December 22, 200718 yr Just finished shoveling ~2' of snow off the deck, took about 2hrs. This is vacation?
December 22, 200718 yr Nah I hadn't shoveled the deck in over a week, no time. Took a few pics for boomana since she's been nostalgic for snow.
December 22, 200718 yr New MDF boards cut, drilled, lightly sanded (not as much as I should've - I'm lazy), and first coat of Danish oil applied. I think I need to go get more Danish oil before I'm done.
December 22, 200718 yr Additional coats applied and drying. I might apply more Danish oil later, but I should be able to put the rack together sometime tomorrow. The oil doesn't look as uneven in person - camera's flash makes it more obvious.
December 23, 200718 yr Looks like it. I made a very similar rack, but I didn't go to those lengths to treat it...Salt Peanut's should turn out nicely
December 23, 200718 yr Woofer inversion, definitely -- they have a visible outward tilt on the bottom (well, the passive radiators do, anyway). I may just have to go for the mods, though, as the woofers are one of the standard mods.
December 25, 200718 yr I built a Dynalo for my brother for Christmas and just finished casing it up today, so thought I'd share some pics. I used the board from my work Dynalo and put a new board in it that I just built up with Roderstein/PRP resistors, Pana FM and Elna Cerafines, etc. I used some Mill-Max flush socket pins to socket all transistors and FETs also. Sorry bro... but that one is mine Here's my new board: And here is the amp for my brother (knob was one I had laying around, not my favorite... but whatever): Hope he likes it!
December 25, 200718 yr Hmmm... Probably comcast... someone told me awhile back they could see them as http instead of https, so I tried that. Apparently not... https://home.comcast.net/~youngc1/My_dyna.JPG https://home.comcast.net/~youngc1/My_dyna2.JPG And here is the amp for my brother: https://home.comcast.net/~youngc1/Fr_dyna_lit.JPG https://home.comcast.net/~youngc1/Inside_rear_dyna.JPG https://home.comcast.net/~youngc1/Rear_dyna.JPG
January 14, 200818 yr I had a little bit of free time today so I decided to undertake the tedium that is matching all of the resistors for my balanced beta22. I guess this now officially qualifies as my next project.
January 14, 200818 yr Wow, Nate. You finally picked one of your many projects! Wuhoo!!! I concur. Good to see you actually working on your own amp for a change.
January 14, 200818 yr I concur. Good to see you actually working on your own amp for a change. I know, it can't last.
January 14, 200818 yr I know, it can't last. Mike quickly thinks if there is anything he can ship to Nate that will distract him once again.
January 14, 200818 yr Mike quickly thinks if there is anything he can ship to Nate that will distract him once again. Oh, I figure I'll be contacting you about something soon enough. I've got a certain email into Apogee...
January 14, 200818 yr I had a little bit of free time today so I decided to undertake the tedium that is matching all of the resistors for my balanced beta22. I guess this now officially qualifies as my next project. I take it you picked up the HP3478 that was FS a bit ago? You get any kelvin leads for it? I've got a 3468B that I use and like alot. Built some 4-wire leads with some Mueller clips from Mouser and some banana plug test jumpers I had laying around... nice for matching resistors.
January 14, 200818 yr I take it you picked up the HP3478 that was FS a bit ago? You get any kelvin leads for it? I've got a 3468B that I use and like alot. Built some 4-wire leads with some Mueller clips from Mouser and some banana plug test jumpers I had laying around... nice for matching resistors. I'm mad, but not quite that mad. I don't think you'll catch me doing 4-wire resistor matching any time soon.
