June 15, 201115 yr comment_452587 Nice work Kerry! Is that one of KG's boards, or did you have those made? Report
June 15, 201115 yr Author comment_452642 Woot!!! Mine just needs to have the heaters hooked up plus sort the earth but I sadly have no time to spend on it... Report
June 15, 201115 yr comment_452652 Great work Kerry! Spritzer, if I was that close to finishing, I think I'd just pull an all nighter if necessary. I can't wait to hear what both you guys think of the amp. Report
June 19, 201115 yr comment_453512 birgir's unit up and running. Evidently he has a noisy pot in one of the batteries, same as the problem andy had. Must be a large batch of bad trimpots. Report
June 19, 201115 yr comment_453521 Which pot? Is it perhaps the one that is (nearly) directly over one of the LED legs and a resistor? Report
June 19, 201115 yr comment_453529 I think I replaced both on one side so couldn't say. It may have been the 10k. Report
June 20, 201115 yr comment_453541 I'm wondering if it's related to the hissing issue that Inu found (and fixed). Seems like some extreme oscillation, that's cured once the amp gets a little more to a stable operating point. Then, once the pot is replaced, the other pot in that battery is already at a more sane location and the issue goes away. This would sorta make sense, given the fix that Inu performed (see link I posted a while back). Report
June 26, 201115 yr comment_454582 I've got two questions for the group: 1 - Does anyone have the part number for the coupler that goes from the Alps RK50 to the extension rod? 2 - The Neutrik connectors seem to push in a bit when you press the release tab. There is an unthreaded hole on the bottom of the neutrik connector where it mounts to the board. Has anyone tapped this and screwed it in? Is this recommended? Thanks. Also, I thought I would throw these pictures up... Report
June 26, 201115 yr comment_454584 Mouser 534-1453 perhaps? Edited June 26, 201115 yr by luvdunhill Report
June 26, 201115 yr comment_454585 The Alps shaft is about 8mm and the extension shaft is .25". I can look at McMaster, but wanted to see what other people did first. Report
June 26, 201115 yr Author comment_454631 I just enlarged the hole with a 8mm drill. I'll have to redo them since I can only get 6mm shafts here and it just makes a lot more sense to use a 8mm shaft. Speaking of my amp, I got new pots but the right channel is still fubar. Anybody whose dealt with loktal tubes knows this sound so the tube sockets are at the top of my suspect list. Report
June 27, 201115 yr comment_454789 Hi All Just wanted to share my (slow!) progress: PS Amp Seems i keep find small new components, i forgot to order ... peter Report
June 27, 201115 yr comment_454792 Holy shite! Buying the full set of prp was expensive enough... Shinkoh ftw Report
June 29, 201115 yr comment_455441 Assembling the mosfets 2sk216 and 2sj79 now is there any way to match them? (since there are a lot of parameters etc., and I dont know the operating mode/conditions). I allready did the simple test: http://www.4qdtec.com/mostest.html all K216 turned out fine. But got trouble with J79: I have 5 (1 extra - but from a different production batch. The 4 reads "6 G5" and 1 "0 J15 5yx"). Now one of the 4 cant be turned permanently on by the diode-tester (or my finger). the internal diode reads about 450 when off. Which suggests "some issue" with the internal capacitance. But i have no clue wether this is relevant. The extra from another batch works, but reads 425 when off. Which one to discard? Or better: what other test to perform? peter Report
July 5, 201115 yr comment_456481 Assembling the mosfets 2sk216 and 2sj79 now is there any way to match them? (since there are a lot of parameters etc., and I dont know the operating mode/conditions). I allready did the simple test: http://www.4qdtec.com/mostest.html all K216 turned out fine. But got trouble with J79: I have 5 (1 extra - but from a different production batch. The 4 reads "6 G5" and 1 "0 J15 5yx"). Now one of the 4 cant be turned permanently on by the diode-tester (or my finger). the internal diode reads about 450 when off. Which suggests "some issue" with the internal capacitance. But i have no clue wether this is relevant. The extra from another batch works, but reads 425 when off. Which one to discard? Or better: what other test to perform? peter Build myself a rough curvetracer, for testing/matching and the K216 seemed rather similar. And alle the J79 was ok - but the one from the different batch was quite different. However just as i finished, i somehow burned one of the good quad - and the dealer doesnt have any more from that batch So i need buy 2 new "low gain" types, to put in one of the channels peter Edited July 5, 201115 yr by pedefede Report
