  • Replies 2k
  • Views 386.9k
  • Finished the mini bedroom audio rack with Rubio Monocoat and glued it up. Now in place and making me happy. Also shown are the Bendy Head headphone stand from Peter @Iron_Dreamer and coasters from Nat
  • I had previously talked about the bookstore I'm working on. It's almost open for business and I thought I'd show a few of the projects. The shelves are all solid Cyprus. The boardwalk in the back is R
  • Change of Command is this week, which means I get my 4th boss in three years (FML) so I decided I'd fabricobble the command gift.  The outgoing skipper is a Navy diver who has a penchant for clapping
1 hour ago, Voltron said:
"Amazing, amazing stuff!" Nice
I did like his Irish pronunciation of your last name too!
Or was it Scottish?
Well, it is an Irish name.
Wrapped up the tea box. Used the Shaper for joints/hinge/mortises/tea cup.
Quartersawn Oak, Sapele and Bubinga.
Edited by VPI
This little battery powered table saw is impressive. And it's quieter than the corded version.
Story of my life.
I had to cut the end of a long piece of baseboard, and didn't want to drag out my mitersaw.
I normally don't attach the extended fence.
Milling up all the left over Maple from the bench to make a benchtop for the new Maple built in for my closet.  Cannot figure out how to incorporate the bench dogs/vice in the dresser, but I think I can at least make some Jotoba drawer pulls.
Seems like one of these cordless tool companies should come up with a way to flip their  circular saw upside down and use it as a table saw.
Edited by dsavitsk
I used the aforementioned ping pong table to do a test inlay. Worked out very well, onto actually using it on something.20230507_153851.jpg
That just seems too easy. George Santos says he has the ability to alter the tree's DNA to grow it's own inlay.
Edited by swt61
This video would be better if Natasha were also involved.
And maybe moose and squirrel.
Works like a charm!
And I really like the way this 90 degree square guide tightens into the groove of the track, instead of clamping onto it.
Edited by swt61
I bought some Seneca tool for that but have never taken it out of the box to try it.
The scrap wood/HD Plywood built in is coming along. Need to decide now if i go full CanaryWood drawer fronts or all maple fronts with canarywood pulls or inlays.
Going to put some big bevels on the bottom and little ones on the top of the “scrap” top and then throw drawers in and hope my measurements were actually correct. 🙂
Edited by VPI
So much fun cutting hardwood drawers for Blum undermount slides only to come up short because i did not carry the 39/64 of an inch in my calculations.
Appears I need to mill all new fronts and backs to get to my 31 29/32 drawer box for these silly fucking slides.
I know that the Blum undermount slides are the hip thing these days. They do make a quality product, and there are certainly situations where they are preferable. But looking at the design of your current build, I'd think that side mounted KV drawer guides would work perfectly well. With the added bonus of being cheaper and much easier to install.
That's just my two cents.
Based upon my calculatorations, this one ended up being 573/800 of an inch off, but luckily it still seems to work.
Need to pull some of the levers built it to the slides to get the setback perfect for the yet to be processed birds eye maple drawer front.
That is a really nice slab of Birdseye Maple!
Trailer park hack.
The small DeWalt jobsite tablesaws will not accept a dado stack, because the spindle is too short.
But it will accept three thin curf blades of the same tooth number. Not as good as a 3/4" dado stack, but far superior to a 1/16" pass. This about 1/4".
1 hour ago, swt61 said:
Trailer park hack.
Single 1/4" kerf dado.
https://www.infinitytools.com/8-flat-top-dado-saw-blades
Or
https://www.boschtools.com/us/en/boschtools-ocs/router-tables-ra1141-201859-p/
Edited by dsavitsk
No room in the van for a router table. And $130 blade for a railing cap is overkill. This isn't something I need to do often at all. These 3 blades were $8 ea.
Probably a very nice blade for the shop though.
Edited by swt61
This is my first time to use Ipe. It seems that depending on how it’s cut (which seems obvious now, but anyways) there are sections that end up with this sort of mottled grain. This is normal, right? This isn’t end-grain but it’s 90 degrees to the typical smooth lines you see.. I should have better planned for this feature of the wood..
Here is what I am referring to:
Mine cut fairly smooth but looks similar. Looks completely different with finish. Just a pain in the ass to deal with so gave it all away.
Edited by VPI
Cool. Is that the natural/ clear tint Penofin?
It is the Hardwood version. Do not think there is any coloring.
