN2540N5-G qvBtn.png
Mfr. No: DN2540N5-G
Manufacturer: Microchip
Desc.: MOSFET 400V 25Ohm
RoHS RoHS Compliant
Availability
2  Dispatches Now
£1.01 £2.02
Select
Mouser No: 584-LT1021DCN8-10PBF qvBtn.png
Mfr. No: LT1021DCN8-10#PBF
Manufacturer: Analog Devices Inc.
Desc.: Voltage References Prec 10V Ref 20ppm/-uC
RoHS RoHS Compliant
Availability
2  Dispatches Now
£4.97 £9.94
Select
Mouser No: 513-NJM7815FA qvBtn.png
Mfr. No: NJM7815FA
Manufacturer: NJR
Desc.: Linear Voltage Regulators 15V 1.5A 3 Terminal
RoHS RoHS Compliant
 - - Add new for low voltage secti
Availability
1  Dispatches Now
£0.458 £0.46
Select
Mouser No: 513-NJM7915FA qvBtn.png
Mfr. No: NJM7915FA
Manufacturer: NJR
Desc.: Linear Voltage Regulators -15V 1.5A 3 Terminal
RoHS RoHS Compliant
Lifecycle: icon-lc-endoflife.pngEnd of Life: Scheduled for obsolescence and will be discontinued by the manufacturer.
Availability
1  Dispatches Now
£0.963 £0.96
Select
Mouser No: 660-MF1/2CC1000F qvBtn.png
Mfr. No: MF1/2CC1000F
Manufacturer: KOA Speer
Desc.: Metal Film Resistors - Through Hole 100ohms 1% 50PPM
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.147 £0.29
Select
Mouser No: 660-MF1/2CC1001F qvBtn.png
Mfr. No: MF1/2CC1001F
Desc.: Metal Film Resistors - Through Hole 1K 1% 50PPM
RoHS RoHS Compliant
Availability
6  Dispatches Now
£0.164 £0.98
Select
Mouser No: 660-MF1/2CC1003F qvBtn.png
Mfr. No: MF1/2CC1003F
Desc.: Metal Film Resistors - Through Hole 100K 1% 50PPM
RoHS RoHS Compliant
 - - Add new for headphones bias
Availability
2  Dispatches Now
£0.26 £0.52
Select
Mouser No: 660-MF1/2CC1502F qvBtn.png
Mfr. No: MF1/2CC1502F
Desc.: Metal Film Resistors - Through Hole 15K 1% 50PPM
RoHS RoHS Compliant
Availability
1  Dispatches Now
£0.164 £0.16
Select
Mouser No: 660-MF1/2CC2001F qvBtn.png
Mfr. No: MF1/2CC2001F
Desc.: Metal Film Resistors - Through Hole 2K 1% 50PPM
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.147 £0.29
Select
Mouser No: 660-MF1/2CC2002F qvBtn.png
Mfr. No: MF1/2CC2002F
Desc.: Metal Film Resistors - Through Hole 20Kohms 1% 50PPM
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.164 £0.33
Select
Mouser No: 71-RN60D-F-390K qvBtn.png
Mfr. No: RN60D3903FB14
Manufacturer: Vishay
Desc.: Metal Film Resistors - Through Hole 1/4watt 390Kohms 1% 100ppm
RoHS No
Availability
0  Dispatches Now
4  Backordered
£0.364 £1.46
Select
Mouser No: 660-MF1/2CC2493F qvBtn.png
Mfr. No: MF1/2CC2493F
Desc.: Metal Film Resistors - Through Hole 249Kohms 1% 50PPM
RoHS RoHS Compliant
Availability
8  Dispatches Now
£0.164 £1.31
Select
Mouser No: 660-MF1/2CC4701F qvBtn.png
Mfr. No: MF1/2CC4701F
