What Are You Building Today
Even better once frued started carrying the cylindrical sanding tubes.
  • Replies 2k
  • Views 491.6k
FWIW, I have a big brother version of that sander, and I absolutely loathe it. It turns out that a sander can have way too much power. The little one is more useful.
The Ridgid seems pretty good, especially after I went to aftermarket paper. Really only used the belt sander up to this point.
The Dust Right on the other hand is about five minutes from being rolled up the driveway for trash pickup tomorrow.
That didn’t last long. What is the mater with it?
Edited by naamanf
I am going to flip the router table tonight so I can screw on the Dust Right box tomorrow when I get some screws.
Not sure I can fit anything else in my shop at this point.
Nothing with the function, I like suction and how quiet it is.
The putting together part is a cluster as it seems every screw is positioned exactly to have as little access as possible to it. Needed to use 4 different lengths of drivers and one screw head in a ratchet for the 16ish screws. Then you have to balance the fucking motor on top of the frame while trying to blindly find the holes that cannot be seen without standing on your head risking dropping the 80 pound thing on said head.
To make it even worse it somehow gave me carpal tunnel syndrome and ever since putting it together my left wrist is fucking shot. Can’t even pick anything up with my left hand since.
The little Lie-Nielsen and honing guide finally made it out of UPS purgatory and were delivered. The block plane is dramatically less substantial than the Stanley version.
Feels much better in use and things do not seem to just magically loosen up in use like the Stanley Sweetheart.
I have that same Lie Nielsen low angle block plane too. Then I bought a regular angle and a rebating low angle block plane by superb Chinese Quangsheng. These are basically Lie Nielsen knock offs, but are fantastically good quality with a thick iron that takes a razor edge, and needs hardly any back flattening.
The Quangsheng are branded as WoodRiver here in the US.
I have a Woodriver 4 1/2. It seems nice. The Bridge City one is still on back order so I have no idea if they are any good.
I definitely need one more little Woodpecker thing to fill this annoying gap.
I have been buying Norton replacements for the belt. Have not even tried a tube yet.
Great detail but how many walls do you have in your house?
Walls? I’m pinning these on my chest.
25 minutes ago, Voltron said:
I think you need new finishing room. But awesome work.
I do. Would love to be able to switch to a spray lacquer, would speed things up immensely.
Well from this perspective the finish looks like a sprayed lacquer finish.  Nice!
1 minute ago, n_maher said:
Seems like it's time to build a small down-draft spray booth.
I’m starting to run out of room 😬 once the jointer and bandsaw arrive I won’t have much room. The wings are 45” wide so it would take up considerable real estate.  Commercial space is calling my name. Or just moving to a place where I can build a 5000sqft shop. 🤔
