grounded grid
  • Replies 386
  • Views 142.2k
  • Just like Carbon we built. Same box, same PS. Relay=120s. Separated filament transformer.
  • Another Grounded Grid lives.  Have been listening to it for about a week. Powered by the same GRHV/GRLV PSU I use to power my KGSSHV, Carbon and Blue Hawaii. 400VDC rails and 20mA plate current.
Copied.
It's going to complicate my thing a bit.
12 hours ago, kevin gilmore said:
where did you get the delay board?
bought them form china
https://goo.gl/LKTtXI
Edited by ang728
Is there any way to delay a transformer secondary ?
I wanted to build the GG with a single transformer...
If you use GRHV supplies with “switch” – there are all kinds of supplies now days – it’s fairly easy to arrange a delay, even with a flashing led during pre-heat and steady in operation mode.
I used on my carbon an arduino and a solid-state rele. I'm doing the same thing on this PSU.
On 3/19/2017 at 2:01 AM, joehpj said:
Semi-customized. The shape of front plate, depth, height, and heatsink was fixed. Others were customized.
I assume these cases are from China? Any hint as to who/where they are from?
Everytime I see one of your pics, I keep thinking I like those... :)
Those are indeed from China. I have some spare.......so PM me for detail if you are interested :)
Has anyone used the 450 volt configuration?
I´m waiting for a Mouser´s BO and I can´t do nothing :unsure:
I'm building it with +-450V supplies.
Still a bit afraid of the possible short between B- connection and the feedback trace, like it happened to insanity's Carbon.
Edited by G600
precisions
Not built, still waiting for the custom transformer, and a bigger issue is the lack of a drill press and the related skills.
Still being a very young padawan in DIY. Need some more weeks before completion.
Edited by G600
Yes, I´m waiting for two trafos too.
TS300VA PRI: 230V
> 2x360V @350mA
> 18-0-18V @600mA
And:
TS50VA PRI: 230V SEC:
> 6,3V @8A
I don´t think that you have problems again if you use the "top" board (tube side) for put the conector.
Thanks Soren for the boards! Something fun and exciting in the future
Edited by Whitigir
12 minutes ago, G600 said:
Drill press madness...
are the 10m90 at the BIAS/PSU mounted using insulation washers - doesn't look like ?
Can see you are using nylon for those at the amp board ;o)
For sure !
I use the RENY screws I have left from the T2, with spring washers over standard washers. Outstanding stuff from Chemis.
The steel screw you can see just holds the board in place.
Edited by G600
Received the transformer today.
Didn't imagine such a big boy. But perfectly built.
Changing plans for casing, unless it won't fit.
Despite some mistakes and need of adjustment (make the tubes symmetrical for sure), you get the idea :
Edited by G600
Enormouse size! Very interesting, what it is dimensions and weight ...
140*70 cm, 5 Kg roughly
And not Sumr, but British one-man company with stellar products.
Nice work G600 I can not see the tag of your trafo but I have one question: EL34 uses 6.3vol @ 1.5A, if you use four EL34= 6.3vol @ 6A.
Your trafo only have 4.5A current so I understand that your transformer goes very low in amperage.
Edit: Sorry, it´s 2x 6.3volt @ 4.5A
Edited by jose
GRLV @+-15V
GRHV @ +459 and +464V
Waiting for a few more passive before starting to wire the Thing.