Desc.: Metal Film Resistors - Through Hole 4.7K 1% 50PPM
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.164 £0.33
Select
Mouser No: 660-MF1/2CC4992F qvBtn.png
Mfr. No: MF1/2CC4992F
Desc.: Metal Film Resistors - Through Hole 49.9Kohms 1% 50PPM
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.164 £0.33
Select
Mouser No: 660-MF1/2CC49R9F qvBtn.png
Mfr. No: MF1/2CC49R9F
Desc.: Metal Film Resistors - Through Hole 49.9ohms 1% 50PPM
RoHS RoHS Compliant
 - - Add new 20
Availability
2  Dispatches Now
£0.303 £0.61
Select
Mouser No: 660-MOSX3CT521R5R1J qvBtn.png
Mfr. No: MOSX3CT521R5R1J
Desc.: Metal Oxide Resistors RSS3 5.1 5%TR
RoHS RoHS Compliant
 - - Add new 2
Availability
3  Dispatches Now
£0.181 £0.54
Select
Mouser No: 660-MS1/2DCT52R3011 qvBtn.png
Mfr. No: MFS1/2DCT52R3011F
Desc.: Metal Film Resistors - Through Hole 1/2W3.01K ohm 1%
RoHS RoHS Compliant
 - - Add new 1 for for headphones
Availability
3  Dispatches Now
£0.087 £0.26
Select
Mouser No: 71-RN60D-F-806K qvBtn.png
Mfr. No: RN60D8063FB14
Desc.: Metal Film Resistors - Through Hole 1/4watt 806Kohms 1% 100ppm
RoHS No
Availability
1  Dispatches Now
£0.201 £0.20
Select
Mouser No: 594-VR37000004704FR5 qvBtn.png
Mfr. No: VR37000004704FR500
Desc.: Metal Film Resistors - Through Hole 1/2watt 4.7Mohms 1%
RoHS RoHS Compliant By Exemption
Availability
1  Dispatches Now
£0.457 £0.46
Select
Mouser No: 505-M100.047/1000/5 qvBtn.png
Mfr. No: MKP10-.047/1000/5
Manufacturer: WIMA
Desc.: Film Capacitors 1000V .047uF 5% PCM15
RoHS RoHS Compliant
 - - Add new 2
Availability
2  Dispatches Now
£0.64 £1.28
Select
Mouser No: 505-MKS4.1/1000/10 qvBtn.png
Mfr. No: MKS4O131004J00KSSD
Manufacturer: WIMA
Desc.: Film Capacitors 1KV 0.1uF 10% PCM15
RoHS RoHS Compliant
Availability
4  Dispatches Now
£0.718 £2.87
Select
Mouser No: 581-TAP476K035CCS qvBtn.png
Mfr. No: TAP476K035CCS
Manufacturer: AVX
Desc.: Tantalum Capacitors - Solid Leaded 35V 47uF 10% ESR=800 mOhm
RoHS RoHS Compliant
Availability
2  Dispatches Now
£3.77 £7.54
Select
Mouser No: 75-561R10TCCV50 qvBtn.png
Mfr. No: 561R10TCCV50
Desc.: Ceramic Disc Capacitors 1Kvolts 5pF 5% .25LS NPO
Availability
2  Dispatches Now
£0.596 £1.19
Select
Mouser No: 667-EEU-FR1E101 qvBtn.png
Mfr. No: EEU-FR1E101
Manufacturer: Panasonic
Desc.: Aluminium Electrolytic Capacitors - Radial Leaded 25VDC 100uF 6.3x11.2mm LS2.5mm
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.248 £0.50
Select
Mouser No: 661-EKYB350E472ML40S qvBtn.png
Mfr. No: EKYB350ELL472ML40S
Manufacturer: United Chemi-Con (UCC)
Desc.: Aluminium Electrolytic Capacitors - Radial Leaded 35V 4700uF 20% Tol.
RoHS RoHS Compliant
 - - Add new for low voltage secti 2
Availability
0  Dispatches Now
2  Backordered
£2.05 £4.10
Select
Availability
4  Dispatches Now
£19.00 £76.00
Select
Mouser No: 863-1N5927BRLG qvBtn.png
Mfr. No: 1N5927BRLG
Desc.: Zener Diodes 12V 3W
RoHS RoHS Compliant
Availability
0  Dispatches Now
2  Backordered
£0.341 £0.68
Select
Mouser No: 863-1N5934BG qvBtn.png
Mfr. No: 1N5934BG
Desc.: Zener Diodes 24V 3W
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.364 £0.73
Select
Mouser No: 863-1N5952BRLG qvBtn.png
Mfr. No: 1N5952BRLG
Desc.: Zener Diodes ZEN SUR30 REG 3W
RoHS RoHS Compliant
Availability
1  Dispatches Now
£0.395 £0.40
Select
Mouser No: 625-Z4KE150A-E3/73 qvBtn.png
Mfr. No: Z4KE150A-E3/73
Desc.: Zener Diodes 150 Volt 1.5W 5%
Availability
3  Dispatches Now
£0.402 £1.21
Select
Mouser No: 863-1N4007G qvBtn.png
Mfr. No: 1N4007G
Desc.: Rectifiers 1000V 1A Standard
RoHS RoHS Compliant
 - - Add new 2 for headphones bias 2 for for low voltage
Availability
8  Dispatches Now
£0.163 £1.30
Select
Mouser No: 511-STTH512FP qvBtn.png
Mfr. No: STTH512FP
Desc.: Rectifiers high voltage diode
RoHS RoHS Compliant
Availability
8  Dispatches Now
£1.27 £10.16
Select
Mouser No: 575-113308 qvBtn.png
Mfr. No: 110-13-308-41-001000
Manufacturer: Mill-Max
Desc.: IC & Component Sockets 8P GLD PIN GLD CONT
RoHS RoHS Compliant
Availability
2  Dispatches Now
£0.929 £1.86
Select
Mouser No: 651-5452257 qvBtn.png
Mfr. No: 5452257
Manufacturer: Phoenix Contact
Desc.: Fixed Terminal Blocks BC-508X10- 2 BK
RoHS RoHS Compliant
Availability
3  Dispatches Now
£0.805 £2.42
Select
Mouser No: 651-5452258 qvBtn.png
Mfr. No: 5452258
Desc.: Fixed Terminal Blocks BC-508X10- 3 BK
RoHS RoHS Compliant
Availability
3  Dispatches Now
£1.22 £3.66
Select
 - - Add new for headphones bias for low voltage secti
Availability
1  Dispatches Now
£1.37 £1.37
Select
Mouser No: 588-EA-T220-38E qvBtn.png
Mfr. No: EA-T220-38E
Manufacturer: Ohmite
Desc.: Heat Sinks HEATSINK FOR TO-220 BLK ANODIZED
RoHS RoHS Compliant
Availability
1  Dispatches Now
£1.75 £1.75
Select
Availability
2  Dispatches Now
£0.596 £1.19
Select
Availability
7  Dispatches Now
£0.31 £2.17
Select
Availability
5  Dispatches Now
£0.457 £2.29
Edited by jamesmking
Pars, here is my reverse engineering of the kgsshvpssicfetdual2new I have added in red the extra parts for the delayed turn on but there are no pads present on the gerbers for them. As far as I can tell the dual hv boards stopped at version 1.7 just before the cpc117n was added. the individual "left" and ""right" boards went to version 1.8 - which included the cpc117n and the 600ohm resistor.
I just finished building the KGSSHV Carbon and Golden reference PSUs, well, using the PCBs from AliExpress. The performance is superb. It registers 0.0006x% THD+N up to 583Vrms and the distortion profile is very well behaved (2nd order slightly higher than 3rd order). The noise floor is at 1.1mVrms wide-band without power-line frequency harmonics. I found that my comfortable listening level is around 10Vrms and would probably never need that kind of dynamic headroom. Is there a lower gain option or mod that can bring the noise down?
Congratulations to your successful build of the Carbon. The world needs more good amplifiers.:)
Do you mind post some images?
I built the amp on a heat sink taken from an old Denon home theater receiver, and decided to try it out before investing more time and $$ on a 'real' enclosure. It just so happens that the heat sink has the exact length for two boards mounted side-by-side, and width to mount the transistors on both the PSU and amp boards. The big electrolytic caps are mounted on the opposite side of the PSU board to double as temporary mechanical support. You can see the green Soviet military style HV transformer. I got it a number of years ago on ebay when the international shipping wasn't that crazy. It's better suited for circuit requiring 400V or 350V B+, though.
Thanks for image. Indeed very creative built. No need  for fancy cabinet I’d say, unless you have children or cats. Maybe an IR module with the motorized potentiometer for remote convenience.
Oh I'll definitely put these in a proper enclosure with volume control and input selection, etc. This is just temporary.
By the way, do you have any suggestions to reduce the gain? Increasing the NFB would certainly do it. I'm more looking for a way to reduce the open loop gain I guess.
Looking forward a glimpse of your final enclosure.
I’ve no suggestions regarding reducing the gain.  Maybe there are folks out there that have.
Stupid question time, but what is the purpose of the stacked holes for the HV part mounting? Not the best pic, but best I could find.
if you are referring to the large filtering caps, those extra holes were provisioned for builders to use various brand of caps in the position including the boutique Mundorf caps IIRC.
The extra holes to the side were there to help with mechanical security of the caps (if so equipped) as some builders choose to mount the boards vertically on the heatsinks.
Thanks Michael. Actually, I was referring to the pairs of holes for the 10M90s I believe on the Carbon boards themselves (top of pic, past the two resistors).
Edited by Pars
Are you talking about the partially overlapped double holes for the C2M1000170D? I guess non-plated, oblong holes would work better, but somehow the layout person got sloppy and slapped on two plated holes (pads).
Kinda what I was guessing. Thanks Kevin!
A pair of Carbon boards complete other than JFETs. I used Soren's pre-adjustment method on the CCS's. They all came up at 15mA initially; adjusted them to 17mA for a start. I still need to clean the boards more. These are the .6G boards and appear to have a ground plane (haven't looked at the gerbers), so all resistors, etc. are up off the board. If any of you Stax mafia dudes see anything amiss, please let me know. I was careful building these...
Also, I got some pluggable connectors, Hirose DF5A (DF5A-5P-5DSA(35), DF5A-5S-5C) which are 500Vdc rated, and would fit just fine. They have one small nub or pin on the bottom, but it looks like you could either cut it off, or drill a small hole in the PCB for it.
Just a caution for testing - this amp runs HOT! Unless you bias the output device way down, make sure you mount those angles on a proper heatsinks before you energize it.
17mA bias seems like a good starting point. I run mine around 20mA IIRC.
Thanks Michael. Yes, I was going to get some heatsinks something like you used to bolt the angles to (as well as the PSU angles). And thanks for the tip awhile back about putting standoffs upside down for mounting the resistors, etc. to get them spaced off the board. Worked pretty well! They aren't perfect, but pretty good I think.
Mine also runs with 20mA and I am very happy with the result ... but it is a stove, be careful.
The undersized 175K resistors aren't a great idea so I'd have 1/2W units there.
Those were what was on the BOM. I’ll get some 1/2W, though I think people have built from this BOM before? Is a 350V rated part sufficient?
Thanks!
Vishay RN60D are the gold standard. I used them throughout. Possibly overkill. 🤷‍♂️
Thanks!
Chris: You need 1/2W for this position. There is significant voltage drop across these 2 175K resistors. You may have used an older version of the BOM. Check the first post on this thread where I had updated the BOM to use Vishay RN60 parts to replace the Xicon’s.
Edited by mwl168
I used KOA Speer 1/2W on everything I could. The 121R are Vishay/BC MRS25 (0.6W, 350V). I’ll either get some RN60 or Xicon 1/2W for the 174K.
